Question about HP Digital Sender 9250c scanner Printer
My scanner keeps jamming even though I took all the paper out
  • 38 Answers
Try loading 1 paper only, keep an eye to see where it jams. It might be the roller or the pad. You also might have a a paper clip or some object in the paper path.
Posted on Jul 13, 2010
jackboy
  • 2985 Answers
SOURCE: Red Paper light keeps flashing
Try to find thge combination of buttons that reset the printer. there are many possiblities due to the modles - but try pressing any 2 and whilst holding them down switch off and then on again. Also this utility could proce use full. When it is loaded -right click the task bar icon. www.ssclg.com
Posted on Oct 02, 2007
  • 60 Answers
SOURCE: My printer has stopped feeding the paper - It
Please check the paper feed motor connector, if ok then check the supply from PCB.. 12V regulator IC to be replace..
Posted on Jul 10, 2009
komguy
  • 2306 Answers
SOURCE: I keep getting a paper jam message even though the
There's a sensor arm under the white guide plates behind the platen roller that gets bent or broken when you remove a jam, especially if you pull paper backwards to remove a jam. If you can't straighten it you need a shop to replace the sensor arm.
Posted on Sep 14, 2009
SOURCE: Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Posted on Feb 01, 2010
WonderTech
  • 268 Answers
SOURCE: Why does my 2040 Paper light (Red) keep flashing
There are several possibilities with too many to type here so, here is a link to the Brother troubleshooting page that gives several causes for the flashing red light. When you get to the page, scroll down until you see the "lashing "paper" light.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000100/000070/faq000170_005.html?reg=us&c=us&lang=en&prod=hl2040_all&Cat=11
Hope this helps.
Posted on Aug 09, 2010
Screen reads paper jam even though there never was a paper jammed. I tried turning the printer off and on but the same message still appears. Also the cancel ! keeps flashing even though I cancelled the...
Hello Sande.
Try cancelling the printer job via the control panel in Windows.
Also open covers, including the top flatbed half, to view the paper path.
There may still be a stray piece stuck in there somewhere.
Does this help?
Clive.
Nov 18, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
My hp photosmart c4780 won't align because is keeps saying that the alignment plot in the scanner is skewed
If you have had paper jam and not replaced the rear paper grey plastic retainer correctly or somehow it has become loosened the paper will twist on entry and the printing will be askew. Sometimes not loading paper. It will then also not align when replacing cartridge. Had this problem, took out the retainer that has two plastic points that should locate in the retaining holes and pushed it back. Paper jam, printouts and alignment was then fine. Took me months to figure out as it was printing, just not very straight
Jan 24, 2012 | Office Equipment & Supplies
JAM P007
It looks like you're stuck. I would check for any fragments of paper jammed in there, even though you can't see it. Doesn't mean that it's not there.
I could not find your flatlbed Scanner listed on the website.
I would schedule service with canonusa.com by calling 1-800-OK-CANON.
Aug 02, 2010 | Canon imageFORMULA DR-X10C Flatbed Scanner
The scanner won't work because it is detecting a paper jam which is not there
There was this one time that my friends printer states that there's a paper jam even though there's no paper there.
What was actually there, is just a paper with length of roughly half a centimeter and width of roughly 3mm is in the printer, stuck on something which I assumed is one of the sensors. Removed that, and no more paper jam.
Apr 19, 2010 | Panasonic KV-S2046C Pass-Through Scanner
Canon Pixma MP150 keeps blinking E 3 saying there is a paper jammed even though there's no paper in the printer. I found a little screw inside, could this be the problem?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-5
Aug 02, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam in dell photo 964 . Took all the paper
Hi there
i have the exact same printer and this is what i did even though i took out all of the paper ( i thought) i got a flashlite and i opened up every thing that i could and then i looked and wow lots of little pieces of dust and some paper too so i removed all of that and after powering it up again it worked just fine so you may want to try that ok hope this helps solve your problem.
best regards mike
Mar 05, 2009 | Dell Photo 964 All-In-One InkJet Printer
Message shows paper jam even though there is no jam
take all the paper out make sure there is no dirt or dust in the corners,then unplugg the machine for 30 sec. power back up and reload the paper
Feb 26, 2009 | Office Equipment & Supplies
Paper Jam 2
Most probably you took a paper sensor out of position when removing the first jams. In your unit, the paper sensors are connected to the main board or power supply board. If the equipment is under warranty, any authorized service center will gladly replace it for free.
Oct 03, 2007 | Samsung SCX 4521F All-In-One Laser Printer
HP Digital Sender 9250c scanner Printer Logo
300 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
