Question about Linksys Wireless-G WRT54G Router
My linksys wrtp54g wont stop blinking. I have internet from the modem and when i connect the ethernet cable to the router it just blinks and I dont get any connection. I have tried the reset button... Turning it off both the modem and the router and still the same problem. I turn the firewalls off also
  • HaeRAy
    HaeRAy Jul 12, 2010
    Huh? It just blinks??? What just blinks??? There are a bunch of lights on that puppy and most are able to, ummmm.... 'blink!' Plz; Plug it in, wait 47 seconds then note and report the status of each or its lights (including the labeled names) as follows: On- Off- or Blinking (Fast/ Slow/ Steady/ Erratic is helpful info to include as well..) Thanks, RAy
    Genius:
  • 1,354 Answers
Hi
Configure the Router 1. Step 1
Open your web browser, type " http://192.168.1.1/ " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
Posted on Jul 12, 2010
RESET USERNAM AND PASSWORD
Resetting the linksys router in just six easy steps..
1. Turn on the router.
2. Reset the router, wait until the power light is blinking and then press and hold the reset button for 10 second.
3. Turn off the router and turn on again.
4. Wait for the power light to stop blinking, if the power light does not stop blinking, turn the router off, wait approx 30 second , and then turn it on again.
5. Connect the router to your computer, when it is connected to a computer with an ethernet cable, the ethernet port light will light up.
6. Connect the router to your modem, the modem is connected to the internet port is your computer. The router is connected to the modem.
If you are not able to reset the linksys router password then call linksys router support phone number 1-888-494-1155 (Toll-free) USA.
Apr 18, 2014 | Linksys Wireless-G WRT54G Router
Need to connect Linsys to motorola modem for wi fi usage
  1. simply unplug the router and the modem from their power source
  2. plug the power cable into the modem
  3. wait for the lights to stop coming on, until you see solid power and internet connectivity LED and an intermittently blinking activity light.
  4. now plug the power to the router and allow it to boot all the way up as well.
  5. no your internet should be workin. (the ethernet cable should go from the LAN port on the modem to the Internet port on the rear of the router, and any desktops should be connected beginning with the LAN 1 port and advancing as required)
Jan 08, 2011 | Linksys Wireless-G WRT54G Router
Cannot share my cable modem connection
You need to connect a router to the cable modem.  The router then gets an IP address from Comcast and provides a gateway between the computers connected to the router.
The modem expects to communicate with a single Ethernet device, and provides an IP address to the first device that provides a piece of data called a MAC address.  By placing a router in-between, the router gets the IP address that lets you communicate on the Internet.  It provides local IP addresses to the equipment connected to the local Ethernet and "routes" those to the Internet.  You can either hook your two devices into the router if it has enough ports, or hook you switch to the router and hook your PC and PS3 into the switch.
May 05, 2009 | Linksys EtherFast EZXS16W 16-Port Ethernet...
Internet connection problems
Sorry but that seems to be a pretty convoluted explanation. Here is how it should go.
Vonage unit connected to phone line(s) and cable modem. Linksys connected to Vonage box. Computers connected to Linksys.
Ethernet has a length limitation of about 300 feet before you need another switch (hub) or a repeater. Does your wire length exceed this?
Apr 20, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
WRTP54G not routing
turn the power off for 5 minutes then try.
if still pro let meknow.
Jan 05, 2009 | Linksys Wireless-G WRTP54G Router
I have linksies router and 2 wire modem will they work together?
If the Modem has an ethernet port (looks like a large phone plug like the ones on the router) connect an ethernet cable from it to the "internet/wan" port on the router. If it doesn't there isn't much you can do.
Dec 30, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Connecting to internet
Ok, cable (coax) comes in from wall and attaches to modem. Ethernet cable goes from modem to WAN Port of router. You may have to reboot both devices to ensure that your modem (internet service provider) assigns IP address to your router. If PC is close enough, attach new ethernet cable from one of the 4 ports on your router down to your PC's ethernet adapter. (where your modem used to plug into). Router will now assign an IP address to your PC and you should be able to access the www.
