Question about Frigidaire FRS-26DR7D Side by Side Refrigerator
GE Side by side model#ZFSB23DRGSS evaporator coils freezing up on refrigerator side
HVACRH20
  • 237 Answers
SOURCE: Samsung Model No.RS2533SW Refrigerator
The evap coil freezing up is likely due to the defrost cycle not working. The little defrost t-stat looks like a little disc with wires coming out of epoxy. If that is swollen or the expoxy is popped up at all it's bad. You can check it for continuity if you have a multimeter. The next thing would be the defrost timer itself that is bad, the last and least likely item to fail is the heating element itself, you can also check it for the proper ohm value to make sure it's OK. http://www.partselect.com/Schematics/Maytag/SS50-8.gif
Posted on Dec 29, 2006
  • 87 Answers
SOURCE: Whirlpool s/b/s refrigerator - water not evaporating on freezer side - collects & freezes under bottom food bin
Did any of the repairmen replace the heater which is at fault or did all three of them change it? If it has not been changed then I would suggest that it should be. If it continues to be a problem then you can get drainline heaters added to the system but you would need to talk to a fridge guy before they wasted a journey. The other possibility is that the front cover is not inside the drain pan or a leak in the drain pan, and if you have an icemaker you could even get water coming from further up the cabinet. Either way I would suggest picking your favourite of the three and tell them that the problem is unresolved. Most fridge guys offer some sort of warranty on work that they do. Hope this is of some help.
Posted on Sep 11, 2007
applianceboy
  • 77 Answers
SOURCE: FRIGIDAIRE FRS22ZRGD2
you may need to clean the drain tube again. the only other place that water may come from is the ice maker if it is over flowing. this however would be very obvious. use some thing like a length of cloths line cable to "snake" the drain after you defrost it. the fastest way to defrost it is to use hot water and a turkey baister. good luck.
Posted on Sep 26, 2007
Amigaman
  • 248 Answers
SOURCE: GE sxs Not Freezing
See if freezer fan is running when the unit is on. If you hear no fan when it's running. You probably need an evaporator fan motor.
Also check for ice or frost build up around fan.
Posted on Nov 14, 2007
  • 213 Answers
SOURCE: ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
Posted on Nov 29, 2007
Model GSS25SGMCBS coil freezes.heater checkedout ok service man changed the circuit board for $312.After 3 days, same problem again. Freeze temp ok but refrigirator sectio quit working after coil freezes....
Control board is new, heaters ok, Check defrost thermostat and thermisters located on evaporator.
PC board not getting information to defrost properly.See site below
Also check the fill tube at ice maker . Iv'e seen these get loose and fill evaporator with water causing ice block
good luck
GE Refrigerator Repair Guide
Aug 16, 2011 | GE GSS25SGMBS Side by Side Refrigerator
My refrigerator will cool for about 2 weeks and then everything starts meltingand it stops cooling
your evaporator coil is freezing over due to either the defrost heater or thermostat on the evaporator coil are not working,you can check both of these components with an ohmmeter but the thermostat needs to be below freezing to test or it will show bad even if its good,theyre both behind the rear panel inside the freezer,if the evaporator is iced over you cannot get cold air to move
Apr 06, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Is the heater timer on ge refrigerators with computer boards, locayed in the computer board? does the whole board have to be changed also? the heater and the thermostat have been changed but, the...
There are four things that will cause this problem and they are the defrost thermostat, defrost heater, evaporator thermistor and the main board. This page will help http://appliance-repair-it.com/GE-refrigerator-repair.html
Also yes, the board is the timer.
Sep 14, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Top shelf of both regrigerator and freezer not working
i have a side by side refrigerator is all ice bihind the cover evaporator
Apr 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE refridge model GSS20DBMB WW freezer coils keep freezing up! I have replaced the door seals as an appliance center recommended. However, It did stop it from freezing up! we have to use a hair dryer...
Something has gone wrong with the defrost system. It could involve the defrost timer, the evaporator heater, or some of the wiring.
This problem would take some troubleshooting that most do-it-yourselfers would likely not be able to do.
Oct 18, 2009 | GE GSS20DBM Side by Side Refrigerator
Evaporator coil freezing, replaced main control
It is possible you have a defective fan motor in the condenser area or evaporator area. Sometimes when they become defective they will run for a while and just warm up and stop while the compressor continues to run. I learned that one on four costly returns to the home. The cost was to me not the customer. Thanks, Sea Breeze
Aug 05, 2009 | GE GSS25SGPSS Side by Side Refrigerator
Evaporator Coils freezing.
Hi, The most common problem is the defrost heater. It is attached to the bottom of the evaporator coil in a bracket.
If you have a meter, you can remove the element from the coil and take the two wires off. Checck the post on the element that the wirea attach to for continuity. If the element is good, it will have continuity to it. If the element is ok, check continuity on the bi-metal switch attatched to the top of the evaporator coils. It too must have continuity to be ok and it needs to be tested while still cold.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 20, 2009 | GE GSH25KGPWW / GSH25KGPBB / GSH25KGPCC...
I have a GSS20IEMAWW that the coils freeze up
Check the defrost heater located on the bottom of the coils. Short have a pretty solid short if using and ohm meter.
May 23, 2007 | GE GSS20IEM Side by Side Refrigerator
Frigidaire FRS-26DR7D Side by Side Refrigerator Logo
279 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
