Question about Dishwashers
Kenmore elite ultra wash dishwasher #66516572,green light flashes 7 times then phases. cant clear help! lee
  • leesurf Apr 20, 2008
  • 427 Answers
Look for a reset button, or manually reset it, buy unplugging it. Refer to the owner's manual or call customer support.
Posted on Apr 20, 2008
  • Michael Lake
    Michael Lake Apr 20, 2008
    Did you look at the trouble shooting manual or try to contact customer service?
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Jan 18, 2015 | Kenmore Dishwashers
Kenmore dishwasher won't restart, green light flashes 7 times
Unless you have already tried the fix on this site, please see if you can reset your dishwasher. It appears to be linked to dishwasher not being able to heat water to correct wash temperature.
Apr 29, 2014 | Dishwashers
My Kenmore Elite Ultra Wash Dishwasher keeps shutting off before entering the cycle. I have repositioned dishes, even emptied it, changed cycle and tried everything. When I press the start light flashes...
I too had problems with the Kenmore Elite (aka Bosch). The issue was solved by replacing the Lock Sensor on the door. After replacing the sensor the dishwasher has been working. Hope this helps.
Oct 08, 2013 | Kenmore Elite 24" Built-In Dishwasher with...
My Kenmore Ultra wash dishwasher will not cycle.....the green clean light keeps flashing. How do I reset the cycle?
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Apr 11, 2011 | Kenmore Dishwashers
Hi. I have a Kenmore Elite Ultra Wash with Quiet
This may or may not help in your situation, but the following link explains how you may be able to clear the blinking clean light problem:
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Aug 19, 2009 | Dishwashers
I have a kenmore Elite Ultra Wash Dishwasher that won't run. The lights for the various wash and dry options come on, but when I push the start button, it flashes green three times and then goes off.
Sounds like a safety - lock is operating.
Close and press start button - keep button derpressed untill machine actually starts - maybe 8 seconds or so.
If this does not do it, unplug for 24 hours then try again.
Aug 04, 2009 | Dishwashers
Four hour delay light flashing
I have a kenmore elite dishwasher and the 6hour delay light is flashing and no other buttons work when I push them.. whats wrong?
Apr 11, 2009 | Kenmore Dishwashers
My kenmore elite dishwasher will not start.
Thanks to another post, i found how to clear this code, by alternating between the High temp dry and air dry buttons the dishwasher went into diagonostics, then cleared. I found then that the washer would fill but not wash then it would drain. I found the motor was almost seized, I am replacing. The 7 flashes must be a code for the motor going on overload.
Oct 08, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Jun 08, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwashers Logo
123 people viewed this question
Top Dishwashers Experts