Good Luck and let me know if you have any more questions.
Jul 13, 2008 | Linksys Wireless-G Broadband Router
Linksys reset
You dont need to connect your computer to the router to reset it,, There is a small push button on the router , unplug it and press the push button for one minute with a pen and thats it your done.
BTW the router came with and ethernet cable, connect one end of the cable to your pc and then oter end to the lan port (lan1) on the router. thats how you connect the two
Jul 10, 2008 | Linksys Wireless-G WRTP54G Router
Setting up the BEFVP41 Router with a Cable Modem and a Dynamic IP Address
Connecting the Router and the Modem 1. Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. 2. Shut down the computer, and unplug the power cables to both the router and the Broadband modem. 3. Disconnect the Ethernet cable from the computer and plug it into the Internet or WAN port of the router. 4. Take the Ethernet cable that came with the router (or any another available cable) and connect it to the computer. Then, take the other end of that same cable and connect it to Port 2 on the back of the router. 5. Plug in the Broadband modem's power cable and wait for all of its lights to stop blinking. 6. After the lights on the Broadband modem stop blinking, plug in the router's power cable. 7. Start up the computer. Obtaining the PC's MAC Address Windows 98SE/ME 1. Click on the Start menu, then click on the Run option. 2. When the ?Run? window opens, input winipcfg into the ?Open? field, then click on the OK button. 3. The ?IP Configuration? window should appear, select the Ethernet Adapter that the PC is using from the drop down list. 4. Make note of the ?Adapter Address? which is the MAC Address. Windows XP/2000 1. Click on the Start menu, then click on the Run option. 2. When the ?Run? window opens, input cmd into the ?Open? field, then click on the OK button. 3. When the ?MS DOS Prompt? appears, input ipconfig /all then click on the [Enter] key. 4. Make note of the ?Physical Address? of the Ethernet Adapter (normally ?Local Area Connection?). Accessing the Setup Page 1. Open a web browser such as Internet Explorer or Netscape. 2. When the browser window opens, go to the Address bar and type in the router's IP Address and click on the Go button (192.168.1.1 is the default IP address of Linksys Routers). 3. A window will appear prompting for a ?User Name? and a ?Password?. Leave the ?User Name? field blank, and type in the router's password and click on the OK button to login (admin is the default password). 4. The router's web-based ?Setup? utility should then load. Cloning the MAC Address The steps for configuring the MAC Address Cloning feature of a Linksys router vary depending on the firmware version the router is currently using. From the router?s ?Setup? page, locate the Linksys logo in the upper left-hand corner of the page. Follow the instructions below depending on which logo matches your specific screen: If the logo matches the image above ("Linksys - A Division of Cisco Systems, Inc."), follow these steps. If not, skip to the next logo version. 1. From the ?Setup? page, click on the MAC Address Clone sub-tab. 2. In the ?MAC Clone? section, set the option to Enable. 3. Click on the Clone Your PC?s MAC button. Once this is done, the ?User Defined Entry? will show MAC Address of the Ethernet Adapter of the computer you are using. Verify this address with the ?Adapter Address? or ?Physical Address? observed in earlier steps. 4. Click on the Save Settings button. Then, click the Continue button if prompted. If the logo matches the image above ("Linksys"), follow these steps: 1. From the ?Setup? page, click on the Advanced tab. 2. When the ?Filters? page loads, click on the MAC Addr. Clone tab. 3. When the ?MAC Address Clone? page loads, enter the the ?Adapter Address? or ?Physical Address? that was observed in earlier steps. 4. Click on the Apply button. Then, click the Continue button if prompted. Power Cycling 1. Shut down the computer. 2. Unplug the router?s power cable. 3. Unplug the Broadband modem?s power cable. 4. Wait for 30 seconds. 5. Plug in the Broadband modem?s power cable and wait for its lights to stop blinking. 6. Plug in the router's power cable once the modem?s lights stop blinking. 7. Finally, start up the computer and test the Internet connection.
Feb 16, 2006 | Linksys EtherFast Cable/DSL VPN Router...
Linksys Wireless-G WRT54G Router Logo
138 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
