Question about Samsung HP-R4252 42 in. Plasma HDTV
Samsung model hpr4252x/xaa, how long should a plasma tv last, ours is 4 years old and we now have a black screen, this is our first plasma, do we get it fixed or do we need to buy a new one?
5 Suggested Answers
  • 103 Answers
SOURCE: samsung hpr4252x perfect picture in
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Posted on Mar 05, 2008
SOURCE: Top half of screen going black.
I've seen this or something similar to this problem on an old lcd screen. The bulb haden't burned out but the system was no longer getting proper 5 volts to the processor chip that processed the image. I ended up desoldering the voltage regulator and soldering a new regulator in it's place it was one with the same amperage so I put a heatsink on it to reduce the chance of another failure.
Posted on Apr 11, 2009
  • 22 Answers
SOURCE: Samsung LCD tv hpr4252x/xaa not working
Did you check the video plug?
Posted on Jun 14, 2009
  • 6 Answers
SOURCE: Have sound but no picture on Samsung plasma
It's a pretty common problem. The no picture but sound problem is usually the y sustain board. I've replaced 2 on mine now. The 680uf 35V capacitors usually are bulging because one of the power transistors went and took them out. This has happened to both of the y boards I had. One time the failing y board took out the buffer boards too, and once it did not. The fix is super simple and anyone with even the most rudimentary knowledge of computers or electronics can do the labor yourself. You should do the simple stuff first by just doing a quick test with a multimeter. Just check the power coming to the y board. After that you can just remove the y board by removing 3 cables and like 3 screws. Plug in the new board and it's done! You can source the parts from a place like shopjimmy or discount merchant. 3 boards were like 200 bucks. 1 board is like 100 bucks. Labor took me 15min. Think about that the next time an electronics repair place charges you 1000 dollars. Of course they check everything (Yeah right) and warranty their work (I don't) but if you check the service manual it states that this is the most common repair. Look for the Canadian manual online. Hope this helps!
Posted on Feb 23, 2010
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Is there any way to buy a CPU for HLR5667WAX/XAA? How to replace it?
If you TV is 9 years old it is questionable whether further repairs are economically worthwhile.
Jun 05, 2014 | Samsung Cooling Fan Set for HLR5667WAX/XAA
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
I have a Samsung plasma over 5 years old. power
The x-sus or y-sus panel wil be the fault.Check the fuses on these panels ,if one of the fuses is open then that panel must be replaced.Not verry cheap to replace.
Nov 02, 2009 | Samsung HPN4239 42 in. Plasma HDTV
Samsung TV , black screen
Check for the timer settings if possible reset to default......
Sep 28, 2009 | Samsung DLP HL-P5663W 56" TV
Red pixel cloud in plasma black
THIS IS THE START OF THE PLASMA GAS RUNNING OUT...PLASMA TVS ONLY LAST 4 TO 5 YEARS THE GAS JUST BURNS OUT....LCD TVS LAST ALOT LONGER UP TO 10 YEARS..
Dec 29, 2008 | Samsung PS42P2S 42 in. Plasma Television
Samsung hpr4252x perfect picture in
Mar 05, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung HP-R4252 42 in. Plasma HDTV Logo
74 people viewed this question
Jerry Greenberg
Jerry Greenberg
