Question about Keurig Special Edition B60 Coffee Maker
Sometimes it turns off completely while brewing a cup. Other times it stops brewing half way or more while brewing but doesn't shut off.
  • Keurig Master
  • 1,711 Answers
Here is a sugestion tip that will help
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Good luck thanks for voding
Posted on Aug 10, 2010
Need cleaning info
Manual version: Prepare a cup of white vinegar and 4 cups of water. Pour into reservoir and initiate "clean" cycle. Boiler was warm up, shut off and repeat over the period of about a half hour, and then finally cough up all the stuff and end the cycle. Then, fill with cold water and run a full brew cycle to rinse.
My version: Dump about a quarter cup of CLR into the reservoir, let stand for a half hour. Then, add 4 cups of water and run the "clean" cycle. After finishing, unplug and turn unit over over the sink to completely drain, use tap water to clean and flush the reservoir thoroughly, dry thoroughly and then plug in, reset the clock and brew time, and run a full load of drinking water/distilled water through to final rinse. It will last forever with my method.
Feb 19, 2013 | Mr. Coffee 12-Cup Programmable Coffeemaker
My krups 4055 that is less than 2 mos old suddenly wont brew. it brewed about 2 cups and stopped. water still in resevoir & turning it on & off & unplugging doesn't help.
Dec 13, 2010 | Krups KM4055
I have an inexpensive chefmate 12 cup coffee maker, and it's still pretty new. But it stops brewing about 1/2 way through, and is painfully slow the rest of the time. Do I have a "you get what you pay...
I had the same problem. Sometimes opening and shutting the top will get the heating element to come on again. I took mine apart and installed a switch to bypass the thermal sensor located on the underside of the hot plate, throwing the switch forces the heating element on until brewing is complete.
Oct 04, 2010 | Coffee Makers & Espresso Machines
Water doesn't come down when brewing
I had the same problem, and it turned out it was the top needle that was clogged. I used a safety pin to clean out the needle and it worked again . . . I descaled immediately, just in case it needed that too. I am back to coffee goodness!
Jul 07, 2010 | Keurig B60 Coffee Maker
Keurig shuts off as water heats and as coffee is brewing?
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
Jun 14, 2010 | Keurig B50 Coffee Maker
My keurig will not dispense right amt of water
Try brewing a cup without a K-cup in it on the largest cup button (will brew just hot water). This will help clean it out in the event it is clogged. If that doesn't work, completely remove the K-cup holder where the needles are (careful not to get **** ) by pushing up from the bottom and rinse using hot water, preferably with a sink sprayer if you have one. Sometimes the needle can get clogged, especially if you ever use the hot cocoa K-cups, so the manufacturer recommends brewing a "blank" cup of just hot water after each hot cocoa K-cup brewed. Hope that helps...Best of luck!
Jan 02, 2010 | Keurig Special Edition B60 Coffee Maker
Coffeemaker will not brew a full pot
Try cleaning it with pure vinegar. 3-4 times just keep running it through the machine.
Jan 12, 2009 | GE 106591 Coffee Maker
Brews most of the water than stops and shuts itself off
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Aug 27, 2008 | Cuisinart DCC-1200 Coffee Maker
Keurig Special Edition B60 Coffee Maker Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
