Question about Dell Inspiron E1505 Notebook
Dell Inspiron 5150 laptop rarely works on electricity but will charge battery when laptop is shutdown. When I turn laptop on, it goes to battery power. When battery is almost used up, I shut down, and let it charge again. What part is breaking as this is sporadic?
    President:
  • 2,600 Answers
If you are able to test the voltage at the tip of the charger unit and it has the correct voltage and supplied amps.....then I would say that the DC port on the laptop may be failing. The center of the jack which carries the positive charge to the motherboard can be damaged over time by normal use from the charger being plugged in and moved during normal everyday use. The problem may be alleviated by changing out the DC port.
Posted on Jul 12, 2010
Dell Inspiron 6000 won't charge
Since you have already replaced the battery and the laptop works with the AC charger, then probably the charge circuit in the system board (mother board) is bad. I have rarely seen an AC charger that will power the laptop but not charge the battery. 99% of the time, if it is not the battery, it is the system board.
May 05, 2010 | Dell Inspiron 6000 Notebook
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Power button pushed battery light blinks twice won't turn on
I have the same problem for my dell note book
This is how i solve it
Unplug your note book from any power source
then remove the battery from the Notebook for
30 minutes after 30 minutes put back the battery and reconnect your adapter to power source turn on the power
Feb 19, 2009 | Dell Inspiron 5150 Notebook
Laptop will not boot up on its own power.
check in your power options make sure settings are correct for shutdown and stanby ETC
see if battery is showing fully charged or not in your power options
If everything is okay for power options then you need a new battery
please let me know and don't forget to rate
thanx
Feb 16, 2009 | Dell Inspiron 1000 Notebook
Dell Inspiron 5150 Will not turn on......
had same problem, thought changing power jack would solve problem, but, it turns out the power supply is the problem,, works great with another dell ps
Jan 03, 2009 | Dell Inspiron 5150 Notebook
Dell Inspiron Laptops spontaneously shutdown often
sounds like the battery is going bad. how long do they run before they die?
I would recommend looking at the power conservation settings in the control panel and adjusting them to reduce power consumption. You should also lower the lighing level in the room so the stundents can reduce the brightness of the laptop screen...that is a huge power saver.
Nov 14, 2008 | Dell Computers & Internet
Dell Inspiron 5150 no power, no lights
it could be that the ports where you plug in the charger is damaged. if you have an identical or a known good battery that is charged, try to install that and check if it works. you need a motherboard replacement if the system works with a charged battery.
Sep 24, 2008 | Dell Inspiron 6000 Notebook
Can't charge battery or run off AC
You may have a problem in the DC charge circuitry. These parts are located on the moatherboard directly and can't be bought separately and repaired. You must send your Dell to a specialised service to have it fixed by them. Sorry, I can't see no other way for this problem to be solved.
Jan 20, 2007 | Dell Inspiron 5150 Notebook
Dell Inspiron E1505 Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
