Question about Amana NAV3330E Top Load Washer
Have an Amana washer NAV3330EWW. Making a lot of noice like a machine gun. Took front cover off and belt is well worn and flopping. There appears to be a racheting device that is making the noise. From what I could see any moving shafts seemed to be running straight. How do I get the belt off?
  • 163 Answers
SOURCE: change belt.
this is a easy job for a tech but a hard one to regular people have to remove the transmition and thats is by removing a nut in the tub, so better call a tech and pay for it, is not to espensive repair at least in my area...good luck
Posted on Aug 07, 2006
  • 57 Answers
SOURCE: Amana washer leaking.
Have your husband disconnect the power and water lines, pull the washer out and tip it back so he can check the hose connections to the water drain pump in the bottom of the washer. That pump should have two hose connections. In older machines, it is entirely possible that a hose has either come loose or cracked. If the hoses appear fine, check the pump itself for possible cracks. If all looks well, check the hose clamps for tightness.
Posted on Feb 23, 2008
Illeagle
  • 525 Answers
SOURCE: Amana NAV8800AWW making noise while running and spining
Spin Shake is usually contributed to a weak floor support condition. Also, carpeting under the leveling legs can cause a "spongey" effect, which can produce the shakes. Prolonged shaking can cause parts to loosen and make noise.Firstly, we must determine what loosened up from all the shaking.
Remove the front panel by removing the 2-5/16" screws located at the bottom front. Pull out at the bottom to release the top retainer clips, and set aside.
Warning! Never reach inside the machine while it is in operation!
Investigate the cause of the noise by setting the washer to spin, and turn on. Inspect all moving parts for possible wear or breakage. Next, stop the machine and inspect for loose or worn suspension parts, nuts, bolts, struts, hoses banging the cabinet, etc. A protective motor cover can cause noise, or a belt slapping the base mount. Once you have conquered your noise issue, then we will have to eliminate the shakes, provided, what you repaired wasn't the cause...and usually isn't.
Carpeting under the leveling legs should be removed or cut away.
If other items in and around the laundry room shake, then you will need to add support to your floor joists. Shim the floor from under the house while the washer is spinning for best results.
Your installation instruction manual should tell how level the washer properly, after you have added support to your floor.
Good Luck! Post me back if can be of more assistance.
Dave E. (Illeagle)
Posted on Jun 06, 2008
CMV9
  • 594 Answers
SOURCE: amana dlw330ra, loud and leaking
it sounds like you have a worn out seal under your washer. pull the washer out a bit and tilt it backwards. or put something under the feet so you can look under it. turn the machine on look while it is running and see if you can tell where the leak is... there are many hoses under the machine that can give out over time and start to leak. also there is a seal in the bottom of the washer that will wear out and leak over time due to ear and tear.
also if you do not see any water coming from the bottom of the machine pull it out and see if your hoses on the back of the machine are leaking where it hooks up to your water. there are seals inside the hoses that connect from your house to the washer. if those are weak the machine will leak from there... if that is the case than you just need to replace the hoses. they now have steel wrapped hoses that are very good.
Posted on Aug 11, 2008
sdmc73
  • 121 Answers
SOURCE: amana lw8252w2 changing belt
there are 3 screws that hold the pump to the moter but sometimes it is rusted so you may need to pri it off
Posted on Nov 29, 2008
How do you replace the belt on amana washer lw8203w2
To replace the belt, on the very bottom of the front you will see 2 screws. Remove them and the bottom cover will come off. You can then replace the belt.
Check the belt to see if it just broke or if have a worn spot on it. If it appears like it wore in one spot then you have another problem that needs to be addressed.
Jul 01, 2014 | Washing Machines
TROMM WM2277HW Front loader washer has an increasing louder spin cycle.
LOUD NOISES IN MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING,
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Jun 12, 2014 | LG WM-1832C Front Load Washer
I have an Amana washer model NAV3330EWW purchased in November 2004. The washer will not drain during any of the cycles, It apparently went through the entire wash without draining after the wash or...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 28, 2011 | Amana Washing Machines
My frigidaire gltr1670a washer is making a banging noise when on the spin cycle. I took the bottom cover off and watched the drum it doesn't seem to be from the outside of the drum cover it sounds like its...
It sounds like the spider arm supports in your washer has failed. The spider arms hold the stainless steel wash drum to the axle. You need to stop using the machine immediately since the wash drum is flopping around the plastic tub. It is an expensive fix. The replacement drum/spider can cost over $300 with shipping. Get a few estimates before deciding whether to repair or replace. Sorry.
Dec 09, 2010 | Frigidaire GLTR1670A Front Load Washer
Amana washing machine makes loud noice when trying to spin
sounds like you are dealing with the same problem as me .
take off the front panel (after unplugging power) take a flash lite and look at the large pulley at the back just below the pulley is the helix check to see if they are worn .
http://fixitnow.com/wp/2008/10/21/amana-washer-makes-loud-ratcheting-noise-during-spin-but-doesnt-actually-spin/
Feb 26, 2010 | Amana NAV3330AW Top Load Washer
My washer (ALW880QAW) agitates but does not spin. I took off the front cover and the found a black circular piece lying there (What it goes to I do not know). The belt looks okay. The motor goes in spin...
That is the drive coupler and it has worn out. You can order a replacement set that comes with two plastic retaining pieces that slide onto both your transmission and engine and also a rubber piece that goes in between these two plastic pieces. You can search many places to find out how to replace this part. I just ordered a set and shopped around a bit and mine was $20 after shipping.
Nov 29, 2009 | Amana ALW880WH Top Load Washer
Kanmore heavy duty super capacity washer does not spin and belt is off and stretched'
There are lots of appliance retailers online. It pays to shop around, but this is one of them that supplies your belt.
http://www.partselect.com/AppliancePartList.aspx?Brand=Kenmore&Appliance=Washer&ModelNum=&Type=Belt&MinSize=U&MaxSize=U&Electrical=N&Metal=N&Plastic=U&OneColor=Y&PageSize=15&FirstPart=1
Hope this helps.
If it solves your problem, please rate as "Fixya."
If it is of some help - then "Helpful"
Thanks.
Jun 14, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
My whirlpool awz410 is not spinning
if its draining while its filling ,raise the drain hose higher than the water level and it wont syphon.
May 01, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Amana NAV3330E Top Load Washer Logo
136 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
