Question about Sansui DTV3200 32" TV
How to program a universal remote for the Sansui
When I tried to program a universal remote for the Sansui DTV3200 32" tv the channel up/down buttons do not work.
    Problem Solver:
  • 13 Answers
It may mean that the code you entered is incorrect. Try these: 0135, 0310 and 0394.
Posted on Jul 14, 2010
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
Dec 16, 2015 | RCA Televison & Video
I have a sansui flat with build in DVD but don't have a remote the DVD will load but when push play it says operation not possible with disk what is this do I just need a univ.remote
First, check which input you have the TV set on. There may be an Input button on the side of the TV. (On the SLEDVD197, the button just below the DVD Eject button.) Just press Input and use the Channel Up/Down arrows to navigate the menu to change to the DVD. Press Input again to Enter the selected option.
With the TV in DVD mode, try pressing Play again. If you still have the error, check the region code for the disc. The "Operation not permitted" messages is usually that something on the disc is locked. Frequently, it's the result of using a different region code disc than the DVD player knows how to interpret. Try a different DVD.
If your TV doesn't have the Input button on the TV, you absolutely need a universal remote. However, you will want one that can match the TV/DVD button, the Input/Select button and the Menu button. Usually this requires a higher end remote; you also need a remote that was programmed at least 6 months after Sansui released the TV. If you do have the Input button on the TV, a universal remote may make using the TV easier.
I hope this helps.
Apr 13, 2015 | Sansui Televison & Video
Code for universal sony remote sony-v201
Hello
Sorry to say that Sansui is not listed to Sony V201 remote control. Anyway I'll give you some three digit and four diit conds for Sansui. I'm not sure will it work, but try these, sometimes you may get.
Three digit universal remote codes for Sansui are:
135/ 136
Four digit universal remote code for Sansui TV/VCR combo is
0310
Four digit universal remote code for Sansui TV are:
0135 0310
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
NOTE: Switch OFF and switch ON your combo with its FRONT PANEL POWER ON-OFF SWITCH each time before trying an other code.
Hopes you will be helped.
OK.
Jan 27, 2011 | Sansui COM312AD 13" TV/VCR Combo
I have a sanyo remote and a sansui tv how do i program the tv
Hello
I don't have a code for Sansui TV to be programmed with Sanyo remote control But hava a philips Universal remote model which can be programmed for Sanyo TV and has its codes.
Remote Model ===> Philips CL 034 Universal Remote Controller.
Codes
0115 0632
And herealong with I sends some universal remote codes, that you can check it for.
Four Digit Universal remote code for Sansui TV are
0135 0310
Three digit universal remote code for Sansui TV are
135/ 136
Direct Code Entry
Nov 25, 2010 | Sansui Televison & Video
Im having problems programing my sansui flat screen tv when i program my rcr311b universal remote it works up untill the point when the tv turns off after pressing the play button and releasing the reverse...
first wat are u trying to do,,,,,,in mind....wat way,,,,,to do wat....try going to get thing that can remote w/remote to do......reverse the plan of mind,,,,
Aug 27, 2010 | RCA RCR311B Remote Control
Trying to program my sansui tv with the cablevision remote control. unable to find codes
You have to do the universal way which involves:
1) turn on tv and dvr
2) press tv button + select, hold till the io button stays lit (5seconds)
3) once io button is lit, press up and down channel buttons and flip through them until the tv turns off.
4) press mute, this should turn the tv on.
5) press tv button to save the settings (turn off tv)
Oct 05, 2009 | Sansui DTV2760 27" TV
Manual buttons on set will only accept 3 channels
found solution by holding down both volume buttons at same time which enables on-screen menu allowing to select channel auto program
Dec 07, 2008 | SansuiS3275 TV
Sansui channel program w/o remote
You should be able to just use the channel buttons on the TV itself. Go lower than 1 and it should go to video 1 or 2 ect. If this doesn't work there should be a menu button on there too. You use the channel buttons and volume buttons to move the cursor once you get into the menu.
Hope that helps.........
Jun 30, 2008 | Televison & Video
NEXXTECH 2 IN 1 BIG BUTTON Universal REMOTE CONTROL TV code for sansui tv
Have a solution for you.Turn your TV on then Press and hold 'P' on remote until light stays on. Press device to be controlled (TV/Cable) light will flicker but stay on. Now keep pressing channel up (up to 300 times) until device changes channel. Then press Enter to save code. Hope this helps
Jun 08, 2008 | Big Button TV Universal Remote
Sansui DTV3200 32" TV Logo
222 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
