Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
It keeps saying bidirectional support is disabled
It prints certain things like my schedule for school backwards
3 Suggested Answers
  • 18 Answers
SOURCE: what does disabling bidirectional support mean
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Posted on Oct 05, 2008
  • 2013 Answers
SOURCE: bidirectional support disabled
See this... http://support.en.kodak.com/app/answers/detail/a_id/1294/~/error%3A-bidirectional-support-is-disabled/selected/true
Posted on Jun 28, 2014
How can I keep in touch with my old school classmates and plan exciting events with them?
Schooling is one of the best time of our lives, that we can never forget as this is the time when we would have enjoyed thoroughly. School is filled with naughty, sweet and fun-filled memories. To meet and stay connected with our old friends will be surely one of the most exciting things one can ever do as well. I stay connected with my friends via the class reunion websites and the reason why I keep using them is not only to stay connected but also this tool lets me bring together my friends, for any meeting or event. This tool will organise and take care of the entire process of bringing everybody together and providing everybody with all details of getting together as well.
Apr 13, 2018 | Computers & Internet
Bidirectional support disabled
Jun 28, 2014 | Kodak ESP C310 AllInOne InkJet Printer
I have a dymo 450 and it keeps printing 2 labels each time. Is there a setting off?
Make sure you use genuine DYMO labels, not compatible ones. Also, make sure you select the right size in DYMO Label.
You may have to disable bidirectional support: right-click the printer > Printer Properties > Ports > uncheck the option. ^CM
Sep 26, 2013 | Dymo ® LabelWriter® 450 Series PC...
Keeps telling me to enable bidirectional communication
Hi:
When you first loaded the print driver there should have been a box to check to enable bidirectional communication. Most Lexmark printers require this to work properly
Andrew.
Feb 27, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
How to turn off network notices on the photosmart c309. They pop up on every computer the network printer is installed on.
Turn off bidirectional support. This should be in the printer properties under the ports tab. Uncheck the "Enable bidirectional support". If the printer is through a print server, you'll probably need to change this setting on there, otherwise if it is installed on each computer as a direct IP print to the printer, you'll need to change it on each computer.
Mar 31, 2010 | HP Photosmart Premium C309A All-In-One...
When i go to print i get an error message saying that i need to enable bidirectional communication. How do i do this?
Enable Bidirectional Support Go to Start
Control Panel
Printers
Right click on your printer, left click Properties, left click Ports.
Make sure to check the box Enable Bidirectional Support. (Enable Biodirectional Support)
Jan 12, 2010 | Dell 966 All-In-One InkJet Printer
When trying to print says enable bidirectional communication
I came up with a work around solution and for $9.99 I'll tell youo how I did it......
Jun 22, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x2350 series printer
Please check printer properties. Disable bidirectional support under printer properties. Go to printer and faxes and right click printer. Select properties and click on disable bidirectional support
May 20, 2009 | Lexmark X5150 All-In-One InkJet Printer
Siemens 2614
The printer port on 2600 series routers does not support bidirectional printing. This feature should be disabled for the product to function normally. See Related Articles at right for further information.
  • Solution
    To disabling bidirectional printing:
    1. Go to [Start > Settings > Printers] or [Start > Control Panel > Printers], depending on your version of Windows.
    2. Right-click the printer and select [Properties].
    3. Select�the�[Ports] tab.
    4. Deselect [Enable bidirectional support].
  • Hope this helps. let me know.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Jul 12, 2008 | Siemens SpeedStream 2614 Router (ss2614)
    Canon i320
    Try unticking ENABLE BIDIRECTIONAL SUPPORT on the Ports Tab under Printer Properties accessed through control panel / Printers and Faxes. Try to print - get error message Enable Bidirectional Support. Reverse back into Ports Tab and re-enable Bidirectional Support and try printing again.
    Jan 13, 2008 | Canon BubbleJet i320 Printer
    Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
    688 people viewed this question
    Top Kodak Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
