Question about Akai LCT2060 Television
Osd timer turns tv off while watching i believe, sleep timer is off and osd timer is on 60s
  • Akai Master
  • 8,457 Answers
Used the remote,make sure the osd timer is off the 60s will not auto tv turn off.
Posted on Jul 12, 2010
My apex tv shut itself off and it will not turn back on. I watching tv and it shut itself off and will not come back on. I do not have an remote for it.
i believe your sleep timer is still set.. go to the menu and find your sleep timer options turn on or off with volume buttons..that should help
Apr 26, 2012 | Apex Digital AT2708 27" TV
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
My tv turns off after about 10 mins and sometimes a few hours for know reason
Ok not sure if this is your problem, BUT, I have done this before! If you hit the SLEEP button on your TV's Remote control you may be setting the SLEEP TIMER on your TV. It is made so you can watch a show and fall asleep on your couch and the TV will shut off after a specified time. On mine it is anywhere from 30 minutes to 3 HOURS! My remote says the word SLEEP over the timer button. not sure on yours
Hope that solves the problem, just hit the button until the word "OFF" shows on your screen.
Feb 27, 2011 | Televison & Video
How do i set the timer? i use it for my alarm.
Which timer do you want to use? To use the On/Off Timer, press Menu and use the navigation arrows to select Time. Press Enter and navigate (up/down arrows) to select either On Time or Off Time. Press Enter and then use the up/dwon arrows to select Repeat. Select the frequency for the timer function (off, once, everyday etc.) with the left/right arrows. Use both the up/down and left/right arrows to set the time (hour or minute). Press Return to return to the previous menu and Menu to leave the OSD menus. For the On Time, you can also select the input source that will be shown when the TV comes on. (Select Input similarly to the above directions and set the desired channel if the source is TV.) The time must be for this to work (select Time and then Clock then Auto (gets the time from a digital channel) or Manual) and the TV must be in Standby mode for the On Timer to work. The TV will go into standby in two hours after coming on unless a button is pressed on the remote or the TV. The Off timer will override the TV On if they are set for the same time.
The Sleep timer is set in the same Time area or in the Q.menu (from the remote). Select Sleep time and then the length of time you want the tv to stay on before going to sleep. This is reset when the TV goes off.
The Shut-off time is set in the Time menu as well; select Auto Sleep. When this is on (on/off options), the TV will shut off after 10 minutes without a signal.
I hope this helps.
(you will have to reset the timer after a power failure)
Oct 06, 2010 | LG 32LG30 32 in. LCD HDTV
No action shutoff was activated. How do I turn
Go in ur tv menu go to SETUP.Check for Sleep timer might be on.This timer have setting like 30 60 120 mins.Turn off the sleep timer tv well not auto shut off.Check ur remote control might have a button said sleep.
May 28, 2010 | Panasonic TH-46PZ800U Plasma TV
HP 2338H Monitor Goes into Sleep mode and I have to power comput
you meant w2238w , right, you left off the w?
circa 2006 monitor, 11 years old.?
if the monitor fails on 2 PC, the monitor is bad ! ok, do that...
then
push the monitor menu buttton, connected to a running PC.
if the OSD is dead, , (on screen display , menu button front of monitor)
that means the monitor is dead, CCFL tubes are bad.
cold cathod florescient laml tubes all day this old.
the menu button can be in lock mode, hold the button for 10 seconds, and it unlocks
then go in the OSD screens if they work,. and turn off the sleep timer.
this timer is marked in the OSD as power saver,. turn it off.
it is a time clocked feature, and a pain to use on modern PC.
your PC does sleep modes today and never us this timer,inside monitor (default is on, turn it off)
all that is on page32 in your manual,
https://www.manualslib.com/manual/71500/Hp-W2338h.html?page=32#manual
Sep 21, 2017 | HP Computers & Internet
Television is turning off
go under you menu controls go to sleep timer and set it to off. if your tv control has a sleep button on it just press it until it say sleep timer off.
May 03, 2009 | Televison & Video
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Will not turn on
how many times does the light blink? There is a diagnostic set-up built into these Sony TV sets.
Apr 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Akai LCT2060 Television Logo
683 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
