Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Cannot get router to work
I run the cd as instructed but at the end it always says cannot read the router or something like that. this is a router for wireless internet correct all I want is to use my laptop in other rooms of my house.
  • hollyroller Apr 29, 2008
    router goes through everything and at the end it says the router can not confirm connection to the internet
    Sergeant:
    Champion:
  • 427 Answers
Since it is a new router, you are under warranty. Just call linksys and they will have u set up in link 20 minutes.
Posted on Apr 20, 2008
Help with d-link router please
Thanks, konafaa. Sometimes the best procedure is to start over from the beginning, as you discovered.Best regards!
Apr 19, 2012 | D-Link Computers & Internet
How can I get my Belkin router to read my Seagate storage device so that all computers in the house can access said Seagate storage device?
1) Turn off your wireless router and unplug the external hard drive you want to make wireless.
2) Plug an Ethernet cable to the "Network-attached storage" device, and the other end of the cable to an available Ethernet port on your wireless router.
3) Connect one end of the USB cable to the wireless router's available USB port and the other end of the USB cable to your "External" hard drive.
4) Turn on the both the Wireless router and the External hard drive. Make sure that your Internet connection is still working.
5) Insert the installation CD and run it on your computer. Follow the installation instructions and install any utilities related to your external hard drive. There may be special utilities provided for flash drives that are not needed for hard drives.
6) Create a login name and security password for the "NAS" device during the setup process. When the installation process is completed, you will now be able to use your external hard drive.
Apr 10, 2011 | Computers & Internet
How to install the router
You should first install the CD that came with the router. When it comes up, it will guide you through the installation process. At the end of the installation, you will be instructed to plug the router in, and connect it to your computer. At this time you'll be able to select a security code to limit access to your router.
Refer to the instructions that came with the router in case you have any problems. It's not as hard as it seems, and you should be up and running within maybe 15 minutes.
Good luck, and hope this helps.
Oct 29, 2010 | Belkin (F5D5231-4) Router
Links stopped working when I tried to set up my new cumputer
If you have reset the router then you must start afresh as if you are connecting a new connection. You must be having the CD of the software and the instructions which came with the router. Load it on the computer and follow the instructions. It is simple.
May 15, 2010 | Linksys Wireless-G WRT54G Router
INSTALL CD
No install CD needed with valid working internet with modem. First you need to turn off your computer then connect the working hsi modem to the Netgear router with the ethernet cord (looks like a thicker telephone wire) connect the ethernet cord from the back of the modem to the first single port on the Netgear not the ports labeled 1-4. Then with another ethernet cable snap one end into one of the 4 ports available and the other end snap into your computers ethernet port. Then unplug the MODEMs power cord for 30sec plug it back in wait for modem to boot back up with all of its lights and turn the computer back on. After install is finished you can now go and download your routers firmware from Netgear. In your address bar where it reads http://.........go ahead and highlight this and backspace it all until it clears to blank. Type in 192.168.1.1 and then hit enter. A window will pop up asking for username and password. For username type in "admin" for password type in "password" this is default and will always work unless someone has changed the username and password already on your home network, in which case contact netgear support. But if it does work the you will get Negear Smart Wizard. Here is where you can click on "Setup Wizard" and follow the prompts to download latest firmware and then Finished. Close down the netgear page and happy wireless internet surfing.
Apr 25, 2010 | NetGear WGR614 Wireless Router
Linksys router will not connect to internet
The modem looks like a cable modem from what I have found. You should press the small reset button on the back of the router for about 3 seconds and it should go back to factory settings. Connect the router to the modem and unplug power to the modem, then power it back on and the modem should recognize the router. If this works make sure to login to the router and set passwords and security to something other then the defaults. The Linksys routers usually are addressed at 192.168.1.1 with a default username blank and password of admin. Good Luck
Jul 23, 2009 | Linksys Wireless-G WRT54G Router
Cannot finish installing
It means you have to plug in your computer to the router through a ethernet cord. Most computers have one, and on the back of thats router has 4 ehternet female ports. Plug it in, and run it again.
Dec 02, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless G Router Set up
I ended up loading the router setup cd onto another laptop, and it worked fine. I still don't know why the first laptop had the error code, but they now both, work perfectly fine. Thanks, anyway.
Sep 06, 2008 | D-Link DI 514 Wireless Router (DI-514)
Needing help installing new Rangemax wirelss router
Hi!
Try to re-run the cd but if it will still not work, another way of configuring the router is via web interface.
You can download its userguide at NetGears web site.
Hope this helps!
Apr 13, 2008 | NetGear RANGEMAX WNR834M Router...
Help with netgear rangemax next wireless n router
use the connected pc, its always best to use connected pc, then test using wireless laptops
Oct 18, 2007 | NetGear RANGEMAX WNR834M Router...
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
21 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
