Question about Garden
I have a 2 bulb 4 foot light and it has a 5 wire ballast that needs to be replaced. Can I use an 8 wire ballast? Is this possible?
  • Jeffery Crow Jul 13, 2010
    this ballast is for an older style t8 bulb so I went ahead and am now looking for a "wired" for 5 wires not 8 any ideas?
  • Jeffery Crow Jul 14, 2010
    YES! I understand. I had not run into a 5 wire before this (just a maintenance MacGyver without a producer) Thanks
  • 12,061 Answers
NO you cannot use an 8 Wire to power a 2 bulb, 4 Foot (40 Watts) UNLESS you can configure it to this format below. Each, Output wire should "Drive" one Tube if wired as below, You can drive a 4' from a 8 'or a 6' ballast, but not the converse, the Tube, will only "Draw" as much as it needs. Any unused can simply be taped up and made safe.
I have a 2 bulb - afd2e3b.gif A 5 wire ballast, has One IN, and 4 OUT. an 8 way has One IN and 7 OUT. It is NOT the amount of outputs it is the TYPE of Tube the Ballast can "Drive" For every Foot of Tube, that's 10 Watts, so a 4" Tube is 40 Watts, a 6" Tube, 60 Watts, 8" Tube is 80 Watts. That;s what is critical.
As you can see each tube really has only ONE "Hot" wire, and the Neutral, or return, With the other legs of the Tubes "Filaments" are, connected to the "Starter".
Posted on Jul 13, 2010
    Guru:
  • 1,051 Answers
Should not be a problem. The additional wires are for light units with more bulbs. Just make sure the new ballast has the same voltage rating as the old one.
Posted on Jul 12, 2010
  • Bob Korsu
    Bob Korsu Jul 14, 2010
    Make double sure the ballast you plan to use is not for a 240v line. The label on the ballast should indicate this.
I have a T12 fluorescent light fixture and replaced the bulbs and ballast. I have double checked all the wiring connections. I get the bulbs to light when I move the bulbs, but only for a second.
Your description sounds like the connectors for the tubes. Also RECHECK wiring. Different on newer ballasts. See below...
Turn off fixture, unplug, or deactivate fuse...
Pull out bulbs and the tin fixture cover/reflector.
Extract the bulb connector. Go to hardware and buy 4 more, and just replace them. The connections fail where the wire connects and the rigours of bulb replacements damage this piece. TONS easier to get new pieces.
ALSO!!!! many new (fancy schmancy) ballasts WIRE UP completely differently from the old ballast. Follow the wiring diagram on the NEW ballast. This detail trips up many.
Doc
Sep 13, 2016 | Photography
I have 4, 8foot lights to a single switch. once in awhile #1 will go out, next time 3/4 will go out, next two to four days they all stay on. Where is the problem? Thank You.
You listed this under Dimmers, I hope you're not trying to use a dimmer on these!
Since they can all stay on at certain times, it isn't the ballast that's bad. It's either the starters (if it has starters) or the bulbs themselves.
Are the bulbs a little black at one end? Then they should be replaced. Please dispose of the old bulbs properly as they have mercury in them.
4 8 foot bulbs even at 110W each is only 4 amps and most lighting circuits are rated at 15 amps since the 1960's, the switch is also probably rated at 15 amps. The circuit also depends upon what else is running at the time off the same circuit coming from your breaker box.
Aug 03, 2016 | Electrical Supplies
Sylvania ceiling lights in my Kitchen Not working i have new Light Bulbs that i have Got to replace it have put the New Ones in Still No light I have 5 Lights Not working Changed All 5 Now only 4 are...
Are the lights wired black to black, and white to white?
If lights are on timer or dimmer, make sure timer-dimmer are rated for type of bulb, and wattage
Some timer must have minimum wattage.
Use non-contact voltage tester to see if lights are getting power when switch is ON.
Check if wire nuts are tight.
Fluorescent? Look at ballast and see if black ooze is coming out to indicate that ballast is bad.
Check that bulbs are correctly held in place.
If one bulb is bad, others might no work. Replace bulb when it starts getting dark on the ends.
Incandescent? Check that light bulbs are good
Install new switch.
Check white neutral wire located in back of switch box and covered with wire nut.
Click breaker all the way off and then back on.
