Question about Xerox Phaser 8400 Laser Printer
If scanner does not work will printer still work xerox 8560mpf
    Problem Solver:
  • 10 Answers
Yes as long as there isn't anything to cause an error message when the printer is booting up.
Harry
Posted on Aug 25, 2010
Tip
Disconnecting the Xerox c2424 Document Scanner
The Xerox c2424 Document Scanner has a very high rate of failure. After very limited use it can generate an error code of 39,012.40 indicating that the document feeder is damaged. Xerox's answer to 99% of the document scanner issues is to replace the unit. But while restarting or cleaning can possibly resolve this issue, it is also possible to just disconnect the scanner and use it independently of the document feeder.
Xerox documentation however, does not instruct the user how to do this and tech support won't walk you though it. (So, courtesy of Pastor Ray of Indiana) Listed here are the steps to operating the scanner without the document feeder:
(1) Perform a standard shutdown on the printer.
(2) Disconnect the Document Feeder from the printer IN THE REAR OF THE PRINTER. You still need the side connector hooked up, the one by the power-on switch, power plug, USB port and all the other goodies.
(3) Power up the printer.
(4) It should work. However...
If for some reason the printer won't copy, then just do what I did in my experimentation:
(2) Disconnect the Document Feeder from the printer in the rear of the printer.
(3) Physically remove the Document Feeder, leaving the copy platen visible.
(4) Power up the printer.
At this point you should be able to copy stuff.
(5) Physically reattach the Document Feeder, but DON'T reconnect it!
You should still be able to copy, scan, etc.
on Apr 16, 2010 | Xerox C2424 Copier
Xerox scanner device not found
You can download the Xerox printer/scanner drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.support.xerox.com/support/enus.html
Mar 28, 2012 | Office Equipment & Supplies
I have just upgraded my PC to iCore 7 with Windows 7 64bit OS, however when printing to Fuji Xerox Docuprint C2100, the gradiation on the photo is pixelated and not smooth. What printer settings do you...
Did you use plug and play or did you follow the install programs' directions? If you use plug and play, many features do not work.
If you did plug and play, uninstall the printer, download the current install program from Xerox (free), presuming they make one... Some printers and lots more scanners do not work with newer OS...
THEN, use the interfact that Xerox (likely) provides, to run the printer.
Newer printeres and scanners are now NETWORK based, meaning non hosted by a computer. You have to run installs on the printer AND every machine, but then anyone can scan, for example, as if they hosted the scanner.....
Feb 23, 2011 | Xerox DocuPrint C2100 Laser Printer
Xerox 510 windows 7 driver
sorry to say this according to XEROX this printer is not supported in windows7. May be you can try plugging in directly and using it it might work with preconfigured drivers
Nov 30, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
Xerox 6110 MFP scanner locked
The Xerox 6110 MFP has a green 'lock/unlock' slider on the "roof" of the "out" paper tray (under the front control pannel assembly); see images below. When slide to the back, it locks the scanner, and to the front unlocks it.
75884d7.jpg Front of the Xerox 6110MFP howing paper output tray and control panel.
7020767.jpg Xerox 6110MFP showing the output paper tray and the 'green' scanner slide lever in the roof of the tray.
Feb 24, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Help.... System error 09,036.44:11411
That is a magenta ink stick advancement failure.Look in your ink loader and see why the stick is notr advancing. It may be cracked, twisted or somehow just stuck. That code is telling you the ink stick is not advancing downward into the ink loader.
If you put in ink from a different phaser model, it will not read it either. To remove them, take a screw, like a drywall screw and twist it into the ink stick and back it out, then reseat the ink blocks.
Sep 22, 2008 | Xerox Phaser 8560MFP Laser Printer
Scanner problem
reinstall the driver for the printer from this site:::
http://www.support.xerox.com/go/results.asp?prodID=XK35c&Xlang=en_US&Xcntry=USA&Xtype=download&prodName=WorkCentre%20XK35c
Oct 23, 2007 | Xerox WorkCentre XK35C InkJet Printer
Xerox Phaser 8400 Laser Printer Logo
60 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
