Vsx-9900s Hi I had my Pioneer vsx-9900s cranked today and I heard a couple of clicks then no front panel or sound. One click from standby to on but nothing. Think it could be the power amps
  • 1,512 Answers
Hi angelo40
The amp sounds like it has a primary power supply failure and/or may be in protection mode. First, I would check for any blown fuses, replace any you fint with exactly the same type and rating. I can advise you here if you are not sure. If the unit blows a fuse after replace any failed ones, then there is a short circuit that you will have to trace out in the unit. DONT KEEP REPLACEING A BLOWING FUSE You generally are just doing more damage to the amp.
If all the fuses are OK and you are savvy with electronics and soldering, you could open it right inspect for these problems., and you have a multimeter, do some powersupply voltage checks, also check for that the main transformer is ok. Resolder any dry joints you find.
It may also (and or) have a problem in the output stages. Running it hard may have produced some dry solder joints, or blown a transistor in the output array. Happy to advise you further, just ask :)
regards
Graeme
Posted on Apr 21, 2008
  • Graeme Ross
    Graeme Ross Apr 22, 2008
    It may be outputs, hit me a FixYa rating and we can investigate further.
    G
  • pioneerVSX Jan 01, 2011
    Any chance you're still checking this post? I have the same amp- was running it hard for New Year's and at the end of the night it started to smell and then the sound stopped dead. The front panel and all controls work, but no second click- Also the A/B speaker selectors don't produce a click anymore when you turn them on and off. I am wondering about the output array you mentioned above. Is this checkable/replaceable? I don't mind tearing into this thing with a multimeter, but don't want to get nailed by a capacitor somewhere! THANKS in advance for any guidance!
    Steve
How do you troubleshoot a Pioneer VSX-1023 A/V receiver?
Try to do the factory reset on the Pioneer:
Switch the Pioneer into standby (turn it off).
1. Simultaneously press old the buttons on font panel for 5 seconds - BAND & STANDBY/ON
2. "Reset" on the front panel press
AUTO SURROUND/STREAM DIRECT
3. Then press ALC/STANDARD SURROUND
OR
Simultaneously pressing "down" and "on/off" for 5 seconds to reset the Pioneer
Mar 05, 2015 | Pioneer VSX-1023-K Receiver 7.1 Channels,...
I have a pioneer vsx-9900s it has high low speaker impedance switch all my speakers are 8omhs what do i set the switch to low or high ?
This is fairly variable depending on such factors as the sensitivity rating of your speakers; but as a rule of thumb just put the switch at low and you should be fine.
Dec 17, 2014 | Pioneer Audio Players & Recorders
I have a pioneer vsx-9900s- was running it hard for New Year's and at the end of the night it started to smell and then the sound stopped dead. The front panel and all controls work, but no second click-...
If the thing smells you shouldn't need any test equipment apart from your eyes and nose. That should lead you to something burnt up! Unlikely you will encounter any high voltage parts.
Jan 02, 2011 | Pioneer Audio Players & Recorders
Pioneer VSX-815-K receiver with sub in standby
Have you looked in the manual?
No sound from subwoofer. • Make sure the subwoofer is switched on.
• If the subwoofer has a volume knob, make sure it’s turned up.
• The Dolby Digital or DTS source you are listening to may not have an LFE channel.
• Switch the subwoofer setting in Speaker Setting on page 40 to YES or PLUS.
• Switch the LFE Attenuator Setup on page 61 to LFEATT 0 or LFEATT 10.
May 13, 2010 | Pioneer VSX-815-K Receiver
My Pioneer VSX-D1S A/V receiver will not power on; this began yesterday. Pressing the power button results in only a clicking sound along with the standby LED turning on. The owner's manual states to press...
Unit is pretty old I had one of these back in 98-99.
Time to upgrade a service tech is going to cost you $150 just to open it up and figure out whats bad.
Pioneer ok but check out Denon's line of receivers Onkyo is good too but they have a high rate of repairs
Pioneer doesn't make them like they used to that D1S was a tank, had tons of audio / video inputs was one of the first with video upconverting had lots of power and a great front display panel. BUT technology has come along way and pioneer hasn't kept up. They even stopped making high end TV's a few years ago even though they were regarded as the best sets out there.
check this out
Denon AVR-4310CIgoogle it they sell for ALOT less than sticker I bought one for $1299 with a 5 year warranty
Hope that helps
Feb 17, 2010 | Pioneer VSX-D307 Receiver
I have a pioneer vsx-501. I can't get it to turn on. When i hit the power switch I get a mechanical click and the standby light comes on, but that's it. All the internal fuses are fine. I think the power...
have you fixed it already?
I have the same receiver with the same problem as yours.
I found the fault in the voltage selector rotary switch. I'm refering to the round voltage selector switch not the other one, because you'll notice that there are 2 voltage selector switches at the back. The lock was broken so it couldn't switch the primary terminals of the main transformer.
Basically this amp has 2 power transformer, the small standby traffo and the large main traffo.
Try to press that round switch and press the front panel power switch. If it goes ON, then fix the center lock of that round switch.
Hope it helps.
Joel Herrera
Philippines
Aug 17, 2009 | Pioneer VSX-D508
Won't power up; push power button on, hear click in back left of unti, get nothing on front display and no output from speakers; as if unit trying to operate
Disconnect the speakers and see what happens. Carefully examine the speaker cables for unwanted connections (shorts).
Take a clue from when the power problem appeared. Something was moved and made the buzz a (probable) dead short.
May 16, 2009 | Pioneer VSX-305 Receiver
Pioneer receiver VSX-D411
Yes techtod you are right you do have to tell the receiver what you want it to do usually on the front panel you can access set up menu and go into input set up This is an example Say you plugged the dvd into optical one or coax 1 you must go to the input that says dvd click down till you highlight dig input and then select optical 1 or coax 1 there can be as many as 8 digital inputs so just check wich one you plugged it into and then tell the amp then you should be back to watching your digital movies
Mar 21, 2008 | Pioneer VSX-D411 Receiver
Receiver problem
Try this, it may work for you.
1.)Plug the unit into your mains voltage.
2.)Depress the enter and advanced surround buttons (on the front panel of receiver) at the same time for
at least 2 seconds, you should hear the relay tick and front panel should light up.
Mar 07, 2008 | Pioneer VSX-D514 Receiver
554 people viewed this question
 Grubhead
Grubhead