Nov 08, 2011 | Home
Light wont come on.....2 lights over bar, 1 lights, 1 does not
Install new switch.
Oct 31, 2011 | Home
I have a 3 bulb flourescent light that had two magnetic ballasts and I want to replace it with a T-8. What is baffling me is that from one set of sockets on one side there are 6 wires, 4 blue and 2 red and...
  • 1 Turn off the circuit breaker that's delivering the power to the light fixture.
  • 2 Test the feed wires with a touch-type voltage tester before you touch them. Press the button on the tester and touch the tip of it to each wire to make sure the circuit is dead. If the tester beeps or lights up then the circuit is still live. Try additional breakers until you find the correct one.
  • 3 Strip about 3/4 inch of insulation from the ends of each wire coming from the ballast if they aren't already prepped for wiring. Use the smallest setting on the wire stripper to prevent snapping the wires when you strip them.
  • 4 Take the single red wire from the ballast and insert its tip into one of the two pressure-slots on top of one of the sockets on the same side of the fixture that the red wire is facing.
  • 5 Take a 6-inch length of similar red wire and strip 3/4 inch of insulation at each end, then insert one end into the second slot on the socket that already has the red ballast wire attached and insert the other end into the other socket on that side.
  • 6 Insert the tip of one of the blue wires into the slot on one of the sockets on the other side of the fixture.
  • 7 Insert the tip of the second blue wire into the slot on the other socket on that side of the fixture.
  • 8 Connect the white wire from the feed circuit to the white wire on the ballast and connect the black wire from the feed circuit to the black wire on the ballast. Make sure the wire connectors are on tight and wrap electrical tape around the connections.
  • 9 Put the fixture back together and install the fluorescent tubes as per the manufacturer's instructions. Turn the circuit breaker back on.
  • Mar 25, 2011 | Kitchen Ranges
    How do you replace the fog light bulb on 2008 avalanche
      • 1 Open the hood and reach down into the engine bay for the fog light assembly. If you cannot reach the fog light assembly from the top you may need to get underneath the truck to reach it. Remove the electrical plug running to the fog light ballast.
      • 2 Remove the bulb. Unlock the fog light bulb by turning it counterclockwise and pulling it straight out of the assembly.
      • 3 Slide a new bulb into the fog light assembly. The part number you will need for the new bulb will be located on the ballast or base of the old bulb.
      • 4 Turn the bulb clockwise to lock it into the fog light housing.
      • 5 Reconnect the electrical connector to the bulb ballast.
    Jan 23, 2011 | 2007 Chevrolet Avalanche LTZ
    Two different size ultraviolet ballast. The .71AMP ballast feeds two 40W ultraviolet ''UV'' bulbs. The .37AMP ballast feeds one 40W ultraviloet bulb. The two light to larger bal;last want come on. The...
    I usually test the ballast simply by excluding everything else.
    1) Put in bulb that you know works
    2) Replace starter (if you have one)
    3) check that wiring is intact (sounds like it is for you but I had one light that the wiring barely made contact so sometimes it came on and sometimes it blinked)
    4) If all that is good, then it's probably the ballast.
    Sep 29, 2009 | Garden
    Hello...need help.. replaced 600mh bulb then
    Have you tried the switch yet? The plastic switches inside some ballast boxes don't do well with the heat produced by the ballast. You can try to simply bypass the switch and hard wire the ballast to the plug to test whether or not that might be your issue. If you need a new switch, just call Sunlight Supply directly http://www.sunlightsupply.com/hort/contact.aspx they should be able to send you a replacement switch.
    Feb 18, 2009 | Sunlight Supply 400 Watt Hps Sunsystem I...
    How to replace a tube holder or ballast
    You can replace a ballast or tube holder if you're fairly familiar with wiring. 1) Turn off the power to the circuit. 2) Remove the tube and the cover plate that conceals the workings. 3) Disconnect or cut the wires to the tube holder or ballast and remove. 4) Strip 1/2" of insulation from the ends of the wires. 5) Mount the component and connect the wires with wire nuts. 6) Replace the cover and tube. 7) Turn the circuit back on. 8) Turn the switch on.
    Jan 18, 2006 | StarTech.com CCTUBEGN 12.5''TUBE...
    Garden Logo
    29 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
