Question about Dryers
Hi i have a 10 year old dryer that is taking upwards of 2 hours to dry a load of cloths, i have taken the machine apart and cleaned it completely, the vent is clean, so i know its not a venting issue, when i use the auto dry setting the timer never moves and it will run forever, when i use time dry is takes up to 2 60 minute cycles to get the cloths 80% dry, does anyone have and ideas? i've read that the coil's could be bad, the "gas dryer" sensor could be bad... Please help the wife is getting pissed cause i cant figure this out
  • briyouu Jul 12, 2010
    does anyone else have a differt idea of my problem?
  • 6,784 Answers
HI. I suspect that the issue will be the actual timer control module. With that said; I will list all the possible areas of concern that will need to be inspected.
1. Monitoring Thermostats - Most dryers have a choice of temperature settings, therefore a separate thermostat is used for each setting. The selector switch and timer control module then routes the circuit through the appropriate thermostat. If a thermostat fails, it may prevent the heat from coming on, This happens because the thermostat does not close the circuit when the temperature falls below the operating temperature of the switch. It is a simple matter to test a thermostat; it should show continuity when the switch is cool and no continuity when it is warmer than its rated temperature.A thermostat can also fail by being always on, no matter what the temperature. This switch would show continuity whether it was hot or cold. In this case, the heater will not shut off and the the dryer could dangerously overheat. As a safety precaution a second thermostat is used, This is called a Thermal fuse. The power will be cut to the heating circuit if the maximum safe temperature is exceeded. In most cases, this is a one time fuse. The heater circuit(Burner Assembly) will not function until the fuse has been replaced. Of course, it will be necessary to determine and repair the underlying cause of overheating or the fuse will just burn out again. The most common cuase of overheating will be a clogged ventilation assembly. Be sure to inspect the entire ventilation asssembly for build up. This will cuase issues, if obstructions exsist.The thermostats are usually grouped together. The are typically oval in shape and about an inch and a half in size. They may be on the blower housing, under the lint trap or inside the vent line or burner chamber. There should be two wires connected to each thermostat.Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals. You may need to use a pair of needle pliers to remove the connectors. Once the connectors are removed,Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.To test the thermostats or fuse, set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity. Replace the thermosate that failes this test. If all thermostats past this test, move on to step two.
2. Timer - This device is the principal power commander. This device works in conjunction with the selector switch and monitoring thermostats. If this device fails, there will be fluctuation in the heating cycle or no heat at all. Once you have gained access to this device and its connections; Take a close look at the timer motor control. Depending on your make and model, there may be a number of wires connected to it. Locate the wires that deliver power to the mechanism. These wires should be slightly larger in size than the other ones. Use your needle pliers to remove one of the power leads. Pull the connector off the terminal by pulling on the connector, NOT the wire, or it may break the wire off(Not good).Next;Lift the dryers control panel up and set your units timer to a normal dry cycle. If your multimeter came with alligator clip probe adapters, this will be great here, so put them on if you have them. If not, any meter(ohm) will do.Set the multimeter to read ohms (usually labeled R1 or RX1). Clip or touch one probe to the terminal from which you removed the wire. Touch the other probe to one of the other terminals. You should get a reading of zero. If you get a high reading, then the timer motor is bad and it's time to replace it. If the timer proves to be in good condition, move on to the last area of concern(step3)
3. Burner assembly - On the gas valve are one or two coils (solenoids) used to open and close the valve to control the flow of gas. If a coil fails, gas will not flow and the dryer will have no heat.The easiest way to diagnose a problem in the burner assembly is to observe the burner operation. Remove the small access panel at the bottom, front of the dryer, select a high temperature setting and start the appliance. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. Next you should hear the click of the gas valve coil and a flame should ignite. The flame should be mostly blue and it should remain on for a minute or more.If the ignitor glows for several seconds (up to 15 seconds) and then goes out, the problem is probably the coils (solenoids). If the ignitor glows and stays on, then the problem is usually the flame sensor. If it ignites and then quickly goes out, it is most likely a problem with inadequate air flow.Test the coil for resistance using a multimeter. Set the multimeter to the ohms setting X10. Place a probe on each terminal. The multimeter should change from a reading of infinity to roughly 1300 ohms (+/- 150 ohms) when the probes touch the terminals. If the reading is infinity or substantially different from 1300 ohms, the solenoid should be replaced.
NOTE_ Use extreme caution during your testing procedures. You will find the culprit in one or all of the areas stated above. Be sure to unplug the unit before you begin.
Posted on Jul 12, 2010
  • Dryers Master
  • 19,396 Answers
Hi.
Re:"i've read that the coil's could be bad, the "gas dryer" sensor could be bad"
In both situations you would have no flame at all, if the valve opens and the dryer ignites, then coils and flame sensor are OK.
If the machine is taking a long time to dry, or if flame is on and machine heats very poorly or run forever, replace the set of thermostats. Thermostats are located in air duct, near to the burner, or on the exhaust, you have two or three of them.
First ensure you have checked filter, vents and duct and removed lint.
To get parts and diagrams use the links below:
Where do I find parts and diagrams for my...
    ya its all clean, i spent over and hour with the air gun cleaning everything out, you dont think its the sensor near the burner assembly?
Takes too long to dry clothes
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
WD 9900 does not dry
Most all dryers, including combo washer/dryers, have an electric wire coil for a heating element.
I suspect yours has given up ( they usually break in two, stopping the electrical flow). You should need to have the element replaced.
Going to need to take the whole machine apart to fix this.
Be blessed.
Apr 17, 2013 | QuietLine WD-9900 Front Load Washer /...
Takes forever for the clothes to get dry. It use to take a little more than an hour for my clothes to dry but now it takes three hours or more even with a very small amont of clothes in it!
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
May 03, 2011 | Fisher and Paykel Dryers
My dryer is taking twice as long to dry a load of clothes. It is approximately 5 years old.
If your
Dryer Maintenance
heatman101
Jan 30, 2011 | Whirlpool GEW9250 Electric Dryer
The Dryer heats up but does not completely dry clothes. It takes 2-3 cycles to dry them.
If your
Dryer Maintenance
heatman101
Jan 30, 2011 | Kenmore 63942 Dryer
It takes hours to dry a load moderate to heavy load of wash. There is definitely heat, so the heater element is doing something--but apparently not enough to dry the clothes in a reasonable amount of...
heatman101
Nov 21, 2010 | Dryers
My dryer takes too long to dry clothes. It could take up to 4 hours to dry a load of towels on high setting. What could be the problem?
heatman101
Oct 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My Kenmore dryer heats, but not enough to get the clothes dry. Do you know what I should check if it takes 2 complete cycles to dry a load of laundry?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 07, 2010 | Kenmore Dryers
My new whirlpool dryer model WED5300VW0 Ser MO3398130 does not dry properly. It takes 2 hours for a load of towels to dry and even light loads do not dry properly. I just had my vent under the house...
heatman101
Aug 31, 2010 | Whirlpool LER5636P Electric Dryer
Takes 3 hours to dry a small load, dryer is 3 1/2 yrs old
You need to clean vent hose and vent line in wall of house.
May 08, 2009 | Dryers
Dryers Logo
22 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
