Question about Lisle Serpentine Belt Tool & Accessories - Expanded Model
Instructions how to replace and adjust serpentine belt on 1997 toyota corolla 1.8
  • 760 Answers
Here is a cool pdf of many belt diagrams:
http://onlinemechanical.net/support-files/serpentine_belts.pdf
page 4 of this PDF begins listings of different cars. Find yours and then click on belt number and it will take you to the page for the diagram.
Posted on Jul 19, 2010
Just recently bought a used 1997 Corolla earlier this year. We replaced the alternator belt after finding it frayed to spaghetti and didn't think to change out any other belt. With the cold weather rolling...
ok if it has a serpentine belt it would be flat with grooves on one side, and the other belt style is a v belt witch has a v shape surface that fits down in the pulleys. If it is the serpentine belt most likely it has an auto matic adjuster on it that means it keeps it to proper tention. But if it has v belt then look over the belt to see if it is cracked or frayed. it so replace. Also look for burnt marks on it where it may have been sliding on a pulley if so then you have one of the pulleys locking up and thans causing it to squeak. If you inspect it and it looks ok go buy some belt dressing at auto zone and spay it on the belts good it will take the squeak out. hope this helps
Dec 17, 2010 | 1997 Toyota Corolla
How to replace the serpentine belt in a toyota corolla 2002 LE.
On the Toyota Corolla has only one belt that goes around on pulley. Is a mechanism that you loose to remove the belt. is next of the body of the car on the right side where is the belt. I change the belt of my cousin Toyota Corolla 2004.
Nov 16, 2010 | Toyota Corolla Cars & Trucks
The serpentine belt squeaks. I'll check the belt & the tensioner. Anything else I should look for?
The Corolla's has a hydralic belt tensioner. When you replace the serp belt you need to buy a factory Toyota belt. The reason why the after-market reproduction belts are slightly long or short. This
will either cause a squeaky belt problem or a over adjusted belt condition which could burn up one of your engines accessories (p/s pump, alt. etc.)
Apr 05, 2010 | 2007 Toyota Corolla
SERPENTINE BELT REPLACEMENT
The Belt Diagram should be on the underside of your hood, however they have a way of disappearing.
If it is not there:
Click on the following free direct Link. It has the correct Serpentine Belt Diagrams for your 2001 Toyota Corolla 1.8L (4-Cylinder) Engine and Engine Options (AC/No AC etc.). Included are Instructional and Directional Diagrams for your use.
Let me know if this helped, or if you have additional information questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/2001/make/toyota/model/corolla/2001_toyota_corolla_drive_belt_routing_diagram.htm "HOW TO":
Standard Rules to Removal the Serpentine Belt with an Automatic Tensioner:
1. Find the Tensioner(s). (See Diagrams on Link)
2. Using a Serpentine Belt Tensioner Tool, Or Wrench OR Ratchet, Rotate/Move the Tensioner USING THE AVAILABLE NUT (on the Pulley or Arm Base) OR the OPENING (3/8ths or 1/2 inch square opening) rotating the Tensioner Pulley/Arm - moving it away from contact with the belt and towards the area where the belt is not in contact with the Tensioner Pulley. The Tensioner is spring loaded, and is hard to rotate/move.
3. Remove the loosened belt off one of the other more easily accessed Pulleys.
4. DO NOT quickly release the Tensioner, but gently allow the Tensioner to rest in its closed position.
Standard Rules for Installing the Serpentine Belt with an Automatic Tensioner:
a. Pick a Pulley that is most easily accessed. This will usually be on top. This will be the last Pulley that the belt will go on.
b. Using the Diagram: Install the new Serpentine Belt on the remainder of the Pulleys....over, under, left right.
c. Using a Serpentine Belt Tensioner Tool or Wrench or Ratchet Tool: Rotate/Move the Tensioner Pulley/Arm "away" from Belt contact area on the Tensioner. This spring is pretty hard and with a new belt, it will be even harder to install. Rotate/Move this to as-close to the maximum allowed inorder to have enough slack in the belt to get it up and over the last pulley.
d. Using your other hand - Pull the Belt up and over the Last remaining Pulley.
e. Before releasing the pressure on the Tensioner, visually inspect the remainder Pulleys and the Belts' Positioning on them.
Feb 14, 2010 | 2001 Toyota Corolla
Replaciing serpentine belt on 2006 Toyota Corolla
You'll have to remove the engine cover under the bottom so you can position the new belt on the pulleys properly. Get a wrench or tensioner tool and turn the tensioner clockwise to relax the drive belt. Don't apply excessive force.
It's hard to draw a picture with words, but looking at the engine from the passenger side of the car, there are basically two top pulleys, two middle, and two bottom. The drive belt goes around the outside of the two top and two bottom, and on the inside of the two middle.
Oct 31, 2009 | 2006 Toyota Corolla
My serpentine belt broke
not to much a rachet or a wrench their will be one marked pulley that one will be movable (springy)you just move that one and slide the belt in place if not its a alternatooer adjustment
Jun 18, 2009 | 1996 Toyota Corolla
1994 toyota corolla alternator belt replacement
loosen the bolt that is holding the adjuster of the alternator. loosen the belt by pulling it and the alternator would slide in. remove and replace the belt.
do the reverse on installation.
remember to tighten all bolts of the adjuster and alternator after tightening the belt.
tnx 4 using fixya,
drcool
Sep 13, 2008 | 1994 Toyota Corolla
Serpentine belt
any repair shop will charge about .5 hours to replace. If your unsure about how to do it, don't. You will end up loosing more than your patience by trying it yourself
Jul 16, 2008 | 1998 Toyota Corolla
Lisle Serpentine Belt Tool & Accessories - Expanded Model Logo
296 people viewed this question
Top Lisle Hammering Experts
Robert Wooley
Robert Wooley
john h
Lawrence Oravetz
Are you a Lisle Hammering Expert? Answer questions, earn points and help others
