Question about RCA F19426 19" TV
Theres no chanel and the screen say low signal waht is the problem
  • 757 Answers
That sounds like a problem related to an input for satellite television channels. Your satellite setup may need adjusting from it's options menu.
Posted on Jul 12, 2010
  • RCA Master
  • 11,800 Answers
The cable for the antenna is broken, fix it.
Chanel abc picture fragments
Assume you are using antenna, not cable or sat for signal.
abc signal is too low causing break up.
Reaim antenna for better reception.
Go to antennaweb.org website which should help you aim for best signal.
Feb 18, 2013 | Televison & Video
I have an Edimax 802.11/n wireless adapter installed on a desktop. We moved and the new location barely picks up the signal from my Linksys access point. In my previous house, it did okay, although it was...
check your edimax setting for the adapter if teh wireless signal is the same as the routers chanel the edimax defaul channel is always set to chanel 1 for the signal of its wireless and if your router has a different channel most probably channel 11 or 6 which is the most likely chanel that many use
May 22, 2010 | Computers & Internet
TV is turned on-only see blue screen that says Video
if only see blue screen indicate no video signal, check the yellow cable.
Apr 13, 2010 | Sanyo DS13204 TV
I can hear my xbox but can't see the screen
first off make sure that the chanel is set to the right input. check all your input chanels and make sure that its not on a diferent channel. also check both chanels 03 and 04 if you have an older model.
if all that is not doing anything then there mite be an issue with the av cabels see if any of them are missing the silver cover to go over the pin. if not then the cabels mite be cut inside it befor you go out and by new one try it out on a different tv and with a different xbox to see if theres anything. if the problem persists then i sugjest getn a new av cable for the xbox 360
Jan 05, 2010 | Microsoft Xbox 360 Console
Dodge Ram 1500 Ft turn signals work Rr signals and brakes dont Rr running lites work All fuses r good Is it the bulbs?
yes change the bulb and that'll fix it waht it is is that the low side of of the bulb is blowed .
Apr 17, 2009 | 2000 Dodge Ram 1500 Truck
No picture, no sound, but TV is on
do a chanel set up through the menu as if it was the first time you plugged it in. there is no signal on a digital tv with out an initial set up.
Jan 11, 2009 | RCA Televison & Video
Not working
Ok the problem was in the set up had to let it run through all the analog chanels and then through the didgital ones. After that it worked great. Thanks for the infoI read this on you sight so I tried it worked so were good.
Nov 23, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Cannt get tv to change chanel
Check the mode the tv is on (Use "Source" button on remote to change modes). There are several modes to choose from.
Jul 16, 2008 | Akai LCT3201AD 32 in. LCD Television
Mitsubishi tv 52'
CHECK BASE BIAS VOLTAGE OF Q217, FOR 0 VDC (BIASED OFF) IF .7 VDC (BIASED ON) CHECK C268 (22 UFD 50 V) OFF C OF Q215 V-PROTECTOR ON THE SIGNAL PCB. 2. VERTICAL BEAM BLANKING ACTIVE, CHECK PIN 4 OF IC401 FOR 3 VDC IF MISSING CHECK IC202 (5V REG) PART # 266P932010, ON THE SIGNAL PCB. 3. CHECK PIN 6 OF IC200 FOR 9 VDC IF LOW OR MISSING CHECK IC203 PART # 270P210010 ON THE SIGNAL PCB. 4. MAY BE INTERMITTENT. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. Now these are the technical terms, if you do not have the experience you may need a qualified person to do this. Hope this helps
Sep 08, 2007 | Mitsubishi VS-5043 50" Rear Projection...
RCA F19426 19" TV Logo
77 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
