Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
My ice maker is not working. My filter needed to
My ice maker is not working. My filter needed to be changed for quite some time. I emptied the full tray of ice & no ice was made. I went & replaced the filter & still no ice. model # 106.56536400. Does the accelerator 2 button need to be on? Also the ice bin is on the side door & there is a lever inside the bin but does that have to be turned a certain way? I don't think so. Any ideas. Thanks
  • Kenmore Master
  • 43,501 Answers
Here are some basic tips for ice maker troubleshootingMy ice maker is not working.  My filter needed to - 2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Posted on Jul 13, 2010
Ice maker not working on a whirlpool french door fridge
Is the cold water dispenser working? If not, does the filter need to be changed? Do you actually have water supply to the fridge?
Is the Ice bin empty? Is this your fridge, or are you renting and this was in place? If yours, do you have an Owner's manual with the troubleshooting tips? No manual, try manualslib.com Make model possibly year and serial number. If not yours, there should be a switch that turns the Icemaker on or off. A green light on the front of the drive mechanism near this switch should mean it does have power. No light, no power. There should be a mechanical switch that stops the Ice maker. If the bin is empty, the ice detection arm should be down If it is not down, It is stuck in the "bin is full" position. If these are not the problem, It may be the electrical valve for the Icemaker water supply is not operating, or has been disconnected, or is bad. I have found that one of the online "appliance parts store or sites" have been quite helpful in diagnosing problems and recommending parts and how to fix.
Apr 01, 2015 | Whirlpool Whirpool 26 cu. ft. French Door...
Our ED5SHAXM ice maker is intermitant. It will make ice for several weeks and then suddenly stop making ice, the water flow to the ice maker stopes and the bin empties it's final time. Then weeks later it...
Either the freezer temperature is too high or the internal thermostat inside the ice maker is faulty.
The freezer temp must be 5 degrees or less for the ice maker to work correctly.
If the freezer checks out OK you will need to replace the ice maker.
Apr 10, 2011 | Whirlpool ED5SHAXM Side by Side...
Do i need to change the filter in order to get the ice maker to work? the water still come out but not into the ice maker. please help!
no you donot need to change the filter first. all of the water goes through the filter first. you either have a bad water valve for the ice maker. a bad ice maker. or bad optics that sense the ice bin on the door is full. can you move the ejector blades on the ice maker? that will tell you if the ice maker gear is broken.
Apr 25, 2010 | Whirlpool GS6NBEXR Side by Side...
Ice maker stopped working
The water line may be clogged with debris. there is sometimes a filter in the water line to the fridge, or also a screen filter may be located at the point where the water line connects to the fridge. If they are clogged, your ice maker will not make ice and may even burn out.
Check that the water in the line is flowing freely. Also it might be a good idea to defrost the freezer in case you have a ice buildup in the freezer compartment. To do that, empty the freezer and blow air into the freezer for 30 minutes while the power if off. Note, keep the other side closed to protect the milk and other perishables.
Nov 21, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker on GE Profile quit working. Emptied tray of ice and put back in, not producing any ice.
Make sure the "Full" actuator is in the down position. Sometimes when the ice tray is removed, the full actuator flips up to stop ice production.
Hope this helps.
Aug 18, 2009 | GE Refrigerators
Whirlpool water dispenser and ice maker quits
change your water filter its probably full of dirt and plugged
Jun 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
ICE MAKER HAS QUIT WORKING
take off the cover to the ice maker. make sure the 2 tabs in the middle of the main gear are in tack and not broken. if one of those tabs is bent or broken, the gear will not make a full rotation. if the gear is fine, check your fill tube in the back of your freezer that goes to the ice maker and make sure it is not frozen. if it is, it will need to be thawed. does your unit have a water filter? if so,it may be plugged and need to be changed. the last thing would be an issue with the water value itself. Joe
Nov 18, 2008 | Refrigerators
Ice maker quit making ice
your refrig has a built in bypass in the filter housing so yes it will work with out a filter in place. if you have not replaced your filter in the last 6 months that is likely the problem. Hollow cubes are usually a sign of not enough water getting into the icemaker then it cycles too fast and harvests hollow cubes.
when the hollow cubes fall into your bucket they bust and put water in with your cubes freezing them together. so by solving your water supply problem you'll solve most of your icemaking issues..
Dec 19, 2007 | Kenmore 64802 Top Freezer Refrigerator
Kitchen Aid Ice maker Stopped working
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
Nov 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator Logo
359 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
