Question about Gateway GT5432 Refurbished AMD Desktop Computer - AMD Athlon 64 X2 5000+ 2.6GHz , 1GB DDR...
Panel1 power sw i need to no how to wire it properly
  • Gateway Master
  • 5,660 Answers
Gateway Support > GT5432 desktop computer > Components >
Motherboards > 4006157R - ECS MCP61- P AMD Motherboard >
Product View > T - Front Panel Connector,
http://support.gateway.com/s/MOTHERBD/Shared/4006157R/4006157Rmvr22.shtml
The Power On switch connects to Pins 6 and 8.
Should you not understand the chart, or need additional info regarding this, just post in a Comment.
JCV
Posted on Jul 12, 2010
  • joecoolvette
    joecoolvette Jul 17, 2010
    Familycraig, should like to know the outcome.
    Is there a problem, with not knowing which wires lead up to the Power On switch?
    (Located inside the Power On button)
1 -3 way sw installed with a 3 way dimmer without a load,test voltage on wires for light to make sure sw is working properly. with sw on 120V,sw off 100V?? why the voltage with sw off? All new wiring.
You will always have voltage through the black incoming wire unless you turn your circuit breaker off. This wire will be attached to the common terminal on the switch. Is this what you were testing?
The power comes in the common terminal and then is switched through, or on, and broken, or off, when the dimmer is clicked. Therefore, there is always power coming into the switch.
Hope this helps, if it does, please place a vote for me. Thanks,
Handie Andie
Mar 28, 2011 | Pass & Seymour Trademaster 3-Way 15 Amp...
Need prescott 800 ddr 400 sound card drivers
ITALIANO
Sceda madre ASROCK Prescott 800, FSB 800/DDR400 Dual Channel
Comme deve ataca PANEL1
POWER SW o o
RESET SW o o
HDD LED o o
POWER LED o o o
Grazie
Nov 18, 2010 | Asrock P4I45E-R3 P4 845E FSB800 DDR400...
My computer is a clone, brandname Digitek, motherboard model is Pvm7 V:1.0 Mercury, it has aproblem with power switch n the motherboard has not indicated where to plug in the sw power, hdd power, led power
The connector is right below the battery, it is marked on your motherboard Panel1, the battery is the lower right hand corner of the board, ( it looks like a quarter)
Pin Signal Pin Signal
1 HD_LED_P(+) 2 FP PWR/SLP(+)
3 HD_LED_N(-) 4 FP PWR/SLP(-)
5 RESET_SW_N(-) 6 POWER_SW_P(+)
7 RESET_SW_P(+) 8 POWER_SW_N(-)
9 RSVD_DNU 10 KEY
Oct 14, 2010 | Intel Motherboard
Where does the HDD Led, Power SW, Reset SW, and Power LED plugs go on the ECS GeForce6100SM-M motherboard
You'll need the manual for this MB. If you do not have it you can download it from the link provided;
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=685&DetailName=Manual&MenuID=1&LanID=9
You'll also need Adobe reader to view the manual. Download Adobe here; http://www.adobe.com/products/reader/
Open to page 12 and zoom in with Adobe if needed. See pages 4 and 5 for location of, PANEL1.
Wire colors do vary from case to case. Colored wires are more often positive where white is common for negative. As you look at you're case wires you will find one color in common with most of the jumpers. This common color will be positive.
The internal speaker wire colors are red for positive and black for negative.
Main Web Page for ECS GeForce6100SM-M (1.0)
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?DetailId=685&DetailName=Feature&MenuID=1&LanID=9
Take you're time.
Mike
May 12, 2010 | EliteGroup ECS GeForce6100SM-M (1.0)...
I need the wiring diagram for power,reset,lights
there is no need for the wiring diagram
if you check *********** board properly
you could find written in small font like
PWR SW for power switch
RST SW for rese switch
HDD LED , PWR LED etc
May 05, 2010 | Wintergreen Lindows Webstation (M810L11L)...
How to connect power sw and led and reset sw and hd led
You'll need to go to the Elitegroup website and download the .pdf file showing a diagram of the motherboard wiring layout and pin connections and then connect the wires from the case to the proper locations.
Oct 07, 2009 | EliteGroup 865G-M8 (V1.0) (MB865GM8)...
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Front panel connections
Hi sjcrofts,
The most common problem for most people is knowing what wire color is positive & which wire color is negative. The colors blue, red, green, light blue, light red & light green are normally positive. The color white & black are negative. Your board uses only 2-pin connectors. The 3-pin power connector can be turned into a 2-pin connector to work with the M848ALU pins.
(Page 13, PANEL1). How to? Take the three pin connector, on the back side of the connector you'll see a small tab that holds the wire into the connector. Use a needle & pull tab up while pulling the wire out at the same time. The wire should slide out. Insert the wire back into the connector next to the other wire. You do not need to hook up the SUS led which stands for suspend.
Pin 1 is positive & the manual shows this by adding the _P = positive.
Pin 3 which is to the right of pin 1, is negative for the hard drive led. Pins 9 & 10 are not used.
Good luck sjcrofts!
Mike
Nov 30, 2008 | PC Chips M848ALU Motherboard
Proper connection
if u look real close to the pins on the board they will say pwd led and power sw ect ect please keep me posted if you need more help identifying these pins
Aug 06, 2008 | E-Machines eMachines Desktop PC
Gateway GT5432 Refurbished AMD Desktop Computer - AMD Athlon 64 X2 5000+ 2.6GHz , 1GB DDR... Logo
243 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
