Question about Uniflame FG2204C Grill
There is no gas flow to my burners. I have a new
There is no gas flow to my burners. I have a new tank and opened it really slow. took it to a local gas tank fill place and the tank is working fine. grill is a little over a year old. I dont get that sound like the tank is hooked up. any help would be great
    Champion:
  • 274 Answers
Try replacing the hose and regulator, easy to do and inexpensive.
Posted on Jul 13, 2010
We replaced the regulator and the grill still does not have big flame always seem to be on low despite knob adjustment
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 30, 2014 | KitchenAid Superba KFRS271TSS Stainless...
Why wont my old grill work with new propane tank
Jul 13, 2014 | Weber Q Grill
New grill, grill is burning slow like not enough gas going through
Sometimes if you open the valve on the tank a little to fast, Or the burners are on when you open the tank, there can be a surge of gas that can activate a flow restrictor. try turning off the the tank with the grill valves on. listen for a little click or ping. Then shut the grill off and open the tank valve slowly
Aug 27, 2011 | Brinkmann Grilling
Just purchased new Brinkman 5 burner Pro series. Worked fine when I tested it but now the main burner is the only one that will ignite and it won't stay on. The side burner works great.
First, check the gas line hose from the tank to the grill. Look for kinks or twisting that would restrict the flow of gas to the burners. If you find any, turn the gas tank valve OFF, disconnect the hose from the tank and straighten the hose, before reconnecting it to the tank. Then open the gas valve Very, Very Slowly, until it's fully open.
If you didn't find any kinks or twist, do the following:
1. Turn the gas tank valve OFF, Disconnect the hose from the tank and wait 5 minutes.
2. Turn on any pair of burners to High for io minute and then turn them OFF.
3. After 5 minutes has elapsed, reconnect the hose to the tank.
4. Open the tank valve VERY, VERY, SLOWLY (Slow motion, slow) until it's fully open.
5. Light the burner farthest from the tank first and turn it to HIGH. Does the flame height look
correct? If so, light the remaining burners the same way. Do all the flame heights look correct?
If so, you solved the problem!
Hope this helped you . Please let me know and Happy Grilling.
Jun 19, 2011 | Brinkmann ProSeries 810-6330-W Grill
A low flame comes out of my burners. I can not make any adjustments to make it hotter.
Unless, your tank not is really low on gas and your burners really don't need cleaning? Try this:
Turn OFF the tank valve and disconnect the hose/regulator assembly from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY, VERY SLOWLY (Slow Motion, slow), until the tank valve is fully open. Then light the burner farthest from the tank and turn the control knob to the highest setting. Has the flame height returned to normal on that burner? If so, light the remaining burner(s) the same way. Now, do all the burner flame heights look normal? If so, you solved the problem. Just remember to always turn the tank valve on very, very slowly.
If the above didn't solve the problem, turn the tank valve OFF. Disconnect the hose/regulator assembly from the tank and the grill. Then, head on over to your nearest home center or hardware store that sells gas grills and accessories, because you need a new hose/regulator assembly. Be sure to take the old one with you for comparison purposes.
Hope this helped you troubleshoot and solve the problem.
Apr 29, 2011 | Char-Griller CharGriller Grillin Pro 3001...
Grill does not get hot enough. Which seem like low gas flow. One burner does not light
Yes, it is probably low gas flow. I assume you feel comfortable that there's a reasonable amount of gas in the tank.
Here's what you need to do. Turn OFF the LP Tank Valve and disconnect the hose from the tank. Wait 5 minutes. While you're waiting lift out the tank. Does it feel as heavy as it should? Or does it feel lighter than it should? If it feels lighter, you're either very low or have run out of gas.
In either case, here's what you need to do when you reinstall that tank or a new one. Attach the hose to the tank. Turn the tank valve On VERY, VERY SLOWLY ( I'm talking slow motion). Once the valve is fully open, light the burner that's farthest from the tank and turn it to the highest setting. Does the burner flame look correct? If it does, light the next burner and turn it to high and continue doing that until all the burners have been lighted. If the first burner flame doesn't look correct after you lit it. Turn the tank OFF and repeat what you did previously. If it still fails to produce the right flame heights, either the venturri valves on each burner are clogged or the regulator is locked up.. You will have to remove the burners to clean them. If that fails to solve your problem, buy a new grill hose and regulator. You can purchase it at either Lowe's or Home Depot or your local hardware store. Just be sure to take yours with you, so that you can get the right length and brass fitting size matches.
I'm sure this will solve your problem. Please be kind enough to let me know.
Happy Grilling
Rich
Mar 04, 2011 | Char-Broil Advantage 463453306
Low flow of gas to 1st burner, if second burner is turned on flame goes out. bottle full
First disconnect tank. Hook back up and open very slowly. These new valves on tanks have a shut down if you open valve to fast, causing tank valve to think it is leaking, it slows down flow of propane. Always open tank valve slow when turning on grill. If this does not solve problem then regulator is going bad and need to be replaced.
Feb 08, 2010 | Weber Genesis Silver B Grill
Gas does not flow properly to burners. Bled gas container. No impact. What else can I do?
try opening the tank really slowly. if you open the valve on the tank too quickly the OPD (overfill protection devise) will restrict the gas flow to the burners.
Oct 24, 2009 | Weber Genesis Gold B Grill
Low flame only 2 burners will light inition seems good new tank of fuel
try opening the tank valve really slow. it you open it too fast it restricts the gas flow.,
Oct 10, 2009 | Barbeques Galore Grilling
Gas flow
Your regulater connected on tank has a shut down safety inside of it. disconnect tank hookup, then reconnect, always open tank valve slowely when you open to fast regulator thinks there is a leak and starts shutting down valve to slow leak. Opening slowely will solve your problem.
Aug 17, 2009 | Weber Genesis Silver B Grill
Uniflame FG2204C Grill Logo
228 people viewed this question
Top Uniflame Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you an Uniflame Grilling Expert? Answer questions, earn points and help others
