Question about Jenn-Air Cooktops
Help in locating an electric grill unit insert for Jenn Air C202
Can you assist me in locating a grill unit insert for the Jenn Air, 30 inch electric, Model C202
  • 8,197 Answers
You can buy the part that you need on the link below.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=24066&diagram_id=877457#d877457
Good Luck and please rate 4 thumbs up for the free answer.
Posted on Jul 12, 2010
Testimonial: "great response and most prompt, although I erred in describing my searched for item as a grill when I should have said griddle. "
I have a Jenn air c221 cooktop in need of replacement what are the dimensions of this unit.
Here are the dimensions for the Jenn air c221 cooktop. Hoping this will help.
width 29 15/16th of an inch.
depth 21 9/16th of an inch.
cutout width is 28 7/8th of an inch.
cutout depth is 20 15/16th of an inch.
Feb 04, 2011 | Cooktops
Wire for stove top burners
same place you got the switches,you can usually get the whole harness.
Nov 17, 2008 | Jenn-Air JED8430 Electric Cooktop
Melted plastic help!!!!!!!
While the cook top is cool, use a razor blade scraper to remove most of the melted plastic.  Turn on the cook top to warm the remaining plastic slightly, turn off the cooktop,  and then wipe off the excess.
Sep 23, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Cooking element
Hello
If the grilling elements does not get hot enough, then the main reasons for that are:
Escessive air movement across the grill.
Surface controls may not be properly set.
and the voltage maybe low.
But if is not getting hot at all then you can check by exchainging the elements to see if it is the element itself, and if it is the element then you will need to replace it.
I hope this help!!
If you need to replace it I know a place that are very cheap for Jenn-Air parts and super fast delivery...Let me know.
Eddie rentas
Tupper Lake
Jul 13, 2008 | Jenn-Air JED7430 Electric Cooktop
Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Jun 08, 2008 | Jenn-Air JGD8130 Gas Cooktop
Circuit Braker Jumps Off
You probably have a burnt out element. They almost always short out when they burn out. If it is a coil unit it may be visible. A smooth top unit can't be diagnosed without removing the top glass. Most of the time you can do this yourself. Sometimes when a burner goes it will ruin the switch also.
Mar 29, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Jenn-Air 30in. Exaust problem
liquid spill and alarm won't go off.
Mar 21, 2008 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Jenn Air Not Exhausting During Grilling
is this down draft cook top or give me the m# thanks
Jan 13, 2008 | Jenn-Air JED8230 Electric Cooktop
JENNAIR DOWNDRAFT COOKTOP
bibman: Sounds like the control switch or possible loose wiring. Take the element out and test the slots for voltage. You should get 220 Volts when on high.
DMA Jennair The fan motor is bad and needs to be replaced.
I suggest a new cooktop as THIS IS THE WORST DESIGNED COOKTOP I HAVE EVER USED. Not enough power, very hard to clean,
Aug 20, 2007 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Cooktops Logo
314 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
