Question about Microsoft Xbox 360 Console
Bad wire I have a bad plug wire @4" long. L shape plug on both ends. one end has broken off. where can I get a new one.
  • Michael Lake
    Michael Lake May 11, 2010
    Is it the Xbox 360 power cable (Power brick piece of connector piece), or is it the Audio/Video Cord? I know how to get both of these.
    Problem Solver:
  • 8 Answers
Hi you can get new ones from where u got your xbox from or just somewhere like game or hmv
Posted on Apr 23, 2008
Wiring new electric plug on cable end
The green wire is always connected to the ground lug which almost always has a green screw in it. I goes on the long rounded, u shape or L shaped post at the end of the plug.
Jan 29, 2014 | Miller Electric Mfg Co 903376 Deltaweld...
No spark #1 plug
each plug has its own coil...? If so check batttery power at the end of
two wire that connect to the coil. (When car is still on )
Q: Any voltage...?
A: Yes.>>> Bad coil. Replace new one.
A: No.>>>>Check for broken wire or bad connector.
Mai
Mar 15, 2013 | 2006 Ford Ranger
How do I reboot aCuisinart BKR-400C breadmaker?
sounds like you may have a broken wire in the cord. cut the end of the cord approx 4 inches from the "plug end" strip the wire and plug the bare wires back into the outlet and see if your unit works, if it does the plug end has a broken wire, if it doesnt then the unit is bad.
Nov 28, 2011 | Cuisinart Kitchen Appliances - Others
Connecting jumper for start up
That would be connecting a jumper wire, from the Green wire to ANY Black wire, in the 20 or 24-pin ATX main power cable's connector.
If this problem is in direct relation to a Dell E210882 motherboard, it uses a 24-pin ATX main power cable,
http://en.community.dell.com/support-forums/desktop/f/3514/p/19298234/19565862.aspx#19565862
Example of a 24-pin power cable, and it's respective connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
The Green wire is the Soft Power On wire. (Abbreviated as PS_ON)
ANY Black wire is Ground wire.
With the 24-pin ATX main power cable plugged into the motherboard, and the power supply,(Computer), plugged into power, the jumper wire is inserted into the back of the 24-pin ATX main power cable's connector.
Looking at the photo to the far right in the link, shows the ATX main power cable plugged in.
Where the wires go into the connector is the BACK of the connector.
One end of the jumper wire, goes down into the socket hole with the Green wire, RIGHT NEXT TO THE WIRE.
The other end goes down into a socket hole with ANY Black wire in it.
The end of every wire going down into the ATX main power cable connector, has a metal terminal end.
This metal terminal end is pretty far down into the connector, from the backside of the connector.
For this reason the jumper wire MUST go down into the socket hole, far enough to touch the metal terminal end.
The most widely used jumper wire is a paper clip.
The paper clip is straightened out, then bent into a U-shape. Black plastic electrical tape is applied to the center of the U shape.
This taped area is for your fingers.
(One wrap of black plastic electrical tape will insulate you from 600 Volts DC)
The 'legs' of the U-shaped paper clip then go down into the socket holes.
The voltage is 5 Volts DC.
Two D cell flashlight batteries produce 3 Volts DC.
The voltage is VERY low, but there may be a small spark.
Warning you in advance.
Power supply comes on?
You have a bad Power On switch.
Power supply does Not come on?
You have a bad Power Supply.
For additional questions, or to clarify anything I have stated, please post in a Comment.
Regards,
joecoolvette
May 29, 2011 | Dell (E210882) Motherboard
On the right side of me JBL headphone doesnt work pulled the cord by accident
You must have broken the cable somewhere. If you move it around you might get it to come on, try it all over to determine where the break is. If very close to the headshell you might want to consider a new cable. If in the middle you can cutt it off before the break and fit a new plug. Then get an extension cable to complete the length.
If at the plug end follow what follows:
Cutt the old ******** and buy a new plug. Cutt it off 10cm before the plug end if the break is the plug section. Most hadphones are fitted with a 3.5mm jack. You will need to solder the wires on. You will find when you have baired back the cable two coloured wires and two earths. The earths fit together on the metal flange that comes out of the main body of the plug. The coloured wires go on the the two smaller flanges (left and right channels). If you get them wrong way round reverse them you won't do any damage. Make certain the earths don't come into contact with the R & L channels wires or terminals and the left or right don't touch each other. The T shaped end on the large flange is to grip the cable body, bend the tabs to grip the cable.
