Question about Sony VAIO VGP-WKB1 Keyboard
Sony Vaio VGN-Z11MN,Keyboard problem
We recently odered QTY 12 Sony VAIO VGN-Z11MN Laptops which came with the problem as under;
-when you hit Shift +2 it displays @ character, this key in reality is a “ character.
-When you hit Shift + “ it displays @ character
- Ordered Operating System - Microsoft Windows Vista Business
-Supplied – Windows 7
Action:
changed the so-called language setting of the keyboard,nochange!
shaky120
  • 310 Answers
SOURCE: Sony Vaio PCG K115M keyboard problem
Hi, its easy to fix. you have your keyboard layout set to US Layout, ie americans have a couple of keys in reverse from ours. All you have to do is this Windows XP Start, Control Panel, regional & language settings, change all US Settings, in there to UK British, And it will fix your problems :-) if its windows 98/ME ETC start, control panel, Keyboard, and change the US Keyboard setting to UK British, u usually have to set it twice, ie select uk, apply it, then do it again before it changes... If you dont get it sorted will guide u though it just email me.. All the best John auctionscotland@tiscali.co.uk
Posted on Feb 28, 2007
  • 20 Answers
SOURCE: Sony Viao keyboard - certain keys got wet & no longer work
well the damage is pretty much already done however you may try dabbing your keyboard with alcohol you can use quite a substantial amount use Que tips to get in between the keys.
I suggest getting it fixed
Posted on Dec 15, 2008
  • 20 Answers
SOURCE: vodka lemon onto my sony vaio vgn-n38 laptop
call sony, 18887398246, have all your info ready that is on your laptop. order new keyboard.
Posted on Mar 18, 2009
Geekman
  • 32281 Answers
SOURCE: Win Xp Drivers for sony vaio vgn-fw230j
Go to download the drivers that you require from the Sony WEB site, to their support/download page. Make sure you input your model laptop and select the Windows OS that matches your installed operating system.
Use this link :-
http://esupport.sony.com/perl/select-system.pl?DIRECTOR=DRIVER&SR=nav:service_support:electronics:drivers_software:esup&ref=http%3A//www.sony.com/index.php
Posted on Apr 15, 2009
SOURCE: Hi my sony vaio vgn-sr13gn, shift key does not
A friend of mine has the same problem and i stumbled on your question today. This problem occurred with the Vaio VGN-FZ11E, after very very modest usage, no scratches or damage visible whatsoever.
There's one option out there:
"I found that if you hold down both left and right shift key at the same time (did this for several seconds), it somehow solved the problem. Hopefully that fixed the issue. Also, go to control panel, click on accessibility options..in the keyboard tab, click on the settings buttons for sticky keys, filter keys and toggle keys and deselect the option to use shortcut..hopefully this will help you and other people that have had this problem."
Quoted from here
If that doesn't work, seems to me the remark of Benwabnick seems to be the solution, as posted below.
579a389.jpg benwabnick
Rank: Guru sony.gifSony Expert
Rating: 89%, 428 votes
the contact underneath the shift key itself is starting to go bad. Its a common issue with sony laptops, the keys can wear out pretty quickly. You'll have to get another keyboard.
BR
Posted on Jul 20, 2009
I would like to disable the touch pad and use an external mouse. Sony Vaio VGN A190
Please follow the steps to disable the Touchpad under XP environment:
First, click the Start button, then click VAIO Support Central .
In the VAIO Support Central window, in the left pane , click System Maintenance .
In the right pane , click VAIO Central .
In the VAIO Central window, click the System Information tab.
On the System Information tab, click the Plus symbol next to Keyboard and Mouse .
Under Keyboard and Mouse , double-click Built-in Pointing Device .
In the Built-in Pointing Device window, click to clear the Enable box.
Click the OK button.
In the Built-in Pointing Device dialog box, click the Yes button.
Thanks!!!!
Dec 24, 2010 | Sony VGN-A190 Notebook
The keyboard on my boss' sony vaio VGN TZ 340 seems to be locked. At least it doesn't work. Cleaning around it didn't work. Could she have unintentionally hit a key or function key that would cause this...
no there is no key that does that, your boss spilled somthing on it and thus it doesnt work, could need a new keyboard or just connection to motherboard.
Jun 04, 2010 | Sony VAIO VGN-TZ340NCB PC Notebook
My shift keys do not work on my sony vaio. I have a VGN-N130G. Neither shift key works, however, the CAPS LOCK works. It was fine yesterday. I did restart the computer and it did not fix the problem.
sad to say but if you want you can replace it with new one. or you can use a usb keyboard. or just let it be until some of the keys become defective. its your choice.
May 25, 2010 | Sony VAIO VGN-FS980 Notebook
How to insall keyboard on sony vaio fs 635b
Here is the link to your service manual, the keyboard removal procedure starts on page 7. It is in full color pictures and detailed.
http://tim.id.au/laptops/sony/vgn-fs.pdf
Dec 08, 2009 | Sony VAIO Notebook
How to replace keyboard on sony vaio VGN FW230J
This kind of replacement needs to be performed by qualified person. Better take it to the service.
Jun 24, 2009 | Sony VAIO VGN-FW230J/B Notebook
Sony A690 Memory Location
Some Vaio laptops (and some HP's) have a memory slot under the keyboard.
Jan 26, 2008 | Sony VAIO VGN-A690 Notebook
SONY VAIO CMOS BATTERY LOCATION
Correction...
The CMOS battery is located under the system board, and is not accessible from under the keyboard.
The keyboard has to be removed in order to change the CMOS batter, (another reason why I don't like Sony laptops.)
Oct 24, 2007 | Sony VAIO FX150K Notebook
Sony VAIO VGP-WKB1 Keyboard Logo
94 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
