Question about Whirlpool LGB6300 Gas Dryer
Stop heating after 10 minutes
Needs to know how to get to the gas valve to ckeck for proper function..
    Guru:
  • 366 Answers
Turn the gas on or you might have air in the line.
if that dont work check out the ignitor
Posted on Jul 12, 2010
Dryer not heating. Originally worked for 10 minutes then stopped. Cleaned inside - spotless. Installed brand new ignitor (glow type) old one was fine - didn't need changed. Worked for 10 minutes...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 07, 2011 | Kenmore Dryers
Kenmore Gas Dryer 11070852991. Have replaced the thermal fuse , operating thermostat, and High limit thermostat Still same problem . the dry starts ok egnites on and off for the 1st 10 minutes. Then stops...
bad gas coils,if you have heat for say the first 10 minutes then no heat you have bad gas coils located on top of the gas valve,when the coils cool down you'll have heat again this is what happens when they start to fail,also when you change them out on the large coil there's a metal spacer that should be on the post when you remove the coil if it isn't on the post look inside the coil you have to pop it out and slide it back on post part number 279834 remove the two phillips screws,and remove the metal cover,remove the wires from the coil and install the new coils,easy job as long as you know what to look for lol hope this helps you out and good luck
Oct 13, 2017 | Kenmore 74602 Gas Dryer
Whirlpool Estate gas clothes dryer runs but the heat only lasts for about 10 minutes. the drum will be turning the heat will be on but only for about 10 minutes.After 10 minutes the drum will still be...
The gas coils have failed. These are the two round devices on the gas valve. You would need to open the dryer to access and replace the gas valves. Every make and model is different.
With the model number I would be able to better assist you.
Mar 31, 2011 | Whirlpool Dryers
I have a whirlpool lgr5634a gas dryer, it heats up but does not seem to heat as high as it should.
possible of lint build up in the discharge vent vaccum/clean out first. next ensure the filter trap is clean and the below area is in the discharge area is cleaned out. also the sensor on the inside of the drum could be coated with sooftner causing the sensor that automaticly tells the dryer when top stop/ amount of heat to produce could be coated use isopropel alchol to clean and check after 10 minutes if the dyer is functioning properly at this time.
Mar 05, 2011 | Whirlpool LGR5634L Gas Dryer
Frigidaire crown gas dryer runs fine but after about 10 minutes it turns itself off and i cant turn it back on for about an hour
From the description you give the most likely cause of this problem are bad gas coils or a bad gas valve.
You say you see the flames for 10 minutes before it stops heating but you don't mention if the igniter is continuing to glow. One thing we need to know is if the igniter continues to cycle on and off when the dryer stops heating.
There is a small square plug on the front panel you can remove to try and visually check if the igniter is glowing.
The problem won't be the thermal fuse or one of the thermostats. Once the fuse is open the dryer won't heat but it won't start to heat after 20 minutes.
After the dryer runs ten minutes and stops heating then check if the igniter is still cycling on and off. This is important because if the igniter is working then the thermostats and igniter are okay.
When the igniter glows at some point you might hear a click and the igniter would stop glowing. The click is from the flame sensor and after the click and the voltage is removed from the igniter at the same instant the voltage is applied to the gas coils and you should get a flame.
You might hear a hum, buzz or vibration from the coils when this happens. If the coils seem to react to the voltage but there is no flame then most likely the gas valve is bad. If the coils don't do anything then most likely the coils are the problem. The gas valve and gas coils can work for 10-15 minutes and then heat up and stop working till everything cools down.
One other thing I must tell you about the gas coils. Here is a link to the gas coils you will need. These are the new style that will last quite a bit longer the the older one. The coils are like the spark plugs in your car. The will need replacing in time due to wear. Below is a video to walk you thru the repair process.
utube.png You-Tube video "RjonjNitfVk" placeholder
Jan 09, 2011 | Frigidaire GLGR642A Gas Dryer
Have had a repair man out 3 times. Replaced igniter and gas regulator. Dryer will heat for a few minutes then stop heating. When I try to turn it back on, it will not turn on at all for about 10 minutes.
Are you saying the dryer will not start again after a few minutes? That is a motor [problem. Replace motor.
Are you saying dryer starts after a few minutes but will not heat? That is an air flow problem or a gas valve coil problem. Thoroughly clean EVERY single air passage in the dryer and vent tube. If that does not cure it, then replace gas valve coils if the igniter comes on and off.
Jul 02, 2010 | GE DCVH515GF Gas Dryer
Hi. Brivis Buffalo not igniting
Okay,
first and for most do not light burners manually, if that chamber is filling up with gas and you light that sucker you risk the chance of causing an explosion or a blow back that will burn you. What you need to address is
-are the burners clean
-is there proper gas entering the gas valve
-is there proper gas to the manifold
-is the flue product being exhausted properly
-is my exchanger sooted up
-is my gas valve working properly
pm me for walk through steps
May 27, 2017 | Heating & Cooling
Dryer starts with heat. After 10-15 minutes, when dryer calls for more heat, here a metal clicking noise, flame does not ignite. When it's clicking, I can look down the back from the top and see a glow....
Your gas valve coils are defective. Part #694539 and 694540 are required. Once the coils get hot they collapse internally and the gas valve shuts off. This is a common problem when valve coils get weak from use.
Nov 09, 2009 | Whirlpool LGQ9857L Gas Dryer
Dryer heats up ,then loses heat after 10 minutes
Based on your description, you may have a Gas Valve Coil failure. Below is a link, courtesy of www.repairclinic.com, showing the part(s) involved. http://www.repairclinic.com/SSPartDetail.aspx?s=b4a8c237i3479&PartID=3479
More assistance below: You will need your model number to access the information.
Model Number Locator Tip
1. A zero in the model number might be the letter O.
2. A lower case L might be a 1.
3. Some models have 3 digits and a period first, like this 555.66666666
Look for an aluminum tag--or a silver and white adhesive label in the locations illustrated below. The model number may be printed or stamped onto the tag and may be printed in different type sizes. NOTE: There may be partial model numbers on marketing stickers or in the owner's manual. These are often incomplete. For best results use the model number from the tag.
1. Parts Breakdown/Disassembly Procedures: http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
2. Diagnostic tips: If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Aug 27, 2009 | Maytag Dryers
Whirlpool LGB6300 Gas Dryer Logo
60 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