Mar 20, 2010 | JBL Reference 410 Headphones (Black)
1952 ford 8N tractor will not start. New plugs, wires, distributor and coil. Engine turns over but no spark comes to spark plugs
DID YOU REPLACE THE ROTOR BUTTON IF SO THE YOU NEED TO MAKE SURE THAT THE WIRES TO THE COIL ARE ON THE RIGHT POST ALSO CHECK THE WIRES TO THE DISTRIBUTOR TO MAKE SURE + IS TO + AND IF DOSE NOT WORK LET ME KNOW
Nov 14, 2009 | Ford 8N Tractor
Both symbol wires broken
i agree withe you about geting an electricin but before you get him maybe something wrong with the symbol wires or the television
Jun 27, 2009 | Nintendo Rock Band for Wii
My computer light turns on then off, no fan no screen
Changed the power supply and Power On switch?
New parts? Okay. We'll come back to them. For now, lets look over some simple things.
I can tell you that even after 20+ years as a tech, I still get a little zealous, when it comes to building computers. Sometimes we get into a rush, and overlook the simple things.
1.Are you sure the 20/24-pin motherboard power cable, is in tight, and down in there?
2.Are you sure the Front Panel connector, is connected right on the motherboard? Some Front Panel's have individual wires with terminal ends, that go on separate pins on the motherboard Front Panel header.
I'm asking are you sure the Power On switch is connected to the right pins, on the motherboard Front Panel header.
Everything good so far? Okay, lets look at the motherboard.
Look at the Electrolytic Capacitors on the motherboard. Specifically the ones that surround the processor. See if they show obvious signs of being bad.
Here is a link that will show you what Electrolytic Capacitors look like, and the visual signs of failure of them,
http://www.capacitorlab.com/visible-failures/index.htm
Good so far? Okay, lets check out that power supply, and at the same time, check out the Power On switch. Even if these items are brand new, they can still be bad.
I need you to make a jumper wire. This is to jump the Soft Power On, part of the power supply.
Wire needs to be like the power supply connector wires. That thick. It needs to have insulation on it. Should be 3 inches long, and have about 3/4th's of an inch of insulation, removed from each end.
Twist the ends tight, and into a pointed shape. Bend the wire into a U shape.
The 20/24-pin motherboard power cable, needs to be plugged into the motherboard. Where the wires go into the connector, there are socket holes. For every wire going down in there, there is a metal terminal end, on the end of each wire. The metal terminal end is pretty far down in there. Your jumper wire must go down in the socket hole, with the wire that is in the socket hole now.
You will see a Green wire, and a bunch of Black wires. The Green wire is the Soft Power On wire.
ANY Black wire is a Ground wire.
You want to jump across the Green wire, to ANY Black wire. (You can use the Black wire that is next to the Green wire. Just wanted you to know that you could use ANY Black wire you see)
Computer plugged into power. You may want to wear a glove on the hand that plugs the jumper wire in. The reason is that there will be a spark.
Not a big one, but I want you to feel safe.
Just stick one end of the jumper wire, down in the Green wire socket hole. Make sure it's deep enough to touch that metal terminal end. Now since the jumper wire is a U shape, just stick the other end in the Black wire socket hole.
You only want to touch it momentarily. Around 1 to 2 seconds. Then remove it.
If the power supply comes on, you have a bad Power On switch, or bad Front Panel header on the motherboard. If the power supply doesn't come on, you have a bad power supply.
With the power supply running, you can see if your motherboard is bad or not. I have seen VERY FEW motherboards, that have a bad Front Panel header. (Header is a -> Connector <- when referring to the motherboard)
Apr 28, 2009 | Smart Modular SV3170A
The blender coupling on my oster snapped in half. I have the replacement part already I just cannot figure out how to get the broken coupling off the base of the motor. I also got a replacement square...
10-01-2009 Sara - see solution for rlaymon 1-9-08 "Top part of base broke off" by TanyaCS on 1-20-08 - good ideas. I just fixed mine - 2 hour job + half hour to put a new cord in. Like TanyaCS my broken coupling was rusted to shaft - used WD-40 twice and let sit - meanwhile took out motor and removed fan - kept screws and washers in order on workbench (kitchen counter) - the fan hole is "D" shaped - fan end of shaft also "D" shaped - I filed a "flat" on the other side of the factory "flat" (side of 'D' that is straight) - Used big pliers on broken coupling and adjustable wrench on on the "flats" on fan end of the shaft. Broken end came right off. New cord is 18 gauge extension cord capable of at least 6 amps. Cut off the un-needed end. Or order a replacement cord $4 when you order the rubber drive coupling $4, pin with slinger washer $3. Bet you also need new rubber feet - didn't buy for mine - wish I had. Bert
Jul 11, 2008 | Oster 465 Work Top Blender
I replaced heater and thermostat and I'm trying to assemble....
There should be an open plug in for it where you removed the old one from. The flag you referred to on the end is a male spade connector. You should find it is a female end on a white wire.
May 13, 2008 | GE GSH22SGRSS Side by Side Refrigerator
Microsoft Xbox 360 Console Logo
35 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
