Question about Cobra 25 LTD 40-Channels Base CB Radio
Cobra 25 only transmit and recieve on ch 1
Cobra 25 will only transmit and recieve on ch 1. the body was dented in where IC3 is located causeing it to short out, after that the ch display and slecter doesn't work, ch 9 switch doesn't work either.
    Genius:
  • 1,274 Answers
Hi, my name is John. Take the cover off the unit, and check for broken trace or loose solder joints around this area, ...hope this was helpful..Rate this solution on the four thumbs-up.....John
Posted on Sep 09, 2010
Cobra 25 ltd will not transmit it will on pa mode and it recieves i replaced the final pll chip audio chip.can you help
there is the problem. a $150 repair bill for a $ 25.00 problem. After you put in this new IC did you put it on a scope to check it out.How about a frequency counter to make sure you were on the right frequency? take it to a tech and let him fix it .
Oct 16, 2011 | Cobra 25 LTD 40-Channels Base CB Radio
Finals for a Cobra 85 Home Base CB and hom many?
Not familiar with the 35......If it is a ssb radio it will have a pre driver and a pair of finals. they are located on the right side towards the back or along the rear of the chassis to the right. You may have the type of circuit that has a protector diode piggy backed ..they could cause that tyoe of failure also, but in the years I have serviced radios they do not fail too often. I WOULD SUSPECT THE FINALS.
Jun 20, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
I need to wire a sadelta es 880 echo chamber to my cobra 25 LTD ST MOBILE . if i have locator grove on plug upwards . ty for any help you can give
First of all, if you will look closely at the end of the mike plug, you will see numbers 1-4. 1- is shield, 2- is audio,white, 3- is transmit-red, 4-is receive,-black,.....hope this was helpful...
Apr 25, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
Superstar DM 452 echo mic wiring for a 4 pin cobra 2000 gtl ?
Note: The pin numbers are marked on the end of plug.....#1.shield, #2.white, #3.red, #4.black.....that means #1.shield, #2.audio, #3.transmit, #4.recieve..........hope this helps.........
Feb 16, 2010 | Cobra Radio Communications
Have a new cobra 148 gtl took out of box no transmit or recieve
make sure that your [swr] hadn't changed or went higher than a 1.5, anything higher will interfere with your tranmitting an recieving. other than that with out being there to see an hear your radio this would be the first place to start.
Apr 25, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Mic wiring for a cobra 85 base cb
Pin 1 is shield, thats the bare wire wrapped around the mic audio wire
pin 2 ic mic audio [usually white)
pin 3 is transmit or push to talk usually red
pin 4 is recieve or speaker complete usually black
Jan 08, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Cant transmit
Hello Darren, Yes it sounds like the mic is wired bass ackwards,,! A cobra 25 mic wiring is
PIN #1- Shield or ground wire
PIN#2- Audio or Transmit modulation
PIN #3- Transmit or Dead Key
PIN #4- Receive Audio.
When your keying the mic, the RX wires are being connected to make the RX work,,,
*** Let me know how you get along with it. Either buy a new mic wired for your radio or you or someone comfortable with soldering needs to resolder the correct wires back on the mic plug,,,Like I said, let me know and have a great day,, Mechanic is back quiet!
Oct 21, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 29ltd cb radio
A couple of suggestions:
1. verify that the RF Gain is maximum clockwise;
2. verify that the ANL or noise limiter is OFF;
3. pls add a ground strap from the body of the Cobra 29LTD to the chassis/GND of the vehicle or to your house GND connection;
4. Verify that your Wilson 5000 has a sufficient ground plane such as roof or metal objects.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 15, 2008 | Radio Communications
Cobra 25 LTD 40-Channels Base CB Radio Logo
69 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
