Question about LG 26LX2D 26 in. LCD HDTV
LG flat panel Model#26LX2D. Power supply took 18 min. to power up. Main board leds show voltages are coming up, then they fade out. Even standby 5 volts. When the set turned on, the picture had a fine zigzag, and an orangey sunset had blotchy pink and blue toned areas. I came across a comment that the p.s. had this kind of prob., but do you think the main is screwed, too?
  • dachshock Jul 19, 2010
    Azraelsrl, thanks for the second oinion. Changing the p,s.u. was my thinking too. Im the only repair dude in this town of 1000.
  • LG Master
  • 11,800 Answers
No, all points to just a failing power source, the image problems can be caused by the undervolting of the processor. But the only way to know for real is to replace it and see that the tv is doing.
Posted on Jul 13, 2010
How does the standby voltage on the mainboard of a VISIO E420-A0 LED TV turn on the main voltage on the power supply board. THX for any help you can provide.
Sounds like you have main board failure, you can use a 1k ohm resistor and jump between the standby pin and PSON and the set should power up if the main is bad. Normal voltage at the PSON pin is 3.4 give or take a couple tenths of a volt on your set
Mar 25, 2018 | Televison & Video
Tip
Tv problems lg and vizeo
Power Issues Troubleshooting
*NOTE* LG & Vizio TVs must be plugged in for 5 minutes before it will turn on*
1. Inspect ALL Ribbons and connectors. Any tears or bad connections between boards must be replaced FIRST
2. If you have any of these boards, it should be the first board to be replaced
A) T-Con Board - Video Problems (No Video with standby light on, audio but no video, grainy, distorted, or color problems in screen)
B) X or Y Buffer Board (Plasma TVs only) - Standby light is on but no power
C) Backlight Inverter / LED Driver - No Video with standby light on
3. Main Video Board
- Either video or audio does not work (if no T-Con in TV. If audio but no video it is T-Con)
4. Power Board - No power AND standby light does NOT turn on. If standby light is on try other boards above
5. Panel - No power, distorted picture, lines, slow motion, half screen, faded in / out. Panel problems are usually not worth replacing the panel.
on May 22, 2015 | LG Televison & Video
I have a TV that shows power on (red light on front of TV), but nothing on scree. TV model is LG 42LN5300-UB
Check the various voltages coming from the power supply board and see if they are all ok, there is a legend on the power supply board to show what voltages are at what pins on the connectors,the 5 volt standby we know is good as long as the set has sound, but check the others
Nov 08, 2017 | LG Televison & Video
POLAROID P40LCD12 SCREEN AT BOTTOM COMES ON BLUE FADES THEN GOES GREEN ABOUT 5 INCHES LOST ON BOTTOM TV WORKS OK BUT THE SCREENS STARTS BLUE ABOUT 5 INCHES FROM BOTTOM THAT FADES AND TOP HALF PIC OK BUT...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 02, 2017 | Polaroid Televison & Video
I have a LG LED TV 55LS4500UD that no longer works after a storm. It won't turn on and no standby light. I have pics of the circuit boards. I would like to know which board to replace?
3. Main Video Board
Apr 11, 2016 | LG Televison & Video
LG 50ln5200-ub led TV . Has no picture but great sound . What is the problem ? I did the flashlight test and can see the faint picture which tells me the backlighting is out . This tv model is a Black...
usually bad power supply, Where did you source your part? return/exchange it. Bad LEDs/ possible but not as likely, Tcon working if you can see images with flashlight. You must also have backlight on signal from main board ,check for 3 to 5v on labeled connecter on power supply. UPDATE---47" & 50" LN series. This model has had LED problems if your TV acts as described by Mr. Hughes in is answer to this problem you have bad LEDs
Feb 16, 2015 | LG 50 Inch LED TV 50LN5200 LN5200 Series...
My Sony Bravia HX8/46 will not turn on, I check all the power going to it and it all works. Is there something I can do?
Is the standby led on the front lit. If not likely the problem is with power supply. If the standby led is on does it go off when the power button is pressed? Does the led blink. If so count the blinks and get back. The power supply provides an standby voltage to the main board. If the standby led is lit then this voltage is present. When the power button is pressed the micro sends a turn on voltage to the power board. Normally the power supply will respond and all other voltages needed to operate the set will come up. if a component is shorted the micro will not turn on the power board and will usually give a failure code via the standby led.
May 31, 2013 | Televison & Video
LG model 55lh40 no picture no sound
check your standby voltage and make sure it is coming up standbys come from the power supply board and if they are present your main board is bad or the main power supply is not working
Nov 27, 2012 | LG 55LH40 55 in. LCD HDTV
My tv set automatic video/picture will disappear after 5 min but sounds remain. i off the tv set then on again but after 5 min it dis appear again pls help tnx a lot
you lose brightness but sound remains?
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.
Mar 31, 2012 | LG 32LE5300 Widescreen 32 in. HDTV
Lg lcd module le5300
A general answer:
ISSUES:
Answers to issues:
Mar 24, 2012 | LG Televison & Video
LG 26LX2D 26 in. LCD HDTV Logo
Computer Repairing
Computer Repairing
