Question about Jandy AQUALINK RS TELELINK KIT
I'm trying to reprogram my aqualink rs8 system for better power usage costs. i am having trouble trying to figure out the way to reprogram for late night running. Thanks for the help. jim
    Top Expert:
  • Jandy Master
  • 6,465 Answers
Go to system set up go to program highlight filter then time on and time off
Posted on Jan 30, 2016
5 Suggested Answers
PartsCenter
  • 125 Answers
SOURCE: Operating instructions for Aqualink RS8 pool/spa combo panel?
AQUALINK GUIDE
Posted on Feb 26, 2009
  • 246 Answers
SOURCE: aqualinks rs8 wont power on...electrician has
check for the wire that connect the control
Posted on Aug 19, 2009
SHANEOK
  • 21 Answers
SOURCE: where are the water& air temp sensing low
there should be a diagram on the inside of the jandy box.#5,6,7,8 on the terminal bar.
Posted on Oct 02, 2009
Testimonial: "saw T.bar but no wires least I know where they go"
  • 990 Answers
SOURCE: Jandy aqualink rs8.Pool and spa lights wont come
If it's both lights and they are on seperate switches I would start by checking the GFCI and be sure it is not tripped and if it is you would need to find out why. Then check power in and out of the light module in your power center. If you can set the power center to service and turn the lights on manuley from there then it is programming but most of the time it will be something in the lights or their circut.
Posted on Mar 06, 2010
I purchased a home a little more than a month ago that has an Aqualink RS8 system installed. A couple weeks ago, we noticed that in the indoor control panel was not lit, so we checked the outside panel. ...
open the aqualink control box remove the top panel see if the 4 pin red connector is plugged in and tight if it is check to see if the one inside is connected if ok check to see if wiring is cut
Sep 27, 2014 | Jandy Aqualink All Button RS Control...
Aqualinks rs8
go to jandy site they have PDF files you can download or they will send you one go to system set up go to clear memory clear memory then reset button on front of aqualink panel that will loose everything
Jun 10, 2013 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
I want to know how to cancel a program on an AquaLink RS8
go into system setup find program then delete the one you dont want if using a all button just press cancel
Jul 15, 2012 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
I have a AquaLink RS8 and the spa light, filter light, and spa come on all the time. Only way to stop it is to go to service mode outside.
try disconnecting the spa side remote inside the aqualink look at the diagram on inside of front cover water in conduit or bad spa side will do this if it corrects by disconnecting replace spa side switch
Jun 29, 2011 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
I cannot figure out in the RS6 menu how to delete a device program. I have two programs for my cleaner and want to delete one. Anyone know?
The best thing you can do is to clear the memory for the system this should be done once in awhile it is like rebooting your computer.
Here are the steps;
1. Press the menu button
2. Now press < button till System Setup is displayed
3. Press enter
4. Press < till "Clear Memory" is displayed
5. Press Enter
6. Press Enter
You will get a message saying " System Memory is being Cleared"
Once it is done the display will go back to scrolling mode
Now reprogram the system as you normally would
You should do this "rebooting" once a year it will make the system run alot better.
Aqualink systems can get a issue called "Ghosting" which is equipment will get programed to run all on it's own. We see it alot in the bigger systems (RS8 and up) for some reason. We are a Jandy warranty center have been for 10 years now.
Hope this helps
Jan 08, 2011 | Jandy AQUALINK RS TELELINK KIT
We had an intense thunder storm and lightening the other night. My indoor Aqualink RS8 has a blank screen and is unresponsive. It apparently is not getting any power. The Spalink controller is blinking...
The circuit internally have gone short.There are many other facing this same problem.Some have got this indoor panel dead due to moisture collected on the indoor panels circuit board.The panel is not very strong to handle the humidity effect.It gets short. It has to be replaced. To get any other part and also the indoor panel board please click on the link below http://poolparts2u.com/products.asp?catid=0&scatid=27 ------ Thanks.
Jul 19, 2010 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Need a replacement manual
www.polytecpools.com/jandy-aqualink-rs8-all-button-pool-and-spa-combination-control-system-p-275.html -
Apr 26, 2009 | Computers & Internet
To clear the memory
Push the menu button once
Push the back arrow to "System setup"
Push star * or enter button
Push back arrow till display says " clear memory "
Push star or enter
Push star or enter again to confirm.
You will get a message "erasing memory"
Now you can reprogram system
Nov 18, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy AQUALINK RS TELELINK KIT  Logo
79 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
