Question about Fisher and Paykel GWL11 Top Load Washer
2nd 3rd and 5th lights on. washer stopped in the spin cycle and water won't drain. washer won.t come back on
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Do you still require help ?Please reply and I can help you rectify this fault.
Posted on Jul 16, 2010
Fishwe&Paykel GWL10 won
It could be the out of balance switch faulty & need replacing.
Nov 17, 2012 | Fisher Paykel EcoSmart GWL15
Fisher & Paykel Pride 5.5 won't wash. It fills with water then starts to beep. I can advance it to the rinse stage so it drains the water, once the water is drained, it starts to beep again. The...
Hi - the out of balance switch has activated this will be found under the lid right side if you bend lw enough you can see it hanging by a lever - it may have activated from the previous cycle - it needs to be freed - put it outside of the bowl and be sure its free to operate - if not it needs to be removed and replaced.
Jul 12, 2011 | Washing Machines
Not draining an erro comes up E20 on it
E20 = draining issue. The most common problem is a blockage at the drain pump.
This can be checked by a DIYer with general hand-tools.
1st. Unplug the washer! We don't want to get shocked.
2nd. There is a lower panel on this unit which can be removed by removing two screws at the bottom. Remove this panel to gain access to the drain pump area.
3rd. Find a big diameter black hose coming from the bottom of the wash tub and follow it until it gets to a plastic housing with an electric motor sticking out the side. (there will be a smaller diameter hose coming out of this plastic housing as well this is your drain hose)
4th. Remove hose clamp on large black hose and remove hose from pump (water will flow! be ready)
5th. Check hose and pump for blockages... One of the most common is under-wires from the wife's bras. Spin impeller of pump to insure that it moves freely.
6th. Put it back together in reverse order of taking it apart. Try unit out by starting a cycle without clothes. Then put it in a spin cycle to see if water drains.
May 17, 2011 | Frigidaire GLTF1670A Front Load Washer
Fisher/Paykel WA37TG1 washer. goes through the wash cycle and the rinse cycle. stops at spin cycle and beeps. lots of suds left on clothes. have unplugged and let sit and start again. this got me through a...
Hi just read your posting.Now when the cycle beeps a series of lights will light up indicating an error code.The lights will be in a row of 8 lights.Starting from the left to the right which lights are lit?Is it the 2nd and 5th or the 3rd and 7th ---etc----?Or do you have the display model and an error code is on the screen?Please reply with the additional information on the questions and I can help you further.
Jul 20, 2010 | Fisher and Paykel WA37TG1 Top Load Stacked...
My washer stops when it is in the draining proses almost when it has draining all water and it wont continue
Hi just read your posting.Now when the machine stops does, it beep and show a series of lights.If it does show lights that are lit then they will be in a row of 8 lights.Starting from left to right which ones are on?Is it the 2nd and 4th or the 5th and 7th ---etc---?Please reply with additional information and I can help you rectify this problem.
Jul 11, 2010 | Fisher and Paykel GWL11 Top Load Washer
F&P GW512 compact wont spin
Hi just read your posting.Does your machine drain the water out?Starting from left to right what lights were lit on the progress bar when it started to beep?Was it the 2nd and 5th or 3rd and 7th---etc---?Please reply with additional information on the questions and I am sure I can help you rectify this fault.
Jul 09, 2010 | Fisher and Paykel GWL11 Top Load Washer
After washing heavy load mashine spin cycle not working
Hi just read your posting.Does your machine drain the water .When your machine stopped doing the spin cycle did it start to beep and show a series of lights as an error code?Or have you got the model with the LCD display and it showed an error code in letters?If you have the model with lights and your machine beeped the lights that did come on will be in a row of 8.Starting from left to right is it the 2nd and 5th lights on or the 4th and 8th lights---etc---- that are lit? Please reply and I can help you rectify this fault for you.
Jun 26, 2010 | Fisher and Paykel GWL11 Top Load Washer
Not spining
1st,check if you have lay down the drain hose to the ground,2nd if the drain hose is blocked.3rd,if the drain pump has problem
Mar 07, 2010 | Frigidaire ATF6000ES Front Load Washer
GLW10US won't do anything but beep
well i don't have any experience with this brand but i would say you need to change the fill switch it senses how much water is in the tub shuts the water off then starts the washer its also called the pressure switch
Feb 16, 2008 | Washing Machines
Fisher and Paykel GWL11 Top Load Washer Logo
117 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
