Question about Refrigerators
We have a sub-zero 561 side-by-side. The freezer has not been staying cold (around 45F). We keep the condenser cleaned, and it's fan is running properly. We found that the freezer compressor keeps thermally cutting out. The surface temp of the compressor is about 140F when the thermal limit switch cuts it out. When it re-starts, it's drawing 4.6 amps and after it runs for a bit it levels out at about 2.6 amps. The refrigerant low side pressure holds steady at 20 pounds as far as we know the system still has R-12 in it. When the compressor is off the static pressure is about 60 pounds. Couldn't find any information on what the running or static pressures should be... so we recovered what refrigerant was in it and evacuated it and recharged it with 8 oz. of R-12 as per label on door jamb. No change in anything, the compressor keeps cutting out. Are we looking at a bad compressor or do you know of any other problem that would cause this? Frig side will maintain 40F, but the thermostat has to be set at 10. The compressor runs much cooler (100F) and draws 2 amps at start-up and runs or settles in at 1.5 amps. The low pressure is at about 28 psi and the static pressure is around 65. Our unit is completely built in with custom wood panels that match the cabnitery so we'd like to fix it if economically practical. The serial # is: P733870 installed February 1989. Thank you! Mar Gee Farr
    President:
  • 2,047 Answers
Usually there are a couple of issues which can cause this. The first thing you should check is the current which supplies the refridgerator if this is stable. If not then all you need is a stabilizer or an automatic voltage regulator.
If this is not the problem then the compressor is bad and should be replaced. With the age of the refridgerator this should be expected the thermostat should also be checked and replaced if the problem persists.
But on the whole if the system will be fixed by a proffessional it will be more economical if fixed as compared to buying a new set which will need new space and might now be as nice looking as the present state.
Hope this was very helpful.
Posted on Jul 12, 2010
Sub zero 690 side by side the vacume the condenser light keep on flashing after 12 hrs or so but the condenser is clean it could be my both door are not flushed together .Fridge side door is little out may...
It is likely the condenser fan is not functioning. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
Oct 18, 2013 | Sub-Zero 690 Side by Side Refrigerator
1988 sub zero refrigerator's freezer is warm on the top and not making ice
Sounds like you have a fan problem around the evaporator in the freezer, it is possible it has failed and won't move air within the freezer section anymore. Cold air drops and heat rises.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Mar 21, 2013 | Sub-Zero 561 / F
My freezer drawers are very warm All food defrosted smells horrible even after cleaning. Should I clean condensor, temp is not cooling?
It is likely the condenser fan is not functioning, or the condenser is dirty. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
Jan 01, 2013 | Sub-Zero 700 Refrigerator Freezer...
Sub zero freezer - 501 f
Jun 19, 2012 | Sub-Zero Freezers
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
Sub Zero 561 Refrigerator side is not cooling." the freezer side is working perfect.."
pop the top panel and clean your condenser,this is the most common problem,other than that it could be your compressor or refrigerant leak.this model i believe is two separate systems so one will not effect the other/. good luck!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 17, 2010 | Sub-Zero 561 / F
My sub zero 561/F has what I think is a noisy compressor. I would like to know how to get to the compressor and clean/lubricate. I believe the noise is coming from the top grill area. Don't know how to...
the grill has two and maybe three screws onthe under edge of it remove and lift up and tilt out / there is a spring holding it in place / remove and lif off .. do clean the condenser coil ( unplug or turn off power befre doing this ) vacuum the compressor area. you cannot lube the compressor as they are sealed .. the fan motor is generally the noisey . replace if so ./ clean both sides of cond and fan blades .. mm
Dec 03, 2009 | Sub-Zero 561 / F
I have a 20 yr old Sub Zero 561 side by side. The
If it were not a Sub Zero i would say its time for new. It sounds like it needs a service call and shot of gas and all will be well for many more years.
Sep 01, 2009 | Refrigerators
Subzero 632 cycles from 37 to 50 degrees
few things to check... condenser coil clean. dirty condenser fluctuate temp. clean condenser. evap fan motor work? open the fridge. press the switch. heard the fan? feel the frame around the fridge an freezer is hot? or cold? cold ok. hot dirty condenser coils OR condenser fan motor. or seal system problem. call a tech>.. good luck... LEAVE YOU COMMENT IF IT WAS GOOD FOR YOU... thanks
Mar 07, 2009 | Sub-Zero 632 / S
Subzero model #561, freezer is warm, water leak
Check to see if the freezer fan is running. Push in the two switches at the top. The light should go out and if the freezer is powered on the fan should come on. The icemaker runs on temperature so no cold means no ice. Check for ice build up around the evaporator. Could be a defrost issue or a sealed system problem. As for the water, is it the floor of the unit or the floor of the house? Is the drippan in place or sitting on the floor? Also check the condenser fan motor. If this is all greek to you, you should probably call a factory authorized servicer.
Feb 03, 2009 | Sub-Zero 561 / F
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
