Question about Palm Treo Pro Smartphone
My reminder is not alerting me of appointments and when I take the battery out it puts my existing appointments 1 hour ahead of time... Why??? And how do I fix it???
  • 6,487 Answers
Base from the description of your problem this is a software related problem, so what we can do for this concern is to do a hard reset on your phone , but doing that will erase all data on your phone so better back first all data and then do this reset procedure.
1. Take the back panel off to expose the reset hole.
2. Press Power to turn on the screen.
3. While pressing and holding End, use the tip of the stylus or a small paper clip to press and release the Reset button.
4. Continue pressing and holding End until the Erase all data? prompt appears.
5. Press Up.
6. Wait for the progress bar on to fill up, then you can use the device again.
Posted on Jul 12, 2010
TEXT ALERT
I use SMS Popup (from the Play Store) for repeating text message reminders. It has other functions, but I primarily use the 'reminder' options. I'm not sure if you could (or should) do 5 to 10 second intervals as it would probably kill your battery. I think that 1 minute is the minimum. I guess you could also use a notification sound that is longer. You could even record your own. I once recorded myself coughing and used it as the notification.
Feb 08, 2014 | Samsung Cell Phones
Appointments off by one hour after DST
did you get the update for the new DST shift that happened a week early this year?
Mar 16, 2008 | HP iPAQ rx1950 Pocket PC
What does this alert sign mean?
There is a very un-used setting in your alert window you can setup and use when you are on the road for extended periods of time. It's call the rest feature. You can program in the amount of time you would like to drive before your car will remind you that it's time to take a break. To set/unset it go to your settings window, go to alerts and rest. Change it back to nill or "-" to unset it. That will stop it from popping up every half an hour (0.5h).
Feb 19, 2013 | Cars & Trucks
Turn off alarm for calendar?
As far is I can tell there is not a global setting for turning off the alarm on the calender. Whenever you create a "Schedule" event on your calender the default seems to be for a "Reminder" alarm to go off "On Time"; that is to say the alarm will go off at the exact of your scheduled event. However, when you first create a "schedule" event you can scroll down to "Reminder" and choose from "On Time", "10 Minutes before", "30 Minutes before", "1 Hour before" or you can choose the one you would want which is "No Alarm". You can also find options on that screen for controlling what kind of alarm you want including the choice of having a "Vibrate only" alert to you scheduled event. You can always go back and "Edit" any events that are already scheduled and deselect the alarm for those events.
If you don't want to mess with the different alarms and alarm settings you might consider creating from the "Create Event" menu either a "Task" or a "Note" for a particular date on the calender. There are no default alarms associated with either of those. Create "Note is very easy to use. Just select a date and you can enter the time and other appointment information in the "Note" area of the "Create Note" screen.
I hope this is a helpful solution for someone.
Jan 13, 2012 | Pantech Ease P2020 AT&T
Sony Ericsson T700 reboots automatically
how to unlock my t700 sony tel me pls
Nov 20, 2009 | Sony Ericsson K700
My 6120c nokia doesn't support the calendar appointment and reminders - always appear a message say "1 reminder or more missed because of change in hours" i stoped the automaticlly time adjastmenet but it...
soft rest your phone then setup your calendar appointments. the reset code is --->
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones.
Nov 15, 2009 | Nokia 6120 classic Cellular Phone
Removing/clearing message icon on my rumor!
In "Messaging" go into Voice Mail (number 1) and select Clear Icon (Number 3).
Go into Settings/Tools- Settings (#1)- Messaging (#5)-Notification (#1)- Change this To Icon only.
Still in Messaging, select Message Reminder (#5) and change it so it doesnt keep sending reminders.
If its telling you you have a text just go in each inbox and selcet Delete all... see if that helps.
Feb 25, 2009 | LG RUMOR Cellular Phone
Calender problem!
To add, change, or delete a Calendar appointment from the handheld, follow these steps: To add an appointment
  1. From the Home screen, press the Menu key.
  2. Scroll to and select Calendar.
    • NOTE: To select, press the trackball.
  3. Scroll to and select desired date and time.
    • NOTE: Selecting exact date and time will default to that date and time when the appointment opens, however these fields can be changed so any date and time can be selected.
  4. Enter a Subject.
  5. Enter a Location.
  6. If desired, select All Day Event.
  7. If desired, scroll to and set the Start and End date and time.
    • The 'Duration' should update accordingly.
  8. Scroll to and set Time Zone as desired.
  9. Scroll to Show Time As.
  10. Select one of the following as desired:
    • Free
    • Tentative
    • Busy
    • Out of Office
  11. Scroll to and set Reminder time as desired.
    • The options range from None to 1 Week.
  12. Scroll to and set Recurrence as desired:
    • None
    • Daily
    • Weekly
    • Monthly
    • Yearly
  13. If desired, select Mark as Private.
  14. If desired, select Notes, then type any notes.
  15. Press the Escape key.
  16. Select Save.
To change an appointment
  3. Select the appointment to be changed.
  4. Adjust any options as desired.
    • NOTE: The available appointment options are listed in the portion above.
  6. Select Save.
To delete an appointment
  3. Select the appointment to be deleted.
  4. Scroll to and select one of the following:
    • Open the series (for reoccurring appointments)
    • Open this occurrence
  5. Press the Menu key.
  6. Select Delete.
  7. Select Delete again to confirm.
I would recomend that you powercycle your phone regularly. If you have anymore questions feel free to ask me.
Apr 25, 2008 | RIM BlackBerry Pearl 8100
Time off by one hour
a pocket PC that still runs. wow. a blast from the past, 2000.
16 years it works ok , then today it fails?
you need to set time zones. and if you have DST , day light savings time in your unstated locations.
finding a manual on anything that old is problematic to you and most other helpers,
good luck with that.
Apr 12, 2017 | HP Jornada 548 Pocket PC
Blinking Green Ligh
Yes, this blinking green light is an appointment notification. So if you set up an appointment for September 30th, 2005 at 9:00 AM with a reminder set to 1 day....then on Sept 29th at 9:00AM, the IPAQ will turn itself on and a reminder screen will appear on your IPAQ. After a length of time (the default of which I can't remember now) the Ipaq will turn itself off, but will leave that green light flashing. When you then turn the IPAQ back on, the reminder screen will again appear and you can choose to dismiss the reminder or snooze it.
Sep 07, 2005 | HP iPAQ HX2415 Pocket PC
Palm Treo Pro Smartphone Logo
19 people viewed this question
Top Palm Cell Phones Experts
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
