Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Load Washer (LHW0050PQ) not spinning
My Whirlpool Front Load Washer (LHW0050PQ) will not enter the spin cycle. It goes through the wash cycle fine, but when it gets to the spin portion it just stops. I don't hear any noise at all. Putting it on spin only does not do anything either.
Any advice on how to fix it?
Thanks a bunch!
  • Whirlpool Master
  • 8,220 Answers
Use a quarter inch nut driver to remove the bottom panel. A tech sheet should be under there that will give diagnostics. Open the pump filter and check for objects.Whirlpool Front Load Washer (LHW0050PQ) not spinni - 616c06e.jpgfb90284.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 12, 2010
LHW0050PQ4 whilpool washing machine goes through wash cycle but wont rinse,spin or drain
According to the service manual, if the washer won't drain or spin the drain may be clogged.
http://www.searspartsdirect.com/partsdirect/user-manuals/27552/lhw0050pq4-whirlpool-parts-residential+washer-manual
Apr 04, 2014 | Whirlpool LHW0050PQ Front Load Washer
Washer won't spin.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 21, 2011 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool WFS1276AW bangs loudly when rinsing and spinning
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 06, 2010 | Whirlpool LHW0050PQ Front Load Washer
Door to washer won't open
You just have to wait a few minutes after the spin cycle is over and the "done" light is on. At least that always works for me.
Jun 16, 2009 | Whirlpool LHW0050PQ Front Load Washer
Basically,the machine you have is garbage! - I have one also, It is less than one year old and the repair folks have been out 5 times. It doesn't spin either!
I'd call this one a lemon!
Apr 14, 2008 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Dec 29, 2007 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool lhw0050pq washer will not spin
Possible your belt is loose; you have to unscrew the back after disconnecting electrical connection from wall socket. If the belt "gives" more than half an inch, you have to loosen the motor bolts and push motor upwards, then tighten the bolts very well. Try spin only to check, before closing the behind. It shd spin very fast.
Apr 25, 2007 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
334 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
