I purchased a used Alen mobile air conditioner yesterday. It's model C360. It worked until about 5 this morning, then the water full light came on and a code E5 was flashing. What does that mean? How can I drain the tank. I had the tube attached to the back,but it did not drain.
    Guru:
  • 528 Answers
Hi. Might be the sensor is having a problem. Here is the replacement part for the sensor. Click here. Make sure first that the tank has no water. if there is no water, it could be the sensor that is having the problem.
Posted on Jul 12, 2010
  • c_paetsch Jul 12, 2010
    We were able to drain the water using the lower drain, which is constant draining and does not use the pump. Is there a way to clear the error code? Or, does that mean there is still a problem? How hard is it to change the part? My husband is an industrial maintenance man and should be able to replace the part, if the code can't be cleared.
  • Archie Cruz
    Archie Cruz Jul 13, 2010
    if the water is constantly draining then the problem is the sensor. You need to replace that. It could be a factory defect since you just purchased the unit. Have Alen Technicians replaced that one for you. Opening the unit on your own might void the warranty.
    All the best.
P2 code is on Alen AC portable unit. Have emptied tank, unplugged, reset and still have P2 code on.
I am not completely familiar with these units but I believe they use a float to determine condensate levels. This float may be stuck in the raised position.
Sep 13, 2014 | Alen C360 Portable Air Conditioner
Alen Portable Air Conditioner stopped auto draining water how to fix
The drain is most likely plugged with dirt, clean out the drain and the sump
Jun 30, 2017 | Alen C475 Portable Air Conditioner
I bought a Duacraft Mobile Air Conditioner 8000 last summer, today I came home to find the floor soaking wet, no warning light came on, I can't locate where particularly on the unit the water us coming...
inside the air conditioner there should be a tray for catching condensation fro the coil. it should be full of water. the water warning light on your model is at the top left on the temperature panel watch for it as this has happened to me several times as well.
Jun 15, 2011 | Heating & Cooling
Yesterday, I was texting my boyfriend... I was in the bath tub, but I was drying my hands off onto a towel... I didn't think much of it, because my phone has been dropped into the dogs water bowl by...
Try this :
Bring a hair dryer ,then remove your battery and sim card,then turn the hair dryer on (the hot air)
make the hair dryer focus on the phone from the battery side becuase there are some holes wich the
hot air can get inside the mobile and dry the mobile hard ware.
Make the hair dryer focus on the mobile for 5 minutes but be careful and make a distance between
the hair dryer and between the mobile to avoid damage the plastic mobile case becuase of hot air.
After five minutes turn the hair dryer off and wait until the mobile gets cold,then turn it on
This way is effective 50% to 90 %
If your mobile worked that means congratulations.
If it worked but not 100% that means there is improvement and keep drying it by the hair dryer as
i explained before,,,every dry for 5 minutes only.
But if it doesnt work at all ...that means your mobile needs a hardware repair and you have to send
it to a mobile repair store.
Jun 03, 2011 | Cell Phones
The unit is not cooling the room. Water is not draining out the water hose.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 17, 2010 | Alen C400H Portable Air Conditioner
My c360 model hasn't been cooling the room like it used to. I don't know what the problem is.
First thing to check is a dirty filter. Maybe a dirty coil behind the filter. Do you have good air flow?
Jul 08, 2010 | Alen C360 Portable Air Conditioner
The E5 code is on, emptied the water tank; still on
AC Water Level Sensor for C475 and C360 Alen Portable Air Conditioners This is a replacement water level sensor for the C47store.alencorp.com/product-p/acwaterlevelsensor.htm. Check out this sight. Good luck
Aug 31, 2009 | Alen C475 Portable Air Conditioner
We own a Jenn-Air JDB7900. This morning the
More then likely the washer control panel has failed.
Apr 24, 2017 | Jenn-Air 24 in. JDB7900 Built-in...
How to release water from unit
http://www.manualnguide.com/dl/8197/
Here's the manual. There is a tank inside which is accesed by removing the panel. Remove this tank to empty the condensate.
May 27, 2009 | Alen C360 Portable Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
