I have a sharp cd-dp2500,, my dad said he accidently arcd the speaker wires out and now it turns on, and contains a screen that read 'protect',,, i want to kno if any one knows how to prevent this,, i have discovered disconecting the wire harrness to the main power box will put it in demo mode,,, have tryed holding x-bass, play and the power button and got the clear all,,,, but still comes up 'protect' when power is swichted to play music,, has any 1 had this problem b4,, is there a fix? or do i throw it away????
  • 6,826 Answers
I checked sharp electronics website and could not find your model number to download the manual to read what 'protect' means.
Have you tried looking for a fuse in the back panel that screws in?
In the demo mode does it play any sound?
Does current flow out of the speaker cables that lead to the speaker where the cross occurred.?
Maybe you should consider just buying a new DVD system or Blu-ray Player with speakers on it.
good luck on repairing this problem.
Posted on Jul 12, 2010
LMy JVC CD player reads PROTECT across the screen even after resetting the cd player it still reads PROTECT, I'm so lost now because I don't have amps or anything attached just regular car...
Try checking your speakers and speaker wires for shorts and/or grounds. Make sure none of your speaker wires have any bare spots. If your speakers and speaker wires are fine, you may have a bad internal output ic inside of the deck.
Jul 14, 2011 | JVC AM FM CD DET FACE CAR STEREO
The display just reads "protect"
Protect is bad. It means the amplifier thinks it is overloaded. Check the speaker wires to make sure there are no loose connections or shorts.
Mar 01, 2011 | Sharp CD-BA2600 CD Shelf System
I have sharp cd pc3500 stereo system when i turn the power on the message on the screen shows PROTECT. I cant do anything nor any function work
Make sure the speaker wires aren't shorted together and that they are not freyed or cracked...the unit is in protect due to it's internal circuitry sensing a shorted output condition...this is in place to protect the unit should the speaker wires become shorted together. You can remove the speaker wires entirely and then turn on the unit to see if it comes on...if so then I would look at each wire carefully to make sure they look good..of course if the unit comes on and the wires look good then you may have a bad speaker component...Now, if the unit stays in protect after you unplug the speakers, then the unit probably has a blown audio output stage inside the circuitry and will need to be serviced.
Jan 05, 2011 | Sharp CD-PC3500 CD Shelf System
CD-DP2500 error 0306.Disk changer error. What is cause ?? I got it going OK! after having a good look around checking laser head connections. It seems to have arrived with warmup. I cant find error codes...
how to open the code I wrote that has protection and ... I do not know how to open the electrically operated lights notwill to caress the Power but notwill.
Mar 13, 2010 | Sharp Audio Players & Recorders
Says protect on screen
either too many speakers hooked up (bad ohm load) or internal flaw try unhooking speakers and cranking it up while playing if it stays on its the speaker wiring or even the speakers by themselves
May 19, 2009 | Sharp Audio Players & Recorders
My Sharp model no. CD-BA250 is displaying "protect". It will not turn off on or anything!! How do i clear it out to fix the problem.
Disconnect your speaker boxes. If the "protect" error goes, then the speakers or wires may be at fault. If the error remains, most likely the audio output IC is blown.
Sep 17, 2008 | Sharp CD-BA200 CD Shelf System
No volume
Protect is on because one of your speaker's or wires is shorted out. It comes on to protect the amp from frying, check ALL of your wiring and speakers for shorts to ground, NONE of the speaker wires should go to chassis ground only the stereos negative (-) speaker termina.l
Checking your speaker is easy, take a (D) cell battery and a couple of wires and connect the wires to the speaker, you should hear a click if the speaker is working properly. Good Luck
Leadispenser
Jun 10, 2008 | Kenwood KDC-MP235 CD Player
Sharp DP2500 speaker bus diagram
Hi..have you gotten an answer for this question...I just googled this model number..and about the second one down is the factory service manual...for the model you and I have...there is a way to go inside and solder wire to each speaker leg to make it work that way without the special plastic connector that was the original..
Apr 05, 2008 | Sharp HTDP2500 System
XL-MP60 Micro Component System
Email answer I got from Sharp:
I do apologize for the problems you are having with your audio unit. The protect mode
indicator will appear when the unit detects abnormal resistance in your speaker setup. I
recommend removing any additional speaker wire that may be added to the unit to extend the
factory speaker lengths. Also, make sure you have all the factory speakers attached, and all
non-factory speakers removed. Finally, please unplug you unit from he wall for 1 hour after
checking all of the above suggestions to completely reset your unit.
If you are still having issues after doing all of the steps mentioned above, the unit may need
to be evaluated by a Sharp Authorized repair center.
Nov 03, 2007 | Sharp XL-MP60 Shelf System
Won't start up
"Protect" error could mean one or both of the output IC's are defective. This can be caused if the speakers or the wiring have shorted. Try the unit without the speakers to see if it starts up.
Sep 09, 2007 | Sharp CD-BA200 CD Shelf System
130 people viewed this question
 Grubhead
Grubhead
