Question about Plantronics Explorer 320 Headset
The Voyager Pro earpiece keeps beeping repetively
The earpiece for the Voyager Pro keeps beeping constantly- It has been charged. How do I make the beeping stop?
2 Suggested Answers
SOURCE: voyager 510 not working
The power on/off button is TINY and I missed it completely. It is immediately above the volume up/down button.
Press and hold it for a few seconds and see if you get a blue light on the mic bar. Same to turn off (red light).
To make unit recognizable to phones, etc press the teeny power button and the vol UP button at the same time. You should get rapidly blinking blue and red lights, which mean you can sync up.
Posted on Sep 07, 2008
Continuos (3) beep beep beep when voyager pro is turned on
Triple tones are usually associated with the battery having a very low charge. You should be getting approximately 5-6 hours of talk time and 5 days of stand by time from a single charge. If you are not, then the internal battery may be going out. The battery is hard wired and is not replaceable, however the headset does have a one year warranty from Plantronics and they will replace it within the warranty period.
Good luck from Headsets Direct - 800-914-7996.
Aug 17, 2011 | Plantronics Voyager PRO Bluetooth Headset
My Plantronics Blue tooth earpiece gives a constant "three beep" sound. I can hear the other person on the phone but the constant beeps at the same time. The beeps happen also when the phone is...
The three beeps usually indicate low talk time. If you have tried turning off and on your headset and still have the annoying beeps, then there is a problem with the device. You'll need to contact your retailer or Plantronics (800-544-4660 x5538) for warranty replacement. If it's out of warranty, check out our website Headsets Direct for the latest in Bluetooth headsets.
Good luck from Headsets Direct!
Jul 28, 2011 | Plantronics Voyager PRO Bluetooth Headset
The red light and blue light in on permanently. The earpiece has been charged all night but when I push the earpiece to sync, the blue light on top of the base doesn't flash therefore no connection. Please...
Unplug the AC power from the Plantronics 500A base, leave it unplugged at least overnight if possible, no lights should be illuminated on the base. Then plug the power back in, charge the headset, and try re-pairing the headset to the Plantronics 500A base unit. Here is the link for the pairing instructions:
Plantronics Voyager 500A User's Guide
Apr 02, 2011 | Plantronics Voyager 500A Deskphone Adapter...
I have a Plantronics Voyager Pro and it will not take a charge. I plugged the charger into my phone to check it and it does work on my phone except not with my blurtooth. Thanks for your help.
If you have the Plantronics Voyager Pro headset, you should be using the ac adapter that came with the headset ( model 79414-01 ). If the headset will not charge, it could be broken or the internal battery may be worn out. Keep in mind that the Voyager Pro has a one year warranty, and Plantronics will replace it within the warranty period.
Plantronics Voyager Pro Headset
AC Adapter for Voyager Pro Headset
Feb 28, 2011 | Plantronics Voyager PRO Bluetooth Headset
I need to pair my plantronics (voyager) earpiece with my new phone. I don't have my instructions anymore. I cannot get it paired up with my phone. How do I do that if I don't have the numerical code for...
hello, . Press and hold the power button until the indicator LED flashes red/blue. The Voyager Pro headset is now in pairing mode. If you don't see the red/blue flash, press and hold the power button to turn your headset off, and then press and hold the power button again until you see the red/blue flash. try 0000 as the code good luck
regards
shaun
Oct 10, 2010 | Plantronics Radio Communications
Constant beeping in your ear when making a call, even though the phone is fully charged and new batteries have been put in
There is no problem with the battery, but in your earpiece, try replacing new earpiece.
Sep 16, 2010 | Lands Phones
Earpiece slipped off the plantronics bluetooth,and i want to know if there is anything to help put it together again.
my plantronics 510 voyager did the same thing. try putting the earpiece back on to the main bluetooth and wrapping a small rubber band BETWEEN THE TWO. the object is to put some opposing pressure on the earpiece to force it to stay on. it'll work at least till you get anoter earpiece
Oct 05, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics voyager 500a
With these units, if the earpiece battery is allowed to run down, it will switch off. When the earpiece turns off the base station starts to search for it, which is indicated by the flashing red power light. Also the blue light on the top of the base will turn off. The first step, which you have already done, is to charge the earpiece. Next, hold down the little black button that is on top of the earpiece for about 5 seconds. You should get a slow flashing blue light on the mic boom. Wait for about 10-20 seconds and the base should automatically find the earpiece. The red power light on the base will be steady and the blue light on top of the base will come on.
Sep 12, 2008 | Plantronics Voyager 500A Deskphone Adapter...
Plantronics Explorer 320 Headset Logo
740 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
