Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Tub won't drain
My Whirlpool Ultimate Care II washer doesn't drain. Everything else works fine and it goes through the complete cycle. I took off all hoses & found no blockage (once drain hose is removed, water drains out). I also replaced the pump. It still doesn't drain when going through the wash cycle. Does anyone know of another thing besides blockage & a bad pump that could cause this? Thanks.
  • nanaj07 Jul 16, 2010
    It turns out the switch is OK. The washer does spin, but wasn't draining. This model has a drain solenoid which I found stuck in the closed (recycle) position. It forces water back into the drum. I moved it into the open (drain) position and the washer now drains when it is suppose to. It?s now stuck in that position, however.
    The problem now is that when it goes into the spin & rinse position, it doesn't cycle between that position and spin & drain (a feature of the Whirlpool Ultimate Care II washer). It stays in the rinse position indefinitely. This looks like the timer is stuck, but I never had a problem with the timer before this solenoid got stuck. I suspect the washer when in rinse mode, would normally have the solenoid in the closed position. If this were the case, the washer would start to fill during the rinse cycle. I'm guessing that once it fills to a certain level, the washer would then go to the next position which is spin & drain. Does this model work this way? I'd hate to buy & install a new drain solenoid if the timer is also now gone.
  • tinsmith07
    tinsmith07 Jan 26, 2014
    Really?! I\'m having the "no drain" issue, thought I got out the small obstructions and after I put it all back together still no drain. These are apparently bad washers since almost everyone is having this issue
  • Whirlpool Master
  • 8,220 Answers
The lid switch has a green ground wire and 2 hot wires. Jump them 2 hot wires and see if she pumps out.Tub won't drain - 7bce33c.jpg025e16d.gif
More here
bypass it here for testing purposes. How it works: direct drive washer
Posted on Jul 12, 2010
  • Dan Webster
    Dan Webster Jul 16, 2010
    If that is one of the washer models with the water saver feature you have a weird one. That solenoid is expensive. Look through this manual and tell me if this is your machine. The model number you posted does not show a water saver drain solenoid. Catalyst
  • Dan Webster
    That is whirlpool's attempt at saving water. It is the precursor to the calypso. The idea is instead of dumping 35 gallons of water in the tub for wash and 35 more gallons for rinse they put in enough water for the diverter to continually pump water over the clothes. You must replace the diverter valve. You cannot get around it on this type washer. The extra pressure dome is a safety feature which shuts off the wate rvalve in case the diverter gets stuck.
My washer does have this feature. It must be a weird one since I can find no mention of it anywhere except in the manual you attached. The "diverter valve" (pg. 19 in the manual) is the part that is stuck in one position. I also recognize the "recirculation pressure dome" from the manual. I'm guessing that the pressure dome must sense a certain pressure level in order to fire the solenoid on the diverter valve to switch it from recirculate to drain. Right now it never builds up that pressure because the valve is stuck in the drain position. Does that make sense?
And yeah, that diverter valve is expensive. You can't buy the solenoid separately.
Posted on Jul 16, 2010
I have a Whirlpool Ultimate Care II washing machine (model LSN1000JQ0). The washer will fill with water and begin to agitate. Shortly after it will stop and will not drain. I've cleaned all hoses
see the next steps and use the common sense: God bless you
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 01, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II Washer will not drain
bad lid switch,open the lid a few inches and close it down,if you do this a few times and don't hear a clicking sound the switch is bad.
http://www.youtube.com/watch?v=PZAbg9uftos
Jun 05, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool Ultimate Care II washer goes thru all cycles but will not spin, so clothes are wet. We replaced the motor coupler but will only spin without clothes. Once you put clothes in the tub does
sounds like direct drive gears are bad.. there is a slip coupling that goes over the shaft of the transmission adn assist turning the tub that could be worn or broken. you will have to remove the agitator and check the nut on top of the tub to see if it is tight or to remove the nut and check that coupling.
Dec 01, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Water overflow when tub is emptying during spin cycle
It sounds more like you have a drain problem that a machine problem. Try draining into the laundry tub and check that the tub drains quickly enough. If not, you have a plumbing problem...Good luck...Nomess
May 14, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Whirlpool Ultimate Care II Washing Machine. Lately, the spin cycle does not remove all the water. How can I fix this? Thanks. Bill
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II does not completely drain.
Mine will do this if clothes are left in it for a long period of time. The pump will not drain all water out because the will dry out the seals if they do. Your wet clothes dripped in the tub raising the water level to the bottom of the drum and that is why you have wet clothes. Remove clothes as soon as they are done, use cycle signal to avoid this.
Apr 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II will not spin
You said,washer is full of water and will not spin. You hear the lid switch clicking. When you start it on spin cycle and hear a hum, the tub moves a couple of inches and then stops...shortly after it shuts off.
Some reasons this may happen
Washer won’t drain or spin
n
1. Is the drain hose clogged, or the end of the drain hose
more than 72 inches (183 cm) above the floor?
2. Is the lid open? ............Also the lid switch can be faulty!!
The lid must be closed during operation.
3. Is there excessive sudsing?
Always measure detergent. Follow manufacturer’s directions.
4 If you have very soft water, you might need to use less
detergent.
Sounds to me like the lid switch can be faulty!!Then it acts like the lid is open.
Huuum
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
1,075 people viewed this question
Dan Webster
Dan Webster
Sal De
