Question about OKI C5400 Laser Printer
Keeps giving "load custom and press online switch"
How do I get it back to printing without having to push online button every time I send something to the printer
5 Suggested Answers
SOURCE: Okidata 5100C error code 490:MP tray empty
remove toner from your printer see any paper or wheels are jammed or loose...
Posted on May 28, 2008
checkitright
  • 1362 Answers
SOURCE: Having to press paperfeed then enter to print
most likely the paper settings are wrong. it should be set to letter and plain.
go to the menu and look for paper settings
Posted on Oct 07, 2008
jmassengill
  • 345 Answers
SOURCE: Changed drum but it is still saying 'change drum'!
On some printers after you change the drum, you have to reset the counter so the printer knows the drum has been changed. How to reset the counter is as follows:
1. press the ONLINE button to return the printer to off line status.
2. press the MENU button repeatedly until the MAINTENANCE MENU is desplayed, then press the SELECT button.
3. Press the item button until DRUM COUNT RESET is displayed.
4. Press the SELECT button and the Drum Counter is reset.
Hope this helps.
Posted on Nov 10, 2008
  • 44 Answers
SOURCE: "490: MP tray is empty" message when trying to print labels from Word 2003
The MP tray referred to is the Multi Purpose tray and is located at the front of the printer. To access it, you need to find the 2 indentations at the side of the front feed assembly and pull them towards you. this then gives access to the MP tray. Don't forget to press the blue button after loading the paper. Your user guide/manual will give clear instructions and pictures. It may also be called manual feed tray. Once loaded with the correct paper press the online button and printing will start.
Posted on May 12, 2009
My printer reset button keeps flashing. i have switched it on and off and still does not work 1p3500
Hi there
Here How to Disabling Low Ink Level Notification for Canon IP and MP, the method to reset
Ink level notification:
1. Push “resume” for 5 seconds for canon For MPXXX you must enter to service
Mode.
2. Push Power switch then remove power cord.
3. Insert plug power cord while pressing “power switch” at the same time.
4. Push Start/reset by step 2 continue Wait display shown “0′
5. Push + change display from “0′ to “1′
6. Push colour button 2 times
7. Push Power switch again, Printer will print 1 page
8. Open cover
9. Unplug power cord
10. Take out ink cartridge #40 and #41
11. Insert plug again
12. Push power switch
13. Open cover (scan cover)
14. Insert ink cartridge #40 and #41 again
Enter to service mode for canon MPXXX
With the printer powered off but connected to a power source, press the Power
Button while pressing and holding the Stop/ Reset button.
When the Power is lit, press the Stop/Reset button two times while pressing and
Holding the Power button.
When releasing the Power button and the Stop / Reset button (regardless of
Order), the printer will move into a service mode. (Waiting for menu selection)
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 20, 2010 | Canon PIXMA iP3500 Printer
Waste ink reservois is full
Hi
The waste ink are in the inside of your printer you need to get at it to clean out, but after this you got to reset it after you cleaned it or it will still not work, you may not have to get inside to clean it try this first to reset it.
Reset CANON PIXMA IP5000 printer To reset the counter or to find out about it’s reading you have to use the service mode.
Turn off the printer, push the resume button and keep on pushing.
Press the power button and keep on pushing. Now let go off the resume button,
but not the power button. Push the resume button twice, then let go off all buttons.
You are now in service mode.
To leave the service mode, give the power button one push.
Push the resume buttons once, after that the power button once.
The first information page appears.
Push resume twice, then power once: You get the second page.
Newer PIXMA-printers print the first page as a test for the nozzles.
The second page contains a lot of information.
Our advice: Print the second page before and after reset of the waste ink counter.
Only then can you be sure that the reset was a success.
To reset the waste ink counter right now, push resume four times and after that power once.
Important: Before starting with normal printing again, switch off the printer.
That gets you out of service mode.
Then switch on the printer again and print, as you like
Feb 02, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
Will not power back up.
Hi
Jan 05, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
After I press the Stop/Delete button...the ''resume '' (button which never has lit up), doesn't light up when I push it, and if I push ''print'' to print something new,it keeps reprinting the pages I have...
Have you tried resetting the print jobs in the system monitor screen? Or try just powering off the copier completely with the main power switch. Depending on the Canon model you have to clear the print/copy job from the sysem monitor screen.
Oct 18, 2009 | Canon Office Equipment & Supplies
Machine flashing load paper message even though paper is loaded
Hi ...
Most of the time this problem comes when the paper is not loaded correctly. Follow the below instructions to load papers to the cassette and I am sure this will resolve your problem. I will keep monitoring your responce and if required, i'll look for a work arround.
Follow this procedure to load paper / envelope in the cassette:
  1. Pull out the cassette from the machine.
  2. Remove the cover from the cassette.
  3. Fan out the sheets of paper so that they do not stick together.
  4. Align the edges of the paper.
  5. If the cassette is not yet extended, use your thumb to press the tab (indicated by the pink circular outline) and release the latch.
  6. After the latch is released, remove your thumb from the tab. Then extend the cassette until a click is heard.
  7. Load paper on the upper-right corner of the cassette with the print side facing down.
    Note:
    * Since the Credit Card sized paper, Canon Photo Stickers, and Legal sized paper cannot be fed from the cassette, load them in the auto sheet feeder (ASF).
    * When loading A5 or larger sized paper (nonstandard-size paper: 203mm / 8inches or more in length), extend the cassette by pinching the tab.
  8. Grasp the paper guide (A) and align it to the long edge of the envelope stack (2). Align the front edge of the paper stack in the same way (3).
  9. Close the lid and push the cassette all the way into the printer.
  10. Press the <Open> button and pull out the extension completely.
  11. Press the <Feed Switch> button to turn on the Cassette light.
    *MP500 shown.
    Note:
    If the Auto Sheet Feeder lamp lights, press the Feed Switch button to light the Cassette lamp.
    If the Cassette lamp does not light even after pressing the Feed Switch button, Paper Source in the printer driver may be set to the setting other than the Feed Switch button.
Loading on envelopes
Paper Type
Precaution
Envelope (DL / #10 )
Set paper with the flap closed.
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
  5. Load envelopes in the cassette with the print side facing down and the flap towards the left.
  6. Close the lid and push the cassette all the way into the printer.
  7. Press the <Open> button and pull out the extension completely.
  8. Press the <Feed Switch> button to turn on the Cassette light.
    Note:
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Oct 18, 2008 | OKI C5500n Printer
Oct 07, 2008 | Ricoh Aficio AP410N Laser Printer
Paper Out Sensor Not Working
try pressing the load/eject button and switch off the printer then switch on again
Jul 25, 2008 | Epson LQ-1050 Matrix Printer
Cannot Install it Successfully
Restart you computer. Turn your printer off, wait 20 seconds and turn it back on again. Load up software you use to talk to the printer.
What interface are you using to connect to the printer?
Jul 17, 2008 | Star Micronics TSP400 Label Printer
Red light on my hp photosmart 7850 keeps flashing
Same problem red light flashing and a picture of a little box with an arrow pointing right in the screen??? what the hell does that mean?
Nov 22, 2007 | HP Photosmart 7850 InkJet Printer
OKI C5400 Laser Printer Logo
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
