Question about Intel DG31PR Motherboard
My system does not boot properly
Intel Undi. PXE-2.1 (build 082)
copy right (c) 1997-2000 Intel corporation
For Realtex RTL 8111B/8111C Gigabit
Ethernet controller V213(071227)
PXE-E61 : MEDIA TEST FAILURE, CHECK CABLE
PXE-MOF: EXITING PXE ROM
Reboot and select proper boot device or insert boot mediain slected boot divece and press a key
    Novelist:
    Champion:
  • 226 Answers
This is common when there are corrupted boot files on your HDD or your HDD has failed. You need to boot to a windows CD and repair your startup files. Alternatively you can reformat to a fresh windows install but you will lose all of your data. If the previous steps fail then it looks like you may need to replace your HDD.
Hope this helps,
www.PuterCare.com
Posted on Jul 12, 2010
INTEL UNDI, PXE-2.1(BUILD 082) COPYRIGHT (C) 1997-2000 INTEL CORPORATION ..RTL8111 PXE-E53: NO BOOT FILENAME RECEIVED, PXE-M0F: exiting PXE ROM NO BOOTTABLE DEVICE--INSERT BOOT DISK AND PRESS ANY KEY
Could be your HDD is faulty and has errors. Could be you have upgraded to Win10 and the system cannot find the boot sector now. Will it boot from a DVD ROM?
Jun 10, 2016 | Intel Computers & Internet
This is what mine says when I turn on Intel UNDI, PXE-2 . 1 (BUILD 082) Copyright (C) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller v1.0.0.5(01/22/09) Check cable connection..
You hard drive is missing from the system. Just does not recognize it.
Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Oct 25, 2012 | Acer Aspire One Netbook 8.9" Notebook
Intel UNDI, PXE-2.0 (build 082) Copyright (C) 1997-2000 Intel Corporation
As soon as you power on your PC, start pressing the F2 key. This should bring up the BIOS (Basic Input Output Systems) screen. Make sure your Hard Drive is listed in the Boot order. Usually a CD drive is listed first, then the Hard Drive as a second boot device. If you do not see the Hard Drive listed, then it probably is bad and needs replacing. If it is listed correctly in the boot order, your Operating System has crashed, and you will need the recovery disks or the instalation disk for your Operating System (XP, Win7,etc.)
Aug 11, 2012 | Acer Computers & Internet
I need help with something. My eMachines D520 laptop will not boot up. Here is what the message says:Intel UNDI, PXE-2.1 (build 082) Copyright (C) 1997-2000 Intel Corporation For Realtek RTL8111B/8111C...
Your machine is trying to boot off a network (PXE). Either you stole it from work, or the bios is not set up right and / or the hard disc is either no good or the cable is disconnected from it. The boot sequence in BIOS should tell it to not boot from the network first, unless it's on a corporate network. It should say boot from the hard drive first. If it's set to do that and it fails, then your hard drive is probably bad. Dropping a laptop on the ground will do that; did you loan it out, recently???
Sep 27, 2011 | Computers & Internet
My acer is saying that Intel UNDI, PXE-2.1 (build 082) Copyright (C) 1997-2000 Intel Corporation For realtek RTL8111B/8111C Gigabit Ethernet Controller v2.15 (080320) PXE-E61: Media test failure, check...
From your explanation, it looks like the laptop is trying to boot from a network source. Restart your computer and press F2 or Del when booting to go into the system BIOS. In the BIOS, locate the boot order, or boot sequence. There should be Booting devices listed in a numerical order, so what you have to do is, read the instruction at the bottom of the page (still in the BIOS) to see what keys to press in order to change the booting order. (Usually its (- or +) or (Page up and Page down) or anything like that...
Make sure that when you change the boot order in the BIOS, your Hard disk should be the first one. This will tell the computer to boot from your Hard disk and not from the network source... try that, it should solve you out of that problem
Aug 09, 2011 | Acer Computers & Internet
Wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
My laptop doesnt work anymore suddenly!
This error means the operating system on the hard disk couldn't load due to possible faulty hard drive or disk controller. The fault could also mean the hard drive needs reseating to make proper connection. Reseat the hard drive and if you still get this error, then you need to determine if the disk controller is faulty.
To do this, remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer see this hard drive as an external drive and you can also see the contents of the drive, then the hard drive is OK and the fault is a faulty disk controller. If the computer cannot detect the hard drive then the hard drive is faulty.
Then get a new hard drive insert it into youe laptop and install Windows to get your laptop operatioal.
Apr 10, 2009 | Acer Aspire 4720 Notebook
How do i repair my pc it gives a message that says Intel UNDI, PXE-2.0 (build 082) Copy Right (1997,1998,1999)Intel Corporation VIA Rhine II Fast Ethernet Adapter V2.43 (2005/12/15) PXE - E61: Media test...
Dear,
If you are using PC then make sure that Boot from PXE Rom is disable and boot from hard disk drive is enabled. Check your BIOS setting for configure it.
Regards,
Rakesh Kumar
Network Support Engineer
Apr 07, 2009 | Compaq Computers & Internet
Argh girlfriend spilled hair gel on my laptop
thats ethernet card realtek
did you check to see hard drive is securely in tack
saying can't find os
you may need to do a new install let me know
if you took apart you made have caused hard drive to become lose
Jan 17, 2009 | Acer Aspire 3610 Notebook
Acer Aspire 9410-4933 not booting up
YOU NEED TO REINSTALL OPERATING SYSTEM ... FORMAT THE ACTIVE PARTITION AND REINSTALL
Sep 15, 2008 | Computers & Internet
Intel DG31PR Motherboard Logo
809 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
