Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
I have just put a 71 thrust motorguide trolling on my rig. I can not get my 24volt to work right it has 12v with 5speed & 24with 5 speed plus all the time. There is 24 volts to the foot control. I have change boat I had it on allison the allison had 4 wire red 1& black1 & red1 black 2 going to panel up front the plug only had three wire going to tm. On the skeeter has 3 wires going up front direct to panel that ties to the tm, I have 24 volts there but had to use jumper wire to get that .Please help Thanks BB
tripletauto
  • 1450 Answers
SOURCE: motorguide brute 567, 67 lb. thrust
you will probably find it is either a switch problem or your wiring this is a twist handle?
Posted on Sep 29, 2008
  • 323 Answers
SOURCE: Motorguide Trolling motor has low thrust in all five speeds
I have a 4 speed with 48 lbs of thrust. On mine, 1 through 3 will move me out pretty well, however, 4th is similar to an overdrive gear in a car or truck and is meant more for maintaining a speed with less draw on the amps.
I certainly wouldn't want to take off with it. I suspect it is the same with your 5 speed. The boat needs to be up to speed and then those two gears will maintain it, with 5th being optimal as far as low draw in amperage.
Posted on May 23, 2009
SOURCE: MotorGuide pro series 46 lb.thrust not turning smooth
Check the beaing locted where the inner shaft passes thru the outer tubing below top of motor
Posted on Sep 08, 2009
  • 24 Answers
SOURCE: I have a motorguide trolling motor and the front
With the top off take the six screws out and lift the cable and gear out. Next put your foot pedal at mid position. Then make sure the motor is pointed forward and reinstall the slider gear and the six screws. Last put the top on and make sure the arrow indicator is pointing forward and thats it.
Posted on Jun 29, 2010
  • 509 Answers
SOURCE: i bought a used trolling motor (motorguide brute
the black wire goes to - and the red goes to + for 12 volts. If you want 24 volts you need to add another battery and run a jumper wire from the - of the first battery to the + of the second battery and hook the white wire to the - of the second battery. Here is a picture to help you.
Posted on Dec 23, 2010
Why does my motor guide 50 trolling motor fuse
It depends on how much current the trolling motor is supposed to draw when set to 5. If it's more than 40 amps, then you need a larger breaker. If it isn't more than 40 amps, then your current 40 amp breaker is weak and needs to be replaced.
May 13, 2014 | MotorGuide Electrical Supplies
My motorguide trolling motor keeps tripping the 50 amp in line breaker every time I turn it on high speed. It is a 75 lb thrust digital tour model. When I take it out of the water and run it on high...
All motors will draw higher amperage with varying loads. Your hi speed motor winding has probably shorted some its winding's without having gone to ground. It probably needs to be replaced to get your hi speed back. I have run into similar problems in heavy commercial hydronic pumps. Best to have mechanic check it out. An OHM test with factory specs. will tell for sure.
Sep 04, 2013 | Electrical Supplies
I nned a motorguide 46 lb. thrust electric foot controlled trolling motor manual
Go to http://www.boats.net. Let me ask you a question, is it 5 speed? And if so have you lost some or all speeds but 5?. I so, them you need to take the lower unit apart and you will find solder laying in the bottom. You will see that the speed control coil wires at one if the terminals on the brush board has no solder. Clean it up along with the wires so that you see copper and re-solder. This is due to poor quality control on soldering at the manufacturer. When you re-assemble tighten the bolt 45-50 in-lbs only. No more.
Oct 02, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
May 22, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Motor guilde lll trolling motor
I have a motorguide trolling motor model 2600 #s/n 19409 can't find out what thrust it is
Feb 15, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Jan 14, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
Ian Summerfield
Ian Summerfield
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
