Question about Epson Stylus Photo R2400 InkJet Printer
Printing starts ok, then usually about halfway through it makes a clattering noise [like gear wheels slipping making printer judder]this does not always affect the print but sometimes gives vertical banding . The printer is a Epson R2400 and I am using [succesfully up to now] the permajet inkflow system
Hi Paul,
I have exactly the same problem and I also use Permajet (like you, successfully for a while). In fact I took the printer into a shop that does maintenance but it printed fine for them. As soon as I got it home the problem started inmediately! At random points in the print you get a crunching noise and the print has vertical marks on it. The engineer at the shop had no idea what this could be and I just wondered if you had solved it.
I've swapped cables, installed it on different machines but nothing works.
Kind regards
John
Posted on Sep 25, 2010
  • johnjenkins1 Sep 27, 2010
    After weeks of searching I've just got the answer to this weird problem!
    Central Heating!
    The tubes that run from the Permajet Eco Flow ink bottles to the print head expand in the heat and therefore need realigning at this time of year as people turn on their central heating. I phoned Permajet on a hunch and they described the problem to me even before to told them.
    It took me 2 minutes to correct.
    Here's the instructions how to fix it:
    1. Press the ink drop button on the printer panel so that the printer head moves in the ink change position.
    2. Unplug the power lead from the back of the printer.
    3. Now move the printer head to the far left as far as it will go, ensuring the head passes under the foam strip.
    4. Unclamp the grey tube clip on the right hand side of the printer; do not open fully as this will snap the clip.
    5. Hold the ribbon of tubes near the grey clip and pull the ribbon of tubes very gentle towards the bottle end, but please keep an eye on the printer head as soon as this moves towards the right stop pulling.
    6. Push the printer head back to the left hand side as this has moved slightly.
    7. Clamp the grey tube clip making sure the ribbon of tubes are positioned in-between the clip and close this firmly.
    8. Make sure that you pull about 1mm extra tubing towards the left to the printer head.
    9. Move the printer head manually to the far right hand side, pass the ink change position, when you have done that move the head to the far left as per 3 and back to the right hand side.
    10. Please perform and move the printer head from right to left a few times until you are satisfied that you have enough tubing to allow the printer head to move smoothly from right to left. You are now ready to plug and power the printer back on.
    Kind regards
    John
  • josearle Dec 25, 2010
    Hi John,
    I know its Christmas Day but we are waiting for our Grandaughter to arrive so I thought I would scan the net to see if anyone had this problem. Lo and behold I found your entry the only difference is that we have a Fotospeed CIS.
    Before I go blundering in do you think this a similar problem the Fotospeed System.
    We had a problem with blocked jets which is now resolved but still experience the grinding noises you desccribe with some minor paper jams.
    Would appreciste your thoughts.
    Have a good Christmas.
    Regards
    Joanne Searle
    E Mail josearle@onetel.com
What is the cause and solution of a grinding noise when printing from a xerox workcentre 6605dn color laser
Defiantly a main drive issue, slipping belt can make the noise you described, sometimes the pulley gets tight or the tensioner binds causing the belt to slip
May 17, 2014 | Xerox WorkCentre 6605/DN Color Laser...
1998 jeep cherokee clattering noise when starting in first gear
Very Hard to say where a Clatter is coming from.
Do you have an Automatic or Manual Transmission?
Does it make a noise when you are turning and it stays in 4WD?
Feb 13, 2014 | 1998 Jeep Cherokee
Service manual
Any time I hear that complaint I cringe. Not because of the noise but what it might be telling me. I usually hear that noise as the hot roller bushings &/or the main gear that drives the fuser is cracking or already cracked and is ready to fail. This causes the roller to bind up hence, the grinding noise. Sometimes a drum can seize and that will also make that sound but if you're able to print OK that is probably not the issue.
Oct 24, 2013 | Epson ACULASER CX11NF All-In-One Printer
Noise in rear end
Provided that this is a rear-wheel drive vehicle, there are a number of things which can make noise when you accelerate. Most are due to excess clearance in moving parts. This means some parts are worn out.
On the outside, the U-joint next to the rear differential can be worn and make noise. Inside the differential, usually a pinion bearing(carrier bearing) can make a noise like a whine or growl depending on the gap.
Now in the axle tube, the axle shafts have a bearing on each wheel. Like any bearing, when they wear out, noise usually indicates failure.
When Torque is applied on acceleration, the parts shift creating noise. If you have a Limited Slip Differential, there are clutch plates which have a material which can wear out. These types of rear ends also need a special Additive to make the parts work. Sometimes you get a clatter when the additive is low.
Have the U-joint checked first as it is the only external part to check. The rest will need disassembly.
Please rate my info.
Mar 11, 2013 | Ford Sport Trac Cars & Trucks
How do I remove the cover from an HP Deskjet 5740 printer
No need to open its cover. that is normal, when the print is first start the mechanical parts are re-adjusting and re-alignment its system to start printing.
Sep 11, 2012 | HP Deskjet 5740 InkJet Printer
My hp deskjet F2430 is making a loud clicking noise when it is printing something. What is wrong with it?
I don't have a solution, but mine is doing the same thing. It also has started printing multiple copies all on its own when I print a multi-page document. It will stop printing, for example, right in the middle of the third page, kick out the page halfway printed, and then start from the beginning all over again. This is my fourth HP product over the years, and I've never had any luck with any of them. They were all short-lived, pc's included.
Sep 28, 2010 | HP DeskJet 5150 InkJet Printer
Before pulling in paper printer makes a gear slipping noise. sounds like plastic gears slipping. printer works ok otherwise
One of the gear in the roller mechanism is either displaced and not in alignment with other gear wheels OR the gear blades is broken. You have to take the assistance of technician from service center to open the printer and change the part. You can not do it your self.
Sep 15, 2010 | Office Equipment & Supplies
Paper jam in Canon PIXMA iP90
one of your feed gears has poped out of placeor one of the teeth is broken,check the paper path with a flashlight you will probably see one loose.
Good luck
Aug 28, 2009 | Canon PIXMA iP90 InkJet Printer
Loud clattering noise
-Open the Front Cover. -Remove the Toner Cartridge -Remove the Drum Cartridge -Next locate the black gear attached to the end of the Drum and turn it with your fingers. -Check to see if the gear is locked, or difficult to turn. The gear will only turn in one direction. -If the gear won't turn at all, or if it catches while you are turning it, or if you hear the same noise when you turn the gear that you heard when the machine was on, the Drum Cartridge is the cause and will need to be replaced.
Jun 22, 2007 | Xerox WorkCentre XE88 Laser Printer
Epson Stylus Photo R2400 InkJet Printer Logo
229 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
