Question about Ariston Technologies Refrigerators
Refrigerator Ariston MBT 1912 FI. It worked perfectly for almost 2 years...few hrs ago, it just stopped. No indication on digital panel, no sound nothing. I have checked for voltage presesnce and, on the big green electronic board, there is voltage on brown/blue wires. What could it be, is it any replaceable fuse anywhere?if you could sent the answer in greek please.thank you
SOURCE: Samsung side by side refrigerator not working
I am somewhat of a fix-it guy and here is my take....I also have the same refridge with other problems, and have done alot of research and discussions with the local repair techs and Factory rep. Here we go: The Samsung models are very prone to problems arising from power fluctuation's that fry the motherboards. One problem may be that the defrost circuit fails and the unit freezes up causing a lack of cooling and loud banging of the compressor. To run a diagnostic of the unit, you need to press both power freeze buttons for 10 seconds beeps will sound and release, the dashes on the display showing if any circuits are bad.(self diagnostic) This is what the service guy will do then come in with the part and replace. With a bad board, the diagnostics reveals no problem and the service agent will just start replacing parts, at your expense! Also the part #'s will show discontinued but they just changed parts #'s.. Be careful, my dealer said all parts were no longer available....he was wrong! Motherboards are a bear, I believe my model has 3!Most techs are not familiar with Samsung and will not be able to correctly diagnose the problems, mine came out and said it! "We do not Know and the factory will not give us any idea what the problem is" We're sorry! That was 3 month ago, and now I have a beautiful yard fixture! a $1400.00 yard fixture!! hope this helps someone..
Posted on Sep 06, 2007
ctf1800
  • 4402 Answers
SOURCE: Green light blinking - Panasonic PT-40LC12
Found that the thermistor/temp measuring device is suspect, no resistance across legs. There is a label there that says F701 see service manual
http://www.goodmans.net/get_item_th-tf117c_thermal-fuse-117-degrees-celsius.htm
I went here for a tech manual for the Panasonic
tv.
http://www.ManualsParadise.com
then ordered
Manufacturer: Panasonic
Part Description: FUSE
Part Number: LSJA0411-1
from
PartStore.com
it was mounted to the case that holds the lamp. had to remove the back panel, etc. Also think I had to splice in the fuse or something. was a while ago.
i purchased a NTE8115 from my electronics supplier, closest I could find.
Radio shack also has them.
remove the back cover and measure for continuity across the thermal fuse
above the lamp housing.
if open jump it wth a 5 amp fuse, be sure to close the safety switch with
the small blue lever then try to power on.
If comes on ok you will need to replace the entire ballast assembly to get
that fuse.
Panasonic does not have a part number for just the fuse on the PT40LC
series.
It is possible to cut off the fuse and replace with another but dont solder
Posted on Jan 28, 2008
maklean
  • 1665 Answers
SOURCE: Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Posted on Jul 04, 2008
SOURCE: Will not cool on gas or electric
my RM2652 refrigerator will not get cold on gas or elec. freezer cold (not much) but main box nothing. also fairly warm/hot to the touch around the edge of the unit. Any ideas??
Thank you
Robert
Posted on Jul 27, 2008
SOURCE: no sound
I had the same exact problem, here is what someone else suggested I do:
I had a problem with no audio and I recently found the fix. When thesub still worked and you turn it on you hear one relay click and thenabout 5 seconds later a second relay clicks and the audio comes on. Theproblem I had lies with that second relay. When you take the case apartthere are 4 circuit boards. The big board with the two big bluecapacitors is the main board. Well next to the two blue capacitors is ablue relay. That relay had a pin that came un-soldered from the circuitboard. I re-soldered that pin and the sub works just like new.
Posted on Oct 08, 2008
Wi- fi
I would say you have a problem with the router unless you are not reading the situation correctly, the other alleged connections will not be accessible for any reason unless you are the one paying for that connection, it would be illegal otherwise, so i am going to assume that you have a faulty router.
Jun 22, 2014 | Acer C7 Chromebook
I have a Denon AVR 1912 purchased 1 1/2 years ago. All I have hooked to it is the cable box and then it runs it out to the TV and surround sound. My Denon stopped sending the picture to the TV but I can...
I would double check all the connections to and from the Denon. Cables and poor sockets are the biggest problem with these kind of systems. Double check the settings of the Denon for outputting video signals.
May 30, 2013 | Audio Players & Recorders
Polar RS200 kills batteries
Got the same problem - changed battry in the RS200 twice, dead after about a week. Bought a "quality" battery, lastet fro 3 weeks, dead again.. :-(
This 4. time, after replacing battery again, I did try to Master Reset the RS200 (see www.polar.fi under support in forums) link: http://forum.polar.fi/showthread.php?t=14065 - but also TAKE CARE to reset to factory default!! You will loose all stored data!!
I am now only waiting (and running) to see how long the battery will last this time...
This might be the problem... give it a try?
Jun 02, 2010 | Polar RS200sd Running Computer Heart...
Our Ariston AWD12 keeps cycling through programs. Engineer has replaced lots of parts but problem not fixed. 13 flashes showing as it clicks round.
Th e fault code indicates a problem with the dryer fan or the thermistor as being the cause of the problem. Check for broken wire.
These are located in the top of the washer, access is gained by removing the top cover.
Jan 15, 2010 | Ariston Technologies Ariston AWD12 Front...
GE Arctica intermittant clicking sound, panel flashes "hrs"
It sounds like the main control board is going bad . This controls every part on the fridge , except for the light bulbs . It's located on the back of the refrig , behind an 8" X 10" panel , with about 11 screws , holding the panel on . Part number WR55X10656 .
Sep 16, 2009 | GE GSH25JFR Side by Side Refrigerator
The refridgerator has stopped working entirely..2 weeks ago the water stopped working, now only the light works
On your model that is an indication that the mother control board is defective. Unplug and remove the panel on the rear of the refrigerator tat covers the mother board. Take it out far enough to examine both sides for burn marks on both signs or heat damage. Let me know what you find, Thanks, Sea Breeze
Aug 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Chinese refrigerator stopped working.
Appers to have lost refrigerant, yup you need to call in the repair man.
Nov 11, 2008 | Refrigerators
Kenmore Elite refrigerator Model 596.76533500 temperature control panel locked?
I have this problem also my control panel is not working. It has an Er If on the panel.
Oct 08, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Please help
it is the timer or, it may be a short of some kind
Apr 19, 2008 | GE WDSR2080D Top Load Washer
Refrigerators Logo
164 people viewed this question
Top Ariston Technologies Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you an Ariston Technologies Refrigerator Expert? Answer questions, earn points and help others
