Question about Lexmark X83 All-In-One InkJet Printer
Printer I have a lexmark x75 all in one printer. I recently downloaded the driver and stuff for it. I have checked the ink cartridges but it is still printing blank pages. What is making it do that? Any suggestions would be great. thank's halllah19631@aol.com
  • 323 Answers
Click on start, programs, lexmark x85
Click the "cartridges" tab and check the ink levels.
You may have to allign the print cartridges to set the color up correctly.
http://www.lexmark.com/publications/pdfs/x85/en/user.pdf
Posted on Apr 20, 2008
Can no longer print
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
  2. Open the printer cover and remove both the cartridges.
  3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
  4. Close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first.
  7. Close the printer cover and check the light status.
  8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
  9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
  10. Load some paper. Try to print a document again to verify that the problem is fixed.
Dec 12, 2011 | Lexmark X75 All-In-One InkJet Printer
Printer has stopped printing blue
Make sure that you are inserting only genuine Lexmark cartridges in your printer. Removing then re-inserting the color cartridge into the printer is a quick to minor cartridge communication issues.
Make sure that your color cartridge still has substantial ink level for printing using the Lexmark Solution Center software on your computer.
Click Start > Programs > Lexmark X74-X75 > Lexmark X74-X75 Solution Center. Check the ink levels.
If color ink level is still good, then it probably just needs some cleaning. Print quality issues can be due to dirty or clogged print cartridge nozzles. From the Maintenance tab in the Lexmark X74-X75 Solution Center, click Clean print nozzles to fix horizontal streaks. Your printer will then print a test page. Try to print a color page again to verify that the problem with the blue color is fixed.
If the problem continues, try to insert a different known working color cartridge to identify if it's a faulty cartridge issue.
Oct 26, 2011 | Lexmark X75 All-In-One InkJet Printer
I can't see where the ink cartridges are on my Lexmark X74-X75
It is beneath the scanner. Lift the scanner and there should be a lid beneath that as well. Opening it will reveal the toner cartridges.
Aug 01, 2011 | Lexmark X75 All-In-One InkJet Printer
Lexmark X75.........computer can read the scanner but not the printer
Please ensure that the Lexmark X75 printer driver is properly installed on your computer. You can download and install the X75 printer driver by visiting the Lexmark website at http://bit.ly/iSpJjv. Select your operating system, download and execute the file. Follow the instructions on your computer screen.
Note: The Lexmark X75 printer is not compatible with Vista and Windows 7.
Jun 15, 2011 | Lexmark X75 All-In-One InkJet Printer
Black ink not printing even tho a new black ink cartridge was installed recently and working properly until I opened the unit to install a new color cartridge and now the black ink is not printing and the...
Try to reseat your cartridges. Unplug and replug your printer into the power source to reset itself. If that doesn't help, try to clean your cartridges and check if print quality improves. If you're using Windows, go to Start -> Programs -> Lexmark X74-X75 -> Lexmark X74-X75 Solution Center -> Maintenance -> Clean print nozzles to fix horizontal streaks.
Feb 17, 2011 | Lexmark X75 All-In-One InkJet Printer
Ink cartridge
you may check your ink cartridge
long time less using cause 3 color ink chanel(holes) a little dryer, could not print well even refilled.you may take out the color ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 -2 Hrs, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Jan 20, 2009 | Lexmark X75 All-In-One InkJet Printer
LEXMARK X75 BLACK INK STOPPED PRINTING.
When was the last time you changed the black ink on the printer? If it's been a while then I would suggest you change it. If you recently have changed it then you can try pulling the cartridge out of the printer and giving it a small shake. Put the cartridge back in and run an alignment operation on the printer. You can do that through the printer utilities installed on your computer.
Mar 26, 2008 | Computers & Internet
Lexmark X75 no color
even though you have ink coming out of the cartridge, if it's more than a few months since it's pumped any ink, it can be clogged internally, blotting with paper doesnt always work. Try a new cartridge, or buy a new printer, it's usually cheaper now to get a whole new printer than it is to replace a set of cartridges. consider it's a few years old now
Aug 16, 2007 | Lexmark X75 All-In-One InkJet Printer
X75 windows vista compatable drivers
Not really, If you like vista and dont want poxy xp back, then from vista install using Microsoft Virtual machine Windows XP, thiscanrun from within a window like any other app, just intall the bare stuff, and install theprogram you use to print from,and then install your printer, easy.
But ultimatley the 3rd party vendors do need to keep upwith the times, most other makes of printer will working without downloading any other driver, but Lexmark make there money on inks not printers, so they dont really care at the end of the day.
Just install VM ware or similar, install XP and printer, and your sorted.
Jul 28, 2007 | Lexmark X75 All-In-One InkJet Printer
Lexmark X83 All-In-One InkJet Printer Logo
44 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
