Question about Kodak Easyshare M381 Digital Camera
Kodak M381 easy share camera the lens is stuck and won't retract even when the camera is turned off.
    President:
  • 1,382 Answers
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Posted on Jul 12, 2010
My kodak easy share cameras zoom lens is not retracting so the camera is not turning on
When a lens got stuck, by whatever reason, the camera shuts down to prevent further damage to the lens construction. If you can't move the lens at all. PLEASE DON'T APPLAY ANY FORCE TO THE LENS, just feel, try to find out what is holding the lens. If you can't see anything, the defect can be on the inside. This can't be changed easy. I don't believe in shock therapy, because you could help the lens to move once, but when something is wrong, it will happen again and the damage will add up.
But perhaps your camera is not turning on and that is why the lens does not move?
Did you try recharging the battery? And check if the battery has enough power?
Try that first.
Jan 08, 2014 | Cameras
Camera powers on and dies immediately
There was a problem with your Kodak system which is very critical to do it by yourself. It is better to check it with Kodak repair shop.
Please rate me solved if you like my solution.
Best regards,
Philip
Nov 13, 2007 | Kodak EasyShare C633 Digital Camera
My Easy Share C533 camera will not turn on. I just replaced the batteries.
make sure batteries are in the correct position, if the camera has a retractable lens make sure its not stuck in the out position if none of these are the cause then you may have to send it in if its under warranty if not then its most likely possible you have a dead camera
Feb 07, 2011 | Kodak Easyshare C813 Digital Camera
My Easy Share (Z730) is in the open position & will not close.
VERY COMMON WITH EASY SHARE. There are only a couple things you can really do. FIrst, try removing the memory card and try it. Than if that dosen't work. Try holding power button while gently wiggleing the zoom.
May 30, 2009 | Kodak EasyShare One Digital Camera
Camera lens extended and blue light comes on. That is all. Cannot turn light off or retract lens Kodak Easy Share Z1285
The Lens Barrel gears are damaged ...... Get it changed by a repairman please
Oct 16, 2008 | Cameras
I have a Kodak Easy Share M1033. I turned it on the lens extended but now the camera's stuck. I can't turn the camera off at all.
Try the Kodak Easy Share web site and look for trouble shooting FAQ'a or even an on-line forum.
You also might e-mailing or calling their tech support.
Jul 18, 2008 | Cameras
Kodak easy share z612 will not turn on to take a picture
When the battery dies, usually the camera will retract the lens if possible. If the battery is so dead the lens can not retract, I would recommend trying to charge or change the battery. Or try to turn the camera on, and then manually shutting it off if you can.
Nov 16, 2007 | Kodak EasyShare Z612 Digital Camera
Lens will not retract
I had exactly the same problem and I went to this site and got my solution. I banged the bottom of the camera with my palm and turned it off and on at the same time. On about the fourth bang the lens retracted and cleared the error codes. I know, "Caveman Maintenence" but it worked. Can't hurt to try...
Dec 10, 2006 | Kodak EasyShare CD33 Digital Camera
Kodak Easyshare M381 Digital Camera Logo
370 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
