Question about Poulan FL1500LE 25cc 150 MPH Blower
Wont start not fuel new spark plug - Poulan FL1500LE 25cc 150 MPH Blower
  • 718 Answers
Do you have spark? if no spark SOL is your gas line good, did you rebuild carb, pretty vague question for someone asking for help. Your question sounds a little like you know everything already but try what I sugested and you might get somewhere. Gas and spark is the key to keep these things running its not rocket science. Good Luck PAL
Posted on Jul 12, 2010
Saw wont start, getting fuel and spark
Try starting it with the air filter removed. If it starts, clean the air filter. It could also be the fuel filter. If you replaced all the fuel lines, make sure you didn't get the oil line mixed up with a fuel line
Jan 25, 2015 | Poulan Garden
2001 dodge stratus 3.0l automatic cranks but wont start not even with start fluid
check the fuel pressure and make sure you got the correct pressure
Jan 25, 2014 | 2001 Dodge Stratus
Spark plug blew out now car wont start
sounds like the autoshutoff relay may be bad..it controls the ingition and the fuel pump too..if the pump works check for spark by inserting a screwdriver into a pulled off spark plug wire and look for a decent spark between the screwdriver shaft and any ground like the block..if no spark the relay may not be powering up the ignition system..
Dec 15, 2013 | Acura RSX Cars & Trucks
92 kodiak wont start
well no fuel pressure most likely bad fuel pump so if i were you would get new fuel pump new fuel lines new fuel injectors that covers your fuel problem then with no spark most likey a bad distributor so get a new distributor and to make sure i would get new ignition coil and spark plug wires and spark plugs
Nov 25, 2012 | Cars & Trucks
Wont start
Are you getting spark to the plugs ?
Is the fuel pressure in the normal range ?
Any chance the timing belt has jumped a tooth or two ?
Have you checked for trouble codes ?
It could be a long list of possible issues. You'll have to narrow it down to fuel or spark to proceed.
Aug 07, 2012 | 1995 Dodge Neon
My Mitsubushi Space Star Car won't Start. What can I try?
spark plugs are deep in the head yet you should get all the the old fuel out first, stale fuel wont ignite and will also clogg fuel filter. you need a mix of atleast 70% new fuel even then its not good for the injecters. If its a manual gearbox a tow start is a quick fix although no go for auto's. cant be much wrong if car was fine when parked, plugs-fuel-filter and possibly fuel pump for sure. If that doesnt fix take plug out put in lead and crank engine to be sure you have spark even just put any plug you know works in lead leaving your plugs in engine just to check for spark y turning over engine looking for spark on plug good spark will be blue but any spark is good.
Jun 16, 2012 | Mitsubishi Cars & Trucks
Wont fire
You have to check of there is sparks at the spark plug and also if the fuel is being injected to the combustion chamber.
Crank start the engine for a short while and thn remove one spark plug, if fuel is injected you will see tht the plug is wet.
To check for sparks to the plug, wipe tht plug dry if its wet due to gas, thn earth the spark plug body to the engine and crank start, if theres sparks you will see.
If you both of these thn it the engine must fire.
I guess one is missing.
Hope this helps!
Dec 19, 2009 | 2005 Triumph Sprint ST
Wont start has spark , new fuel, new oil.
Is the spark plug black?
It won't run well with a carbonized plug.
Is the main jet in the carb plugged?
If the plug is dry after trying to start it.....your fuel is not getting into the engine and most likely a plugged carb jet..
Also.....Is the fuel switch working...is it in run position?
If the generator has sat for a while with fuel left in the carb/fuel tank.......the most common problem is a plugged varnished dirty carburetor in need of a good cleaning.
Always shut the fuel off and let the carb run dry (run until the engine stops)before storing.
Add fuel stabilizer to any remaining fuel or drain the tank before storing.
Oct 14, 2009 | Honda Electrical Supplies
The car wont start but trying got spark and got
This could be a lot of things,fuel pump pressure not enough(new fuel pump)or spark plugs and air filter need to be replaced(flooded plugs and air filter stopping up)timing has jumped,or maybe a blocked fuel filter?
Aug 08, 2009 | 1989 Oldsmobile Cutlass Supreme
98 chevy camaro wont start
check fuel pressure regulator
Dec 06, 2008 | 1998 Chevrolet Camaro
Poulan FL1500LE 25cc 150 MPH Blower Logo
175 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
