Question about Panasonic Viera TH-42PZ80U Plasma TV
I have a Samsung LN26B460B2DXZC LCD which suddenly has no sound and the picture is very faded with pink tones. I switched the hdmi cables but it didn't help.
2 Suggested Answers
  • 210 Answers
SOURCE: DVD picture is pink
check that all leads are pushed in
Posted on Nov 29, 2009
Our picture suddenly changed drastically from a clear sharp picture to a blurry, faded looking picture. Some colors are extremely bright, others are faded out. It is so bad it is not viewable.
Please check the flat cable connections between TCON board and the LCD panel. If this is ok, then it is either the TCON board or the LCD panel itself. Good luck.
Jan 02, 2014 | Samsung LA Televison & Video
My sumsung T220 HD LCD monitor *** t.v . when in install with cable its sounfd is not working when i install with somputer picture and sound is ok. how can i solve thisproblem
Use a HDMI cable for all signals. The cable you may be using may not be carrying a sound signal with it. HDMI cable will work for both sound and picture.
HDMI cable Links:
http://shop.ebay.ca/i.html?_nkw=hdmi+cable
http://www.amazon.com/HDMI-Cables-Video-Interconnects-Accessories/b?ie=UTF8&node=202505011
Feb 21, 2011 | Samsung T220HD LCD Monitor
Great picture but suddenly no sound over HDMI cable
try replacing hdmi cable. if that doesn't work you have something in the amplifier curcuit bad
May 15, 2010 | Televison & Video
Sony kdl-40v5100 has handshake problem
1.This issue sounds as though the TV connection circuit has an issue.
2. You have changed the DVR and the HDMI cables and you still have an issue with the video (pink screen) indicates a video circuit issue ( improper voltage or current) at the video section of the circuit.
3. This will require some troubleshooting by a qualified tech.
4. To make sure, try connecting another properly working LCD TV to the cable box or DVR an check.If you get a picture and sound properly it is the TV.
5. Usually a cable box is QA'd (quality assured) by the company and will not be sent unless tested 1st
Feb 05, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Does the Samsung PN58B650 need a minute to warm up the first time you turn it on every day? When I turn on the TV for the first time every day, the picture is there but the colors on the screen are pink...
I swapped out the HDMI cable with standard component cables. The picture and sound is perfect. Later I will swap again with a different HDMI cable to confirm if the problem is a bad cable or if the TV has a problem with HDMI.
Sep 22, 2009 | Samsung PN58B650 TV
Compatibility with Samsung LCD Display
It sounds like the HDMI port on the back of your Marantz is damaged. if you know for sure that the HDMI port works on another tv still you might just use component connection because the visible difference between component and HDMI is not very recognizable.
Jan 13, 2009 | Marantz DV4001 DVD Player
Samsung lcd tv LTN1765
check the wires, use a hdmi cable. one wire connects the sound and picture. other than that you will have to use the 3 componets wires and a seperate connection for your sound. example would be audio hook up or fiber optic cable
Nov 11, 2008 | Samsung LTN1765 17 in. LCD HDTV
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
NO sound on HDMI3 port and when playing Blu-Ray DVD's the screen is pink
Go to the samsung website, and find out how to upgrade the firmware for your TV. You will probably need a portable usb memory stick to do so (if your TV is equipped with one). HDMI is an evolving technology, and firmware upgrades can resolve many of these quirky issues.
Here's a possibility from http://www.samsung.com/us/support/faqs/supportFaqList.do?group=&type=&subtype=&model_nm=LN-S4696D&dType=D&mType=UM&vType=R&prd_ia_cd=02010100&acc_ia_fl=&disp_nm=LN-S4696D
Which Samsung LCD TVs Have The HDMI 1.3 Interface? spacer.gif Of the LN-T series Samsung LCD TVs, those models whose last two digits are 61, 65, 66, 69, 71, or 81 (for example, LN-T4071F or LN-T466F) have the HDMI 1.3 interface.
Samsung LCD TVs with HDMI 1.3 interfaces also have HDMI-CEC (HDMI - Consumer Electronics Control). For information about CEC, click HERE.
For information about individual Samsung LCD TVs with HDMI 1.3 interfaces and HDMI-CEC, click HERE. When the Samsung LCD TV web page appears, select the TV model you want information about by clicking the drop down list under Product Finder on the left side of the page.
Though other series of Samsung LCD TVs (LN-R, LN-S, etc.) have HDMI connections, none have models with the HDMI 1.3 interface.
Feb 18, 2008 | Televison & Video
Pink display
It seems the DV-S5950 has an incompatability with HDMI through Samsung TV's.
I work for an electronics store in Australia, and had same problem when running this DVD player on my Samsung KA40A650.
I tried it on my brothers LA40M51 and the same thing happened. Tried it at work on the A650 display model and same thing again. Then I tried it on the LG LCD that was next to it, and no problems. Also tried the DV-S5950 display model at work and it did the same thing.
It's not a general Yamaha issue, as we bought a new (higher model) Yamaha DVD player and it worked perfectly fine. I also tested the cables, and it wasn't them either.
It seems that that specific model of DVD player from yamaha just doesn't like the HDMI inputs on Samsung TVs...
Nov 26, 2007 | Yamaha DV-S5950 DVD Player
Panasonic Viera TH-42PZ80U Plasma TV Logo
63 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
