Question about Sharp AR-M205 Copier
My Sharp ARM205 has a L4 error code and it makes a funny noise when I turn it on. No papers are jammed so what is wrong?
  • Sharp Expert
  • 316 Answers
Main motor problem
Posted on Jul 13, 2010
Sharp AR5316 is error code L4
Main motor issue check fuser unit (hot part) check paper jams durum installed correctly image units etc
Dec 11, 2015 | Sharp Office Equipment & Supplies
ERROR CODE L4-02. PAPER JAM
indeed you can experience the paper JAM because the developing motor is the one which is faulty.
1. check if it is being powered.
2. if so change it.
3. maybe its gear is broken therefore it can not rotate.
Jul 14, 2011 | Sharp AR-M455N Copier
Sharp ar 5316 code error L4
This problem relates to the Main Motor Drive on the printer.
The L4 error details that the Motor Drive has been Overloaded.
I would recommend opening the main door and inspecting to see if it's jammed by paper or anything else. Try disconnecting the power and blowing it out with air-cleaner. Then restart and see if the error is still persisten.
There is also another solution that was posted back in '09 by hamzaskilltd, who mentioned that the two common problems can be as follows:
1. Main motor lock detection 2. shifter motor trouble
My second recommendation, if my first doesn't work, would be to either replace the copier or request repair from Sharp or another tech repair shop. Such as Geek Squad which provides industry back support.
Just be prepared that both solutions will cost.
Hope this helps.
Mar 03, 2011 | Sharp AR-5316 Advanced Digital Imager...
ARM205 Error Code CH. what is wrong with our Sharp Copier
If CH flashing reinstall your toner cartridge properly if not that mean you have an open door close it.
Dec 29, 2010 | Sharp AR-M205 Copier
Error Message - L4-03 What is wrong?
If you had paper jams it will display this error after 3 in a row in the fuser. Double check to make sure all paper is removed from the fuser. To reset, on the keypad press pound star clear star and enter sim 14 and press copy button. reset copier it should turn off and on, test if paper jams there may still be something stuck.
Aug 24, 2010 | Sharp AR-M550U Copier
Error code L4 30
L4 error code mean your copier motor fail problem.
Please press # Interrupt C interrupt press 16 press start key or print key.If are not fix this problem please check motor fuse or any kind of gear was broken.
Dec 16, 2009 | Sharp AR-M455N Copier
CODE L4-02 JUST ILUMINATE ON MY SHARP AR-M 350U PHOTOCOPIER
That code means you have a drum drive motor failure. The drum is the long, cylindrical green-blue tube you'll see when you open the left-side door.
Chances are some paper jammed up inside the drum process unit (that black frame that holds the drum) and it's keeping the drum from turning. Check the drum/process unit and make sure they are clear of any material that could cause a jam.
Aug 28, 2009 | Sharp Office Equipment & Supplies
Sharp arc 270 error code l4-04
Possible bind in one or more of the developer units. Replace as needed. Sec. 11 Page 11-61 it talks about Paper Feed Drive Motor, it is the same motor as the Black Developer Drive Motor.
For L4-04 swap those two motors around to troubleshoot bad motor
Feb 03, 2009 | Sharp AR-C270 Color Copier
L4-05
Yes , main motor lock trouble , try to turn on & off several times quickly ! There is a load in the drive (stuck) look for paper jammed in paper path . need make & model to help further .
Mar 12, 2008 | Sharp AR-C160 Color Copier
Sharp AR-M205 Copier Logo
302 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
