Question about GE WSXH208A Front Load Washer
Front load washer GBVH5140HWW blown fuse of resistor on main control panel is burnt so I cant tell what size to replace it with
4 Suggested Answers
Illeagle
  • 525 Answers
SOURCE: dead Maytag washer
You will need to replace the lid switch assembly, not just the fuse. Below is a link that will go directly to an enlarged image of what you need, along with ordering and shipping information.
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1468&PPStack=1
Note: Lid switch adjustment may be required when installing new kit. If instructions do not come supplied with the kit, post me back and I will try to guide you through it.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 18, 2008
  • 116 Answers
SOURCE: How do I remove the selector knob on washer
The main selector control know spins off by turning the selector inner knob counterclockwise. The outer ring will then pull off. The other knobs are held on with friction and should just pull off.
The best way to get behind the front panel is by removing the top panel of the machine. There should be 2 gray/solver tabs at the back of the machine near the top if you remove the 2/4 screws from the top then the whole top panel will slide forward then lift off.
Be sure to unplug the machine first.
Posted on Aug 02, 2008
TheMobilian
  • 8220 Answers
SOURCE: I have a GE top
themobilian_130.jpgThe new part has a clip in it that holds it to the shaft of the timer. Installing it is so easy. Just slip the new knob on the shaft of the timer. IF the shaft is still on the timer. Did you mean the shaft came out of the timer? In that case you would need a new timer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Nov 13, 2010
My LG washer stopped mid-load at spin cycle, how can I fix this?
It sounds like a serious fault if there is no power the fuse has gone or some item has burnt out . You will have to arrange for a service engineer to look at it more closely.
Apr 28, 2015 | LG WM-2277HW Front Load Washer
When I push "Start" on my Maytag Neptune front load combo, it lights up, the door locks, then it starts filling and after few secs it cuts off, what can I do?
If this is a combination washer dryer (model number starts with MLE). First disconnect the power to the unit and locate the main control board located on the top right hand corner. You can remove the two 5/16 screws holding the top of the front panel and move the front panel forward to remove the other two 5/16 screws holding the front of the top panel. Once these are removed there is one more 5/16 screw holding the board in place, remove the screw. Now lift the top panel and pull out the board with the wire harness. Search for the resistor R11 on the board (it's towards the middle). If this resistor is burnt, replace the main board and the wax motor located inside the latch mechanism ( it will have a red/burgundy color plunger which will be replaced with a wax motor with a black plunger). If R11 is intact, look closely at the latch system, and replace it if needed.
Jan 09, 2015 | Maytag Neptune MAH5500B Front Load Washer
Why is my GE front load washer is non responsive. The control panel went blank. Not a power issue since the outet is good. Model GBVH5140HWW
It could still be a plug or wire problem but if not a power problem inside the machine or a printed circuit board or other internal failure. It will not be possible to diagnose the problem without a lot more inforamtion.
Sep 12, 2014 | Washing Machines
My maytag washer stoped during the cycle with 8
You may have blown the internal fuse located in the lid switch. Could be you over loaded the washer and blew the fuse.
Unplug the washer and remove the four screws holding the control panel front in place. Two screws on top and two screws under control panel.
Remove the control panel and tilt forward.
Locate the lid switch assemble and remove glass fuse and inspect.
Door switch assembly should be replaced. When you order the proper fuse it should come with the door switch assembly.
Replace assembly. Reinstall the front control panel and four screws.
Plug machine in and test.
Jan 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune front loader washer has NF error code
Does it agitate and does the door lock light come on? Theres a panel on the back you can take off via 4 screws. Here you can check the belt and watch to see if it spins or moves at all. If the door lock light comes on, and you here the door click. Than chances are your motor control board is bad. Seen this many times. Im actually replacing one tomorrow on the exact washer.I believe the part # is 22004045. Heres a diagram. If the door doesnt lock than you need either a lock assy or a new computer for it. The computer is in the top panel where the timer is. If you look at it you should see a burnt resistor. If no burnt resistor than its more likely th lock assy. Ill try and find the part # for the lock and computer, and a digram. Hope this helps. Dave www.washermd.com
Dec 19, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer will wash but not spin
Sounds like the control board is bad. take the back panel off the control panel and look at the R11 resistor and see if it burnt. If it is replace the control board and the door wax motor (in the locking mechanism)
Nov 21, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune m/n MAH3000AWW burnt R11 resistor
STOP
There is a short in the door lock (very, very common problem )
Go to ebay and search neptune washers and im sure youll find a site i was selling a kit to repair this. If you cant find it let me know ill look .
Jan 18, 2008 | Maytag MAH6500 Neptune Front Loading...
MAH5500BWW model fuse blown
You probably need the motor conversion kit 12002039. This Neptune motor / motor control board has a high failure rate. To determine this you need to remove the front cover and inspect the motor control board near the floor on right side for burnt components or a blown 10 amp fuse. If you have burnt components or a blown fuse then your motor control board has failed and needs to be replaced. See www.neptunewaxmotor.com for Neptune disassembly pictures and other neptune information.
Dec 31, 2007 | Maytag Neptune MAH5500B Front Load Washer
Neptune MAH3000 Stops
did you just replace the fried part or did you get the board kit guest you may have a bad tacogenerator in the motor check the resistance of the motor
Dec 12, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front load washer (top of the line)
some of the early washers had problems with a weak or faulty motor . take front panel loose and look at motor board it may look burnt on some of the resistors or look at the clear fuse at front of board it may be burnt if so use a motor/board conversion kit p#12002039.
Oct 26, 2006 | Maytag Neptune FAV6800AW Top Load Washer
GE WSXH208A Front Load Washer Logo
178 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
