Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Water will not drain
The water will not drain after the wash cycle and it will not even attempt to drain after the rinse cycle (that's if I manually put the cycle on rinse). I had to manually drain the water..is this a pump issue? If so, is this something I can fix myself once I get the part?
  • Kenmore Master
  • 8,220 Answers
Something could be inside the pump. I have found many items of clothing inside them over the years. Water will not drain - b4fc047.jpg5bacaa1.jpg3a658d0.jpg6a54f5c.jpgHOW IT WORKS (with 4 videos)
Manual and more here
Posted on Jul 12, 2010
  • kimbod24 Jul 12, 2010
    I will try this tonight..Thanks a BUNCH!!!!
  • Dan Webster
    Dan Webster Jul 12, 2010
    Thanks
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Washer not draining
sounds like you need to replace the pump
Aug 30, 2017 | Whirlpool Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
While the washer drains and spins, new water comes in
Drain hose must be at least 30 inchs above the floor.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Washer is not filling during rinse cycle.
Sounds like the water is being siphoned out by the drain hose. Check to see if the drain hose rises above the top of the tub.
Oct 29, 2007 | Maytag Performa PAV2200
MACHINE DOESN'T CYCLE OUT OF RINSE
Does it spin if you move the timer manually? ist it being used on a delicate cycle@? if so it will stop in the last rinse water
Jul 10, 2007 | Ariston Technologies AWD 121
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
265 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
