Question about Maytag MSD2456G Side by Side Refrigerator
Maytag refrigerator model MSD2456DE has water in the ice maker tray which has frozen but will not eject from tray. The wire bail stuck half way between the on and off position and can not be moved.
  • Maytag Master
  • 43,501 Answers
Here are some basic tips for ice maker troubleshootingmaytag refrigerator model MSD2456DE has - 2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Jul 13, 2010
How do I trouble shoot an ice maker on a whirlpool frig, model GI6FARXXY07. The water dispenser is working, but the tray is not filling.
On the back section inside the cardboard cover there is a dual solenoid operated valve that when energized by buttons on the front of the refrigerator either dispense water, (which appears to work by your descrition) and the other opens to fill ice maker tray. It sounds like the ice tray side is not enerzing or does not work. If you take your model number and go to Searspartsdirect.com you can order the replacement valve and get the system back in operation.
Before I trash a potentially good working dual valve, make sure someone has not turned the on/off switch on the ice maker and/or the bin full bail (if it has one) is in down position. The bin full bail looks shiny metallic and rotates down to the automatic position. When a batch of ice harvests, they puch up against this bail and will halt production when the bin gets full. Once lowered because of ice usages, the bail lowers again to start another batch of ice.
Hope this helps
Dec 08, 2014 | Whirlpool Refrigerators
Ice maker not working.
If your water tray was empty check the water supply to the fridge .
you shouldn't fill it manually.
\if the water supply is turned on, then the operating solenoid that allows water into the tray is faulty.
Whoever repaired your fridge should be called back immediately.
Dec 02, 2014 | Refrigerators
Where do I find the ice maker inlet water valve or solenoid? The valve on the back of my fridge has only one hose going to both the water dispenser and ice maker and the water dispenser works fine.
Since there is water that flows to the water dispenser, the water valve is working. Now, there's a spout that water flows from to the icemaker tray. Look for it. It's located on the back wall inside the freezer and maybe behind the icemaker tray. Check and see if it's frozen. If so, defrost your freezer by turning the temperature gauge to off position. Wait a while until it's defrosted, then turn it back on.
Next, make sure that the metal wire is in down position.
If that doesn't work, your icemaker maybe defective and needs replacement.
Nov 01, 2014 | Maytag MFI2665XEM Stainless Steel
Ice maker inop
Water valve for ice maker may be bad. there are two valves with one supply line, one valve controls the water dispenser and one for the ice maker. you can ohm out the solenoids, it'll ohm if its good and won't if its bad
Dec 11, 2013 | Maytag Refrigerators
The ice maker wont make ice
If the ice maker is filling, but not ejecting the ice into the bin, then you first need to make sure that you have power to the unit. If the water is not filling the ice tray then the first thing you need to do is to make sure that water in getting up to the two zone value (normally in the freezer door next to the dispensor). It it is getting there then you need to check the sensor for the ice tray.
But first completely defrost the unit and make sure the line is not frozen to the ice maker.
Jun 14, 2011 | Maytag Refrigerators
Maytag side by side, msd2456de will not make ice, I have water that dispenser works fine, I believe freezer is cold enough what could be the probem?
If water is not getting to the ice maker the fill ice maker with tap water. Wait until it freezes and dumps and then replace the dual water control valve on back near floor. Sea Breeze
Jul 20, 2009 | Maytag MTB1504A Top Freezer Refrigerator
Metal ice maker arm is stuck midway. Will not produce ice
The small metal arm that raises as the ice fills in my GE side by side with water and ice in the door is stuck. Will go all the way up but only half way down. No other obvious issues. Have felt inside the little tray to be sure nothing was jammed or frozen.I need help !!
Jan 07, 2009 | GE Refrigerators
make sure the wire rod on the ice maker is in the down position in order for it to make and release the ice
Dec 13, 2008 | Maytag MFD2560HES Bottom Freezer French...
Ice Maker Infrared light doesn't light
Each mold tray has a heating element that is turned on to free the ice cubes from the mold tray and allow them to fall into the ice bucket when the tray is rotated into harvest position. Sounds like that is not being turned on... or is defective..
Sep 18, 2008 | KitchenAid KSRG25FK Side by Side...
KITCHENAID MODEL KSRJ25CNST-00 FRIDGE QUIT MAKING ICE WITH OUT ANY WARNING. WTER IS WORKING.
I have this model and it has stopped making ice for two different reasons. These solutions may not fix your particular problem, but they worked for me.
Problem #1: the water inlet to the ice tray is frozen shut.
Solution #1: Raise the door that hides the ice tray. The water inlet is the black rubber nozzle on the right-hand side that points down into the ice maker. Squeeze the rubber nozzle between your fingers to break up any ice that may have formed inside the nozzle. This will clear the water path into the ice maker. Lower the ice tray door.
Problem #2: an ice cube is stuck in the ice tray.
Solution #2: Raise the door that hides the ice tray. Look for any pieces of ice that were not completely ejected from the ice tray - they are usually partially ejected and are very easy to see. Carefully (but it may require a good deal of force) remove ice cube from tray. Lower the ice tray door.
I hope this helps.
Aug 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Maytag MSD2456G Side by Side Refrigerator Logo
459 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
