Question about HHP Alternator/Battery Tester - 125 Amp Load Hand Held
How do i find the tension bar to loosen the v-belt to change the alternator in my 2005 ford f250 6.0 d...need a diagram please
Tensioner pulley is located on passenger side head, just behind the fan shroud. There is a pivoting catch that will hold the tensioner in the "loose" position so the belt can be removed or installed.
Stand on ladder or on the passenger side tire and pull up on the belt, Reach down and press the keeper in while holding tension on the belt. Release tension down on to the keeper. When belt is reinstalled, pull up on the belt to release tension from the keeper and release. The keeper will pop back into normal position and the tensioner will tighten against the belt.
Posted on Dec 26, 2012
Belt for Power steering needs changing> belt size and how to change
would need more information for your request year make model and engine ----go to any auto parts store they will ask same information for belt ---if serpentine belt under hood is a diagram of how belt is routed use a breaker bar or ratchet on tensioner pulley remove belt on older thin belt usually loosen alternator remove belt replace tighten alternator
Aug 05, 2015 | Cars & Trucks
Alternator belt diagram for isuzu bighorn
All above is Bull Sxxxt. Isuzu bighorn Alternator belt only drives water pump (fan) and alternator. Size of belt is 17x1000 and its a tight fit onto pulleys so it makes you think its wrong belt, but trust me its not. As if you get 17x1025 or 17x1050 belt you wont get it tight correctly due to not enough adustment on alternator. To change/adjust the belt very simple. Loosen 3 bolts (14mm socket) on power steering pump (its 2 belts that diving power steering and air con), loosen tensioner on p/s pump. Remove those 2 belt - to get access to alternator belt adjustment bolts. There are 2 bolts you will need to loosen One at the bottom of alternator (14mm socket and 25mm extension bar to get it easier) another one is 12mm on tensioner rail. Than adjust tension by screwing 12mm long bolt that mounted across the tensioner rail until you get tension correct. Correct tension is about 68kg. But i do it just to get it nicely tight without too much of sag. REMEMBER DO NOT OVERTIGHTEN the belt as you will crush berings on water pump or alternator.
Jan 12, 2012 | Cars & Trucks
I'm changing out a bad alternator on a 2004 mustang ,where is the belt tensioner locateed?
usually right under the alternator sometimes the alternator is the belt tensioner, if so then just loosen the alternator bolts and in should move inwards a little allowing you to get the belt off, if thats the case then make sure you have a pry bar of some sort to adjust the new alternator so the belt will be tight
Apr 15, 2011 | 2004 Ford Mustang
How do i change the fan belt on an m reg 1.6 si ford fiesta. please give a diagram if possible.
havnt got a picture but just loosen the three bolts on the alternator,swing it inwards towards the engine block and remove/fit new belt,swing the alternator back out and tension the belt before doing up the bolts,use a long screwdiver as a "crowbar"to tighten.The belt should have 1/2/"play on the longest stretch between pulleys.....check the tension after 250 miles.(yes,it is that simple).
Dec 31, 2010 | Ford Fiesta Cars & Trucks
How do you loosen belt to change alternator.
You need a belt tensioner tool, it's a long flat bar with a 3/8" square drive on the end. Most auto parts stores will have one to borrow.
Insert the tool into the belt tensioner and rotate this will loosen the belt for removal.
Make sure you disconnect the + battery cable before you start working on the alternator.
Nov 12, 2010 | 1994 Ford Taurus
I can't get my serpentine belt back on after changing my alternator. What do I do now?
Hi Friend:
#1) On your vehicle you have a Serpitine Belt tensioner ,your Serpitine Belt runs on this also;
#2) Locate your Belt Tensioner its (Aluminum) and is Spring Loaded to kep your Belt at the Proper Tension.
#3) On the front side of the Tensioner there is a Bolt Head, Get a Breaker Bar ,Correct size Socket or(Ratchet and Socket)
#4) With the tool on the bolt head the Tensioner will move by applying pressure to the Tension.It will only move 1-Way when applying Pressure with Your Tool.
#5) By Moving the Tensioner you will be getting enough Slack that you Can Put the Belt Back on.
#6) You should have a Belt Routing Diagram on your Cooling Fan Shruod or the Frame in Front of it.
#7) Just take a Good look at how the Belt HAS to Be Routed it will only work 1-Way.
#8) So Follow the Diagram for Routing and you should have no Problems. Don't Forget it Will not Go on Correctly until you Apply perssure to your Belt Tensioner.
Please let me Know how well i have Assited you.By voting .And a Testamony would be Appreciated.
Thanks for Using FIXYA from; d_hubbs
Jun 18, 2010 | 1991 Chevrolet Cavalier
How to releived the tension on the belts when removing the the alternator on A 1995 jeep wrangler
Serpentine Belt:
If there is a tensioner with a spring, then put a 1/2" breaker bar on it and rotate the tensioner to relieve tension.
Conventional V-Belt:
Loosen the nut and bolts for the alternator to swing it in a way that relieves tension on the belt.
May have to relieve tension on other belts in similar way to change the belt in question.
Jun 21, 2010 | Cars & Trucks
Serpentine Tensioner for 2000 Ford Escort ZX2
normally you can take a 1/2inch breaker bar and insert it in the hole on the tensioner pull down and take the belt off the alternator and also try autozone.com to see if they have your car listed for diagrams pictures and step by step instructions if your car is not listed then try your local library they have all the car manuals and even copy them for you
Mar 21, 2009 | 1998 Ford Explorer
Need to change a belt on 97 ford explorer
u dont loosen pully there is a place on belt tensioner you put breaker bar, ratchet,or belt tool in to pull tensioner back to remove belt
Mar 05, 2009 | 1997 Ford Explorer AWD
Changing alternator
Look at the tensioner and u will see a slot in the end where a breaker bar will fit into. Install the breaker bar and rotate tensioner clockwise.
Feb 18, 2009 | 2001 Ford F150 Styleside SuperCrew
HHP Alternator/Battery Tester - 125 Amp Load Hand Held Logo
209 people viewed this question
Top HHP Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a HHP Measuring Tool and Sensor Expert? Answer questions, earn points and help others
